RodBarnes
- Joined
- Dec 8, 2011
- Messages
- 71
- Thread Author
- #1
Friend's Asus TP500L laptop running Windows 10 is giving the 0xC0000225 error (). I created a recovery image for a USB and booted from that. I've tried all the standard stuff (see below) and just looking for other ideas before I pronounce the drive toasted. This was originally delivered with Windows 8.1 and it has been upgraded to Windows 10 and has been working fine for a long time.
Steps I've taken:
Steps I've taken:
- Startup Repair -- reported it "...couldn't repair your PC"
- sfc /scannow -- reported "no violations"
- chkdsk c: /r -- A second chkdsk reports: During phase 1 "Examining basic file system structure" it found four "record segments" unreadable and later fixed/repaired several files. During phase 2 "Examining file name linkage" it attempts to fix one of the record segments and then bails, reporting "Failed to transfer logged messages to the event log with status 50". (I actually saved the output from the first chkdsk but saved it to the X: drive instead of the media drive, so lost it.)
- bootrec /scanos -- finds 0 Windows Installations but says "completed successfully"
- bootrec /fixmbr -- Says it completed successfully
- bootrec /fixboot -- Says it completed successfully
- bootrec /rebuildbcd -- finds 0 Windows Installations but says "completed successfully"
- diskpart shows partition 4 as primary; setting it active reports it is "not a fixed MBR disk" (Yep, it is a GPT disk so that won't work.)
