AgejevDominik
First of all, I'm sorry if this isn't the right place to post this kind of question. If you know where I can post this please let me know.
Onto the question.
I'd like to start a program (Rainmeter) when I plug in my laptop to charge, I would also like to kill it when I plug it out, i.e. stop charging. I'd like the program to run while the laptop is at a 100% while plugged in (so it's not actually charging but it's plugged in).
The reason I am trying to do this is because Rainmeter drains a lot of power. I might add other programs in the future.
Can I do this with the Task Scheduler? (If so, how?)
I can do basic coding in Python and C++ but I don't know how to interact with other programs and definitely not with the machine itself.
Thanks in advance
You could launch the following Powershell script on user logon. Just change the paths in the first line to whatever you want to start and stop.
$RunApplicationsOnAC = @("C:\Windows\notepad.exe","C:\Windows\System32\cmd.exe")
Function Get-IsOnACPower
    return (Get-WmiObject -Namespace root\WMI -Class BatteryStatus).PowerOnline
Function Main
    $PowerState = Get-IsOnACPower
    while($true)
        $CurrentPowerStatus = Get-IsOnACPower
        if($PowerState -ne $CurrentPowerStatus)
            $PowerState = $CurrentPowerStatus
            # Power status has changed to on AC Power (plugged in)
            if($PowerState)
                foreach($RunApplicationOnAC in...
Neemobeer
Windows Forum Team
Function Main
    while($true)
            if($PowerState)
                foreach($RunApplicationOnAC in $RunApplicationsOnAC)
                    Start-Process -FilePath $RunApplicationOnAC -Wait:$false
            else
                    $ProcessName = (Split-Path -Leaf $RunApplicationOnAC).Replace(".exe","")
                    Stop-Process -Name $ProcessName -Force -ErrorAction SilentlyContinue
        if($PowerState)
                try
                    Get-Process -Name $ProcessName -ErrorAction Stop | Out-Null
                catch
                    Start-Process $RunApplicationOnAC -Wait:$false
        Start-Sleep -Seconds 5
Main
