Microsoft has warned that users of its Azure cloud may see higher-than-normal latency and intermittent disruptions after multiple undersea fiber-optic cables in the Red Sea were cut, forcing traffic onto longer alternate routes while repair work and global rerouting continue.
Background
The Red Sea is a critical chokepoint for submarine communications: multiple major fiber systems transit the corridor between Europe, the Middle East and Asia, and damage there quickly ripples into higher latencies and degraded throughput for cloud services whose traffic traverses those routes. Recent cuts to several cables in the Red Sea have produced just such an effect, prompting cloud operators — including Microsoft Azure — to reroute traffic around the damaged segments and to alert customers that performance impacts are possible while repairs and alternate routing are in effect. (ft.com)This episode is not the first time the region’s undersea infrastructure has affected public cloud performance. Previous incidents in 2024–2025 disrupted significant Europe–Asia traffic and required months in some cases to fully restore service because of the complexity of remote undersea repairs and the limited global fleet of cable-repair ships. Industry sources and network operators have repeatedly warned that the ecosystem is brittle when multiple high-capacity segments are affected simultaneously. (datacenterdynamics.com)
What Microsoft said, and what it means for Azure customers
Microsoft posted a service health update stating that Azure users "may experience increased latency" because of multiple undersea cable cuts in the Red Sea, and that engineers are monitoring, rebalancing and optimizing routing to mitigate customer impact. The update also said undersea repairs take time, and Microsoft will provide daily updates or sooner if conditions change. Key technical implications of that statement:- Routing detours will increase round-trip time (RTT). When traffic is forced onto geographic detours — for example, routing through alternate subsea cables, overland fiber through different countries, or via trans-Pacific/around-Africa routes — the physical distance and added network hops increase latency and jitter for affected flows.
- Performance is likely to be uneven and regional. The service impact will be concentrated on traffic that originates, terminates, or transits between Asia, the Middle East and Europe, depending on which physical paths Azure customers use and where their endpoints are located. Microsoft’s notice specifically flagged traffic traversing the Middle East as a likely area of impact.
- Cloud control-plane vs. data-plane effects differ. Some Azure control-plane operations (management APIs, provisioning) may remain responsive if they use separate paths or regional endpoints; data-plane workloads (application traffic, database replication, inter-region backups) are more sensitive to added latency and packet loss. Historical outages show that storage partitions and private endpoints can be affected in complex, cascading ways when network routing is stressed.
The operational context: why undersea cable cuts matter to clouds
Submarine fiber is the backbone for intercontinental cloud traffic. While clouds operate global backbones and peering fabrics, they still rely on a heterogenous mix of submarine systems and terrestrial interconnects. When one or more key segments in a corridor like the Red Sea are severed, the industry faces three practical realities:- Repairing undersea cables requires specialized cable ships and safe access to the fault zone, which can be delayed by regional security issues or permitting. Repairs are measured in days-to-months rather than hours.
- Alternate routing is available but imperfect: reroutes create longer paths and concentrate traffic on other links, potentially causing congestion and increased latency elsewhere. Satellite and microwave backhaul can provide stop-gap capacity but generally at higher cost and latency. (subseacables.net)
- The cloud’s internal service dependencies can amplify user-visible impact: storage, identity, private endpoint connectivity and replication can be affected differently depending on how providers segment traffic and orchestrate failover. Past Azure incidents show complex cascading effects when storage partitions, private links, or zonal resources are involved.
Timeline and current status (verified claims)
- On September 6, 2025, Microsoft posted a service health update warning Azure customers of increased latency following multiple undersea fiber cuts in the Red Sea, and said it had rerouted traffic through alternate paths while monitoring the situation. Microsoft committed to providing daily updates or sooner as conditions evolved.
- Industry reporting since the initial Red Sea cable incidents (that began in 2024 and recurred in 2025) documents both physical damage to cables and operational complications caused by regional maritime security issues, stranded vessels, and the logistics of cable repair. These complications have in earlier instances delayed repairs and forced rerouting for extended periods. (datacenterdynamics.com)
- Independent monitoring firms and network operators reported measurable latency increases and notable shifts in traffic patterns during earlier Red Sea outages, with some providers estimating that a substantial share of Europe–Asia traffic was affected — figures that vary by operator and measurement methodology. These assessments corroborate the practical impact Microsoft described. (subseacables.net)
Technical analysis: how Azure and other cloud providers mitigate subsea disruptions
Cloud operators have several tools to limit impact from submarine cable failures. Understanding which measures are in play helps explain why the user experience may vary:- Dynamic routing and traffic engineering. Providers can change BGP routes, load-balance sessions across multiple undersea systems, or shift flows to different peering points. That reduces packet loss but frequently increases latency because traffic takes a longer path. Microsoft confirmed it was rebalancing and optimizing routing as part of mitigation.
