Windows 7 An installation problem
motibin
While trying to install windows 7 beta that downloaded from microsoft-windows-7 site and burn into DVD
I tried to install it on Laptop ACER ASPIRE that over the system requirment for windows 7.
The boot was ok - but after pressing the "INSTALL NOW" button. after about 2-3 minutes a problem was accured:
"a required cd/dvd drive device is missing".
I also burn the disc twice and still the same error message.
kingskin
I had problems with the install from the DVD. I just installed vista x64 and then ran the setup from within windows, only choosing a clean install. It works fine and isnt an upgrade as such, it just renames your windows to windows.old and moves your user folder and prog files into it as a backup.
Top Bottom
