ATI Radeon 64MB PCI card driver needed
reghakr
My onboard Nvidia GeForce 6100 nForce 405 (Microsoft Corporation - WDDM) video card has lost it's blue color.
I've installed an ATI 7100 64MB DDR V/D/VO PCI card and cannot locate drivers.
It will not accept the latest Catalyst drivers as it is not a HD card.
Any ideas on where to locate a compatible driver?
I'm running the 32-bit version.
I also changed my Display to a Sony DVI, but cannot update the .inf files as no Monitor shows up in Device manager.
There is a Legacy 9.3.1 driver that they recently released and should work. Normal install won't work(At least it didn't for me) What I had to do was;
1. extract the driver
2. Go to device manager
3. Select update drivers
4. Next choose let me pick
5. Then have disk
6. Finally find the driver in the sub folder.
Once I did this my X1900 is using the ATI driver instead of the WDDM one.
Hope this helps.
