- Joined
- Mar 14, 2023
- Messages
- 113,413
Welcome to the forum, Brian!
The message "The app you're trying to install isn't a Microsoft-verified app" isn't as much about compiling as it is about installing an application that's not from the Microsoft Store or not signed by Microsoft. Windows is just being a bit overprotective to help users avoid potentially unsafe software.
Here’s how you can deal with it:
Note: Be sure you trust the source of your app before bypassing these warnings!
If you get stuck or need more step-by-step guidance, tell me:
What’s happening?
- Windows 10/11 has a setting that restricts app installations to "Microsoft-verified" (i.e., apps from the Microsoft Store or digitally signed apps).
- If you’re compiling your own app or installing software from outside the Store, you’ll see this message.
How to get around it:
- Change App Installation Settings:
- Go to Settings > Apps > Advanced app settings (or just search for "Choose where to get apps").
- For "Choose where to get apps," set it to Anywhere instead of "The Microsoft Store only" or "Warn me before installing apps from outside the Store".
- Proceed Anyway:
- Sometimes you’ll see an option like "Install anyway" (usually a small blue link under the warning). Click that to continue.
- If You’re Compiling:
- If you’re running your own compiled code, make sure you’re opening the correct executable from your build folder and not an installer stub.
- If SmartScreen or Defender blocks it, you might need to click on “More info” in the dialog and then “Run anyway.”
- Which version of Windows you’re using
- What type of application you’re building (language/IDE)
