Windows 7 Boot up problem not fixed, yet stabalized.
JaxDrumm
Member
Problem signature:
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional information about the problem:
BCCode: 3b
BCP1: 00000000C0000005
BCP2: FFFFF96000082CB6
BCP3: FFFFF880081B8D90
BCP4: 0000000000000000
OS Version: 6_1_7601
Service Pack: 1_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\111614-53757-01.dmp
C:\Users\JaxDrumm\AppData\Local\Temp\WER-169682-0.sysdata.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
The Full Story Here: http://windowsforum.com/threads/a-problem-with-bootup-maybe.200864/
we need to read the actual files created when the machine blue screens. These are called dump files and are found in the minidump folder. You can find this folder in the main windows folder although if you cannot find it then your system needs configuring to create dump files. Change your settings to the ones shown below:
Go to Start and type in sysdm.cpl and press Enter
Click on the Advanced tab
Click on the Startup and Recovery Settings button
Ensure that Automatically restart is unchecked
Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box
Ensure that the Small Dump Directory is listed as %systemroot%\Minidump << where your .dmp files can be
found later.
Click and apply to exit the...
found later.
Click and apply to exit the dialogs, then reboot for the changes to take effect.
You'll need to wait until you bsod again before a dump file is created but when you do read the following thread:
This tells you how to post the information.
