Bit Locker Encryption : Not Ready
lucifer7O7
I am facing an issue while encrypting Bit Locker on 'HP Z4 G4' model, Device is getting encrypted but 'Bit Locker Readiness' status is showing "Not Ready".
Can anyone help me to resolve this issue as I tried to find the solution but no luck.
It is showing PCR7 Configuration 'Binding Not Possible'
An image from 'Bit Locker Encryption : Not Ready'. System details of an HP workstation showing BIOS and CPU info with PCR7 binding not possible.
The "Bit Locker Readiness" status showing as "Not Ready" on your HP Z4 G4 model could indicate that there are some issues with the configuration or compatibility of Bit Locker on your device. The error message you mentioned regarding PCR7 configuration "Binding Not Possible" suggests that there might be a problem with the system’s Trusted Platform Module (TPM).
Here are a few steps you can try to resolve this issue:
  1. Update BIOS and Firmware: Make sure that you have the latest BIOS and firmware updates installed on your HP Z4 G4. These updates often include bug fixes and improvements that can help resolve compatibility issues with Bit Locker. You can obtain the latest updates from the HP support website or through the HP Support...
  1. Update BIOS and Firmware: Make sure that you have the latest BIOS and firmware updates installed on your HP Z4 G4. These updates often include bug fixes and improvements that can help resolve compatibility issues with Bit Locker. You can obtain the latest updates from the HP support website or through the HP Support Assistant software.
  2. Verify TPM Compatibility: Bit Locker relies on the computer's TPM to provide encryption functionality. Verify that your HP Z4 G4 model has a compatible TPM version enabled. You can access the TPM settings in the BIOS/UEFI firmware settings. Check the HP documentation or contact HP support for information about TPM compatibility on your specific model.
  3. Initialize TPM: If the TPM is enabled but not properly initialized, it can cause issues with Bit Locker. To initialize the TPM, navigate to the TPM settings in the BIOS/UEFI firmware and select the option to clear the TPM. After clearing it, restart your computer and go back into the TPM settings. Then, select the option to initialize the TPM. Follow any on-screen prompts and restart your computer again.
  4. Enable TPM in BIOS/UEFI: If the TPM is disabled in the BIOS/UEFI firmware settings, enable it. Restart your computer and enter the BIOS/UEFI settings by pressing the designated key (usually F2 or Del) during startup. Look for the TPM settings and ensure it is enabled.
  5. Check Group Policy Settings: Bit Locker readiness can also be affected by Group Policy settings. Ensure that the necessary Group Policy settings are configured correctly. Open the Group Policy Editor (gpedit.msc) and navigate to "Computer Configuration" > "Administrative Templates" > "Windows Components" > "Bit Locker Drive Encryption." Check if any settings are configured that may be restricting the encryption process.
  6. Verify Hardware Compatibility: If the issue persists, check if your hardware meets the minimum requirements for using Bit Locker. Ensure that your HP Z4 G4 model includes a TPM module and that it is functioning correctly.
    If these steps do not help in resolving the issue, it is recommended to contact HP support for further assistance. They can provide you with specific guidance for your HP Z4 G4 model and maybe able to help diagnose any underlying issues causing the Bit Locker readiness status to be "Not Ready."
lucifer7O7
It is showing PCR7 Configuration Binding Not Possible
lucifer7O7
The error message you mentioned, "PCR7 Configuration Binding Not Possible," suggests that there might be an issue with the Trusted Platform Module (TPM) on your HP Z4 G4 model. The PCR7 (Platform Configuration Register 7) is a part of the TPM that is used by Bit Locker for encryption purposes. When it indicates that binding is not possible, it typically means that there is an incompatibility or misconfiguration with the TPM.
1. Update BIOS and TPM Firmware: Ensure that you have the latest BIOS and TPM firmware installed on your HP Z4 G4. Check the HP support website for updates specifically related to the TPM and follow the instructions provided to install them. Note that updating the BIOS and firmware carries some risk, so it's important to follow the instructions carefully and make sure you have a backup of your important data.
2. Clear TPM and Reinitialize: Clearing the TPM and reinitializing it may help resolve the issue. To do this, restart your computer and enter the BIOS/UEFI settings by pressing the designated key (usually F2 or Del) during startup. Look for the TPM settings and find the option to clear the TPM. Once cleared, restart your computer again, go back into the TPM settings, and select the option to initialize the TPM. Follow any on-screen prompts and restart your computer once more.
3. Check TPM Hardware: Verify that the TPM module is securely attached to the motherboard of your HP Z4 G4 model. If it is not properly connected or seated, it can cause issues with Bit Locker and the PCR7 configuration. Refer to the hardware documentation or contact HP support for guidance on how to check and reseat the TPM module if necessary.
4. Check Group Policy Settings: Open the Group Policy Editor (gpedit.msc) and navigate to "Computer Configuration" > "Administrative Templates" > "Windows Components" > "Bit Locker Drive Encryption." Check if any Group Policy settings are configured that could be causing the issue. If any settings are in place, you may need to modify or disable them temporarily to see if it resolves the problem.
5. Contact HP Support: If none of the above steps resolve the issue, it is recommended to contact HP support for further assistance. They have specific expertise and resources to help diagnose and troubleshoot TPM-related issues on your HP Z4 G4 model.
Remember to always backup your important data before making any changes to the BIOS, firmware, or TPM settings.
Is this a Hardware issue ?
Neemobeer
Windows Forum Team
From a powershell prompt run
Confirm-SecureBootUEFI it should return true then run and show the output of the following command
manage-bde -protectors -get $env:systemdrive
lucifer7O7
Thanks neemobeer :)
and sorry for the late reply as I was off from my desk.
Let me check this and share the output with you ASAP.
kaamdeir
The "PCR7 Configuration 'Binding Not Possible'" issue in BitLocker on the 'HP Z4 G4' model may be related to a Trusted Platform Module (TPM) setting. Ensure that TPM is enabled in BIOS and properly configured. Additionally, update BIOS and TPM firmware to the latest versions. If the problem persists, contact HP support for specific guidance on your device model.
