Romchik9007
- Joined
- Aug 31, 2018
- Messages
- 23
- Thread Author
- #1
Hello all, hope all is well.
I've bought a brand new monitor: ASUS VG248QE
But here's the problem, when the monitor arrived, it came with a CD of what I assume would be drivers for the monitor. However, my PC doesn't have a generic CD/DVD reader. I've installed and connected the monitor to the PC, and all is working. However, in my 'Setting>Display' section, Windows detects it as a "Generic PnP Monitor".
That's not supposed to happen, right? It should detect the monitor as it is.
I've tried to look for the ASUS WHQL Driver for Windows 10, but no luck.
Can someone please lead me to the right direction here?
It'd be much appreciated.
Thanks.
Thanks.
- Joined
- Jul 4, 2015
- Messages
- 8,970
Here you'll find your driver:
VG248QE Driver & Tools | Monitors | ASUS USA
Just choose your operating system.
Sent from my SM-N950F using Tapatalk
Romchik9007
- Joined
- Aug 31, 2018
- Messages
- 23
- Thread Author
- #4
Already ahead of you there. I've picked Windows 10, and the driver downloads successfully. It installs a software called ASUS MultiFrame. But whenever I try to launch it from my desktop, it just doesn't want to.Here you'll find your driver:
And also, this may sound weird, but every time I change my refresh rate to 144Hz, for some reason my internet just breakes. Like, whenever I search something on Chrome, it says there's no Internet connection.
Romchik9007
- Joined
- Aug 31, 2018
- Messages
- 23
- Thread Author
- #5
However, when I change it back to 60Hz, the internet comes back on. I assume it's got nothing to do with the monitor, maybe?Here you'll find your driver:
I'm seriously at a loss at the moment.
Romchik9007
- Joined
- Aug 31, 2018
- Messages
- 23
- Thread Author
- #7
Absolutely sure I've picked the right Windows.Are you sure you picked the right version of windows (32 bit or 64 bit)?
Are you sure your display adapter card supports the 144 screen refresh rate?
In terms of display adaptors, that's the DVI cable, right?
If so, I am using the DVI cable
No, I'm talking about the graphics CARD which is installed in your computer. The DVI port you are connecting the cable to it is the outlet port of the graphics card. Check your computer specifications and find out what type of graphics card you have installed and then look for its specifications (it should be an Nvidia or AMD usually).
nmsuk
- Joined
- Sep 7, 2009
- Messages
- 4,328
You need to be using display port or hdmi. DVI lacks the bandwidth for 144hz
Romchik9007
- Joined
- Aug 31, 2018
- Messages
- 23
- Thread Author
- #10
Ah right okay I got ya. I've got a GTX 1070 Zotac AMP Edition. And I'm fairly certain that should be able to handle 144Hz 1080p?No, I'm talking about the graphics CARD which is installed in your computer. The DVI port you are connecting the cable to it is the outlet port of the graphics card. Check your computer specifications and find out what type of graphics card you have installed and then look for its specifications (it should be an Nvidia or AMD usually).
Romchik9007
- Joined
- Aug 31, 2018
- Messages
- 23
- Thread Author
- #11
Alright cheers mate. I'll try it outYou need to be using display port or hdmi. DVI lacks the bandwidth for 144hz
- Joined
- Aug 28, 2007
- Messages
- 36,129
If the driver supplied doesn't have a exe then you have to install it via Device manager.
Find device manager and the pnp monitor. Click update driver followed by browse my computer, find the folder which contains the driver 'inf' and click on that followed by ok.
Your monitor should now say the proper name when viewed in device manager.
(I only had to do this myself two days ago so know it works.
Romchik9007
- Joined
- Aug 31, 2018
- Messages
- 23
- Thread Author
- #14
Alright, so the best option would be is to contact Zotac themselves?From Asus site:
"To activate 144Hz function (in 2D mode), both DisplayPort (or Dual-link DVI) and a selected graphics card with the latest driver are required. Please kindly contact the service center of your graphics cards companies for further technical supports."
Romchik9007
- Joined
- Aug 31, 2018
- Messages
- 23
- Thread Author
- #15
Alright pal, I'll look into it. CheersIf the driver supplied doesn't have a exe then you have to install it via Device manager.
- Joined
- Aug 28, 2007
- Messages
- 36,129
No, you don't need to, your graphics card is ok, it supports the 144 refresh rate. You just only have to use the right cable, as nmsuk said. I expect that after using the right cable you will be able to also start the Multiframe.Alright, so the best option would be is to contact Zotac themselves?
Similar threads
- Replies
- 0
- Views
- 85
- Replies
- 0
- Views
- 26
- Replies
- 1
- Views
- 950
- Replies
- 0
- Views
- 87
- Replies
- 0
- Views
- 97
