Windows 7 After installing Firefox 4 beta, and IE9 Beta,system keeps restarting
Bubbymac
After installing Firefox 4 beta, IE9 Beta and deleting quarantined items from Malware Bytes. After system restarts it keeps going to the Configuring windows screen do not turn off your computer. It goes for a few minutes then reboots. It has done this numerous times... :serious:
Well they are betas so you are in the realms of the unknown to some extent. I would uninstall them both (or may run a system restore) to get back to a point before you installed them. Then install just one of them (I'd always avoid running two betas simultaneously - just clouds any issues).
Why did you delete items from Malware Bytes during this process?