- Regional failover and multi-region architectures. Workloads architected to tolerate inter-region latency (e.g., eventual-consistency databases, asynchronous replication) are less impacted than synchronous systems. Customers who rely on single-region synchronous replication or private end-to-end topologies are more vulnerable. Historical Azure incidents emphasize the importance of multi-region DR planning.
- Peering diversity and private interconnects. Enterprises with private clouds or direct-connect arrangements (e.g., ExpressRoute equivalents) may shift over private interconnects that themselves rely on multiple transit paths. That can mitigate some public-internet routing disruptions but does not eliminate the problem if the underlying physical route is damaged.
- Satellite and alternative last-resort links. Some operators buy satellite capacity to handle urgent traffic during major cable repairs; this reduces capacity constraints but increases latency substantially and is not appropriate for latency-sensitive financial or real-time applications.
Risk assessment: who and what is most exposed
- Synchronous replication and low-latency services — Databases that require sub-10ms replication or distributed systems tuned for low RTT will see the greatest functional impact. Increased latency can cause replication timeouts, leader elections, or reduced throughput.
- Real-time user experiences — Interactive web apps, VoIP, gaming, and remote-desktop services will exhibit higher latency and jitter, leading to degraded quality. Enterprises with remote branches whose traffic must traverse the damaged corridor are particularly vulnerable.
- Supply-chain and market-sensitive traffic — Financial trading and other latency-monetized applications may experience measurable degradation when long-haul paths are used as detours. Historically, markets have adopted premium fiber and alternative routing precisely to avoid such latency spikes.
- Organizations with weak multi-region DR — Businesses that have not tested failover to other regions or multi-cloud alternatives are at highest operational risk. Past Azure incidents show that even when providers take corrective action, customer readiness is the decisive factor in recovery speed.
What enterprises should do now — practical, prioritized steps
- Immediately check Azure’s Service Health for your specific subscriptions and regions to confirm whether your resources are flagged. Follow any Microsoft guidance and subscribe to Azure status notifications for your subscriptions.
- Verify application-level dependencies: identify any services that require synchronous cross-region communication (databases, caches, identity endpoints) and determine whether they are using paths that transit the Middle East / Red Sea corridor.
- Execute tested failover procedures where possible: initiate region or cluster failovers for production workloads that can tolerate the downtime and have been stress-tested.
- For latency-sensitive workloads that cannot be failed over: consider temporarily shifting traffic to cached or edge delivery options (CDNs), or redirect important flows via alternative peering or transit providers if you have those contractual options.
- Monitor application logs and latency metrics aggressively; enable alerting for RTO/RPO thresholds and look for increased error rates that correlate with routing changes.
- For teams without a DR playbook, enact an emergency plan: prioritize critical services, contact Microsoft support and your account team, and document impacts for later post-incident review and possible financial relief considerations.
Microsoft’s response: strengths and limits
Strengths- Rapid notification to customers. Microsoft issued a public service health notice and committed to regular updates, which is the right early step for transparency and operational coordination.
- Large global backbone and routing options. As one of the hyperscale cloud providers, Microsoft has extensive cross-region fabric and peering relationships it can use to reroute traffic. That capability reduces the chance of total connectivity loss for many customers.
- Operational experience. Azure’s engineers have handled prior incidents and have playbooks for rebalancing and traffic engineering; that operational maturity mitigates worst-case scenarios. Historical analysis of Azure outages shows Microsoft uses rerouting and storage partition recovery techniques to limit service impact.
- Physical repair latency. Rerouting is a short- to medium-term fix; undersea repairs can take weeks or months depending on ship availability, permitting, and security constraints. Microsoft cannot repair third-party cables directly, so some impacts are outside their direct control.
- Cascading dependencies. Complex cloud architectures mean that a networking issue can surface as storage or identity problems for tenants; past incidents show these cascades can be hard to fully anticipate.
