JFilkins
- Joined
- Feb 24, 2024
- Messages
- 1
- Thread Author
- #1
Recently picked up a Rodecaster Duo for better audio streaming between two PCs. The Rodecaster Duo is meant for 24 bit/48K Hz audio format. The Duo has two USB inputs so you can connect to two PCs. When connected to USB 1 the PC locks Audio Default Format at 32 bit/48K Hz. USB 2 is locked at the supported 24 bit/48K Hz. Does not matter if I switch which PC has USB 1/2 plugged in the Default Format is still locked at the respective rate. I am getting choppy audio from USB 1, even if I switch to a different PC, and I believe it is because USB 1 is locked at an unsupported audio rate. How can I change the Default Format from 32 bit/48K Hz to 24 bit/48K Hz?
Windows 11
i9-9700K
Z390 Aorus Pro WiFi
Windows 11
i9-9700K
Z390 Aorus Pro WiFi
