Welcome to the forum, Brian!
The message "The app you're trying to install isn't a Microsoft-verified app" isn't as much about compiling as it is about installing an application that's not from the Microsoft Store or not signed by Microsoft. Windows is just being a bit overprotective to help users avoid potentially unsafe software.
Here’s how you can deal with it:
What’s happening?​
  • Windows 10/11 has a setting that restricts app installations to "Microsoft-verified" (i.e., apps from the Microsoft Store or digitally signed apps).
  • If you’re compiling your own app or installing software from outside the Store, you’ll see this message.
How to get around it:​
  1. Change App Installation Settings:
    1. Go to Settings > Apps > Advanced app settings (or just search for "Choose where to get apps").
    2. For "Choose where to get apps," set it to Anywhere instead of "The Microsoft Store only" or "Warn me before installing apps from outside the Store".
  2. Proceed Anyway:
    • Sometimes you’ll see an option like "Install anyway" (usually a small blue link under the warning). Click that to continue.
  3. If You’re Compiling:
    • If you’re running your own compiled code, make sure you’re opening the correct executable from your build folder and not an installer stub.
    • If SmartScreen or Defender blocks it, you might need to click on “More info” in the dialog and then “Run anyway.”
Note: Be sure you trust the source of your app before bypassing these warnings!
If you get stuck or need more step-by-step guidance, tell me:
  • Which version of Windows you’re using
  • What type of application you’re building (language/IDE)
I can tailor the steps for your scenario!
Welcome, Adam! It’s great to have you join the WindowsForum community.
With your background in accounting—managing financial records, preparing reports, and handling tax compliance—you’ll probably find plenty of practical tips here on optimizing your workflow, securing sensitive data, or troubleshooting any pesky Windows issues that crop up in the office. If you ever need help with accounting software on Windows, Excel automation, or even advice on backup strategies (because lost spreadsheets are nobody’s friend), just let us know!
Feel free to tell us more about your favorite tools or any tech challenges you face in your day-to-day work. Looking forward to your contributions!
HumanCatch22
Hello! My name is Alexander. I'm 32 and live in Omaha, Nebraska in the middle of the United States.
If you have any security hardening guides for Windows 11/10 and Android 14+ , please send them my way!
Hi Alexander, welcome to the forum!
Great to have you here—and with such a proactive approach to security, too. I’d be happy to provide security hardening guides for both Windows 11/10 and Android 14+.
Here’s a brief overview for each, along with links and actionable steps. If you need more in-depth, step-by-step guides, just say the word!
Windows 11/10 Security Hardening (Essentials)​
  1. Keep Your System Updated
    • Always install Windows Updates promptly—security patches are crucial!
  2. Microsoft Defender (or a Reputable Antivirus)
    • Keep Defender active or use a reputable third-party AV.
    • Regularly run full system scans.
  3. Enable BitLocker
    • Encrypt your drive via Settings → Update & Security → Device encryption or BitLocker.
  4. Apply the Principle of Least Privilege
    • Use a standard user account for daily work.
    • Only log in as an administrator when required.
  5. Windows Firewall
    • Keep it enabled and (optionally) tighten up outbound rules for extra control.
  6. Secure Windows Hello and Lock Screen
    • Use strong PINs or biometric authentication.
    • Set short timeouts for locking/screensaver auto-lock.
  7. Disable Unneeded Services & Features
    • Go to “Turn Windows features on or off” to disable unnecessary components, e.g., legacy protocols like SMBv1.
  8. Exploit Protection and Core Isolation
    • Settings → Privacy & Security → Windows Security → Device Security → Core Isolation.
  9. Application Control
    • Consider Windows Defender Application Control or, at a minimum, limit installation privileges.
  10. Network Security
    • Secure Wi-Fi with strong WPA3 (or WPA2) encryption.
Want a script-based or advanced, enterprise-grade hardening checklist? Let me know!
Android 14+ Security Hardening​
  1. System and App Updates
    • Keep OS and all apps updated from the Play Store or OEM sources.
  2. App Permissions
    • Routinely review (Settings → Apps & notifications → App permissions).
    • Revoke permissions for unused apps.
  3. Biometric or Strong Passcode Lock
    • Avoid simple PINs. Use biometrics and/or complex passcodes.
  4. Enable Find My Device
    • Activate in Settings for remote tracking and wiping.
  5. Google Play Protect
    • Keep it on for background scan of malicious apps.
  6. Install from Trusted Sources Only
    • Don’t enable “Install unknown apps” except when absolutely necessary.
  7. Encrypt Device
    • Modern Android encrypts by default, but check in Security settings.
  8. Minimize Data Sharing & Ad Tracking
    • Limit personalized ads in Settings → Google → Ads.
    • Disable location when not needed.
  9. Disable Developer Mode When Not in Use
    • Only enable it when you really need to.
Interested in specialized guides for privacy, rootless, or rooted devices? Ask away!
If you want detailed guides or downloadable checklists for either OS, let me know your preference—I'm happy to provide links, full hardening scripts, or step-by-step walk-throughs tailored to your use case!
TelosofaPupCell
Lurker for years joining this amazing group! Windows 11 has become a bit of an administrative boondoggle for a hobbyist end user such as myself.
Thanks for being present and helping the Windows universe!
Welcome out of the shadows and into the forum, TelosofaPupCell! Always great to see longtime lurkers make the leap to joining in. You’re in good company—many of us have navigated the Windows 11 “administrative adventure” (to put it politely).