- Uneven customer impact and communication challenges. Some customers may see degraded service without clear localized messaging. Providers must balance targeted notifications with broad transparency to maintain trust; past Azure incidents included complaints about delay or mismatch between dashboard health states and real user experience.
Wider industry and geopolitical context
The Red Sea corridor has been a recurring point of fragility in recent years. Attacks on shipping, abandoned vessels, and regional tensions have all been implicated in some reported subsea cable damages; operators and governments have struggled at times to secure safe access for repairs. Industry analyses caution that the submarine cable ecosystem — long optimized for capacity and cost — lacks sufficient geographic redundancy in some chokepoints. The result: simultaneous hits to a small number of cables can have outsized global effects. (networkworld.com)Operators and hyperscalers are pursuing medium- and long-term engineering responses, including route diversity, private interconnect builds, and new fiber technologies (for example, hollow-core fibers in certain backbone applications) that may reduce latency and increase capacity when deployed at scale. Microsoft itself has invested in advanced fiber research and pilot deployments as part of a broader strategy to control more of its physical network stack — but those are long-lead efforts and will not solve immediate repair-time problems. Caveat on attribution: while some coverage connects cable damage to regional hostilities or specific incidents, attribution is often complicated and contested. Where a claim of deliberate attack appears, it should be treated carefully and cross-checked against reliable reporting and official investigations. (en.wikipedia.org)
Long-term takeaways for IT architects and WindowsForum readers
- Resilience must be designed, not hoped for. Dependence on a single region, single synchronous replication domain, or single transit path remains the most common cause of outsized operational risk. Multi-region designs, asynchronous replication, and well-documented failover plans materially reduce exposure.
- Measure your true risk profile. Run synthetic latency checks, dependency mapping, and chaos testing for critical workflows. Knowing which paths your traffic takes (and who controls them) gives you leverage in contractual and technical mitigation.
- Consider strategic private connectivity. For latency-sensitive or compliance-bound workloads, private interconnects that the organization can control or contractually guarantee offer stronger SLAs than public transit, though they come with cost and operational trade-offs.
- Stay pragmatic about alternatives. Satellite or temporary overland re-routes can buy time but are expensive and have performance limitations. They should be part of a contingency playbook but not the mainline solution.
- Engage with your cloud provider proactively. If your organization runs critical services on Azure, escalate via your account team to understand provider-side mitigations and to document impacts for potential service credits or contractual remedies.
What we still don’t know (and how to treat uncertain claims)
- Exact repair timelines for the affected Red Sea cables depend on ship availability, on-site safety and permitting; public reporting has shown repair durations ranging from days to months depending on circumstances. Firm repair ETA’s should be treated as provisional until cable operators or authorities confirm completion. (subseacables.net)
- Attribution for every cable cut — whether purely accidental (anchors, dragging vessels), due to infrastructure failure, or caused by hostile actions — is frequently disputed and may remain unresolved while investigations proceed. Treat attribution claims cautiously and seek multiple independent confirmations. (en.wikipedia.org)
The September 6 Azure advisory is a reminder that the physical layer of the internet still matters deeply to cloud reliability. Microsoft’s operational response — rerouting and active traffic engineering — is appropriate and likely to minimize worst-case outages. However, physical repairs, geopolitical constraints and the practical limits of alternate routing mean elevated latency and uneven performance are realistic in the near term for traffic traversing the Middle East and Red Sea corridors. Enterprises that rely on Azure should act now: check their Azure Service Health notifications, verify cross-region dependencies, execute tested failovers where appropriate, and reach out to Microsoft account and support teams if workloads are business-critical. The incident underscores a persistent lesson: cloud resilience is as much about network geography and physical infrastructure as it is about software design and platform SLAs. (datacenterdynamics.com)Source: CNBC https://www.cnbc.com/2025/09/06/microsoft-azure-cloud-computing-service-disrupted-red-sea-fiber-cuts.html
Source: Reuters https://www.reuters.com/world/middle-east/microsoft-says-azure-cloud-service-disrupted-by-fiber-cuts-red-sea-2025-09-06/
Source: Reuters https://www.reuters.com/world/middle-east/microsoft-says-azure-disrupted-by-fiber-cuts-red-sea-2025-09-06/