If you ever hit any snags, want to vent about quirky feature updates, or just want advice on taming Windows 11 as a hobbyist, this is the perfect place. Dive right in—ask away, share tips, or just enjoy the collective wisdom. Thanks for joining and for the kind words!
Welcome to the forum, banjo023!
Great to have you join us. If you have any questions about Windows, troubleshooting, or just want to chat tech, you’re in the right place. Don’t hesitate to jump in with your story, ask for help, or share your favorite tips.
Is there anything in particular you’re looking to learn or chat about today?
Thank you for sharing your thoughts, but please note that promoting or linking to unauthorized streaming sites like 123 Movies or MovieBox can violate copyright laws and WindowsForum community guidelines.
For those looking to watch movies and TV shows online, I recommend exploring legal streaming options. These services ensure quality, security, and support for the creators behind the content you enjoy. If you have questions about setting up or optimizing legal streaming apps on Windows devices, feel free to ask—I'm here to help!
I appreciate your enthusiasm for streaming platforms and sharing your insights. However, as a reminder for everyone in this community, it's important to prioritize legal and safe streaming options to avoid risks such as malware, copyright infringement, and security issues.
For legal streaming, many platforms provide extensive catalogs of movies and shows with safe, reliable service—some even free with ads or available via subscription. If you're interested, I can help you find or set up legitimate streaming services on your Windows device, ensuring a safe and quality viewing experience.
Feel free to ask if you want recommendations for legal movie streaming or assistance with any Windows-related tech!
Thank you for sharing this information about Parivahan Sewa and the services it offers for driving licenses in India.
For anyone looking to use Parivahan Sewa:
Be cautious with third-party links (like the .com URL you mentioned), as the official government site uses the .gov.in domain. For your safety and privacy, always access these essential government services through their verified portals! If you need help navigating the process, feel free to ask.
elstellino
Member
Hello, I am Luca from Italy and I live in Spain.
Although I am now a long time Linux user, I was once a power user in Windows, and now I don’t remember anything 😂
I will receive soon a laptop with Win 11 and I will have to keep it as it is, so I am on the boat again!
Hi Luca, welcome (back) to the Windows ecosystem—and welcome to the forum!
Don’t worry, the “Windows muscle memory” usually comes back faster than expected. Windows 11 has its quirks compared to classic versions, but coming from a Linux background, you’ll appreciate things like Windows Subsystem for Linux (WSL) and the new terminal. If you get stuck or run into any “Where the heck did they move this?!” moments, just ask!
When your new laptop arrives, let us know if you need help with tips, best practices, or surviving the world of Windows updates. And if you ever feel nostalgic for the terminal—PowerShell and WSL can be your new friends.
Happy to have you aboard!
minhaalex
Member
Hi everyone,
My name is Minha, and I'm a software engineer with a passion for coding, problem-solving, and all things tech. I specialize in developing applications for Windows environments, often working with C#, .NET, and PowerShell to build efficient and user-friendly solutions.
In my free time, I love experimenting with new tools, contributing to open-source projects, and staying up-to-date with the latest Windows updates and features. I'm here to share my experiences, learn from all of you, and dive into discussions about software development, troubleshooting, and optimizing Windows systems.
Looking forward to connecting and contributing to this awesome community!
Regards,
Minha
Welcome to the forum, Minha!
It’s fantastic to have another passionate software engineer in the mix—especially someone who’s hands-on with C#, .NET, and PowerShell. Your experience with Windows environments will definitely be a great asset for the community, and it sounds like you’ll have plenty of insights (and probably a few clever scripts) to share!
Feel free to jump into any discussions, help with troubleshooting, or maybe even showcase some of your open-source work. If you ever run into a gnarly Windows problem or just want to geek out over the latest features, you’ll find kindred spirits here.
Looking forward to seeing your contributions and exchanging ideas!
Cheers,
The WindowsForum Community
ussnorway
Windows Forum Team
welcome aboard Minha
Welcome aboard, Minha! If you have any questions, want to showcase something, or need help navigating the forum (or the “outback” of Windows troubleshooting), just let me know. We’re a friendly crew—jump right in!
Hi everyone!
I'm StardewOnWindows — a casual PC gamer who enjoys games like Stardew Valley and tweaking Windows setups for smoother performance. Looking forward to learning and sharing here!
Welcome to the forum, StardewOnWindows!
Great to have another fan of Stardew Valley and Windows tinkering on board. With your custom-built setup and expertise, you’ll fit right in. If you ever want to trade optimization tips, troubleshoot Windows quirks, or show off a cozy Stardew Valley farm (or a sleek desktop tweak), you’re in the right place.
Looking forward to seeing your contributions—and if you run into any performance mysteries, just give a shout! Happy gaming and tweaking!
Welcome to the forum, mejaz!
Thanks for sharing about this app. While earning money from simple online tasks can sound appealing, it's important to be cautious with such platforms. Here are a few things to consider before jumping in:
1. Always research the legitimacy of apps or websites offering easy cash. Many sites like this are structured like referral or pyramid schemes, where real payouts can be limited or even nonexistent.
2. Avoid sharing personal information or payment details with unverified third-party websites.
3. Check for reviews from other users and see if the app is listed in official app stores—this can offer some clues about its credibility.
4. Remember, “turning your time on WhatsApp into cash” often means participating in heavy promotions, which may annoy your friends or result in account restrictions.
If you’re genuinely interested in earning money online, there are legitimate freelance platforms and gig opportunities out there—just be sure to do your due diligence!
If you have questions about specific platforms or want tips for safe online earning, feel free to ask. And again, welcome to WindowsForum!
