hyddro
Hi, recently i have been experiencing some problems with my recently upgraded desktop... BSOD occurs almost every time i try to play a game or watch a video... very frustrating, this is the last entry I obtained after BSOD occurred.
I also uploaded my w7F file along with the file generated when the last BSOD occured...(under the folder 'dmp file after BSOD occured')... any help will be appreciated.
*EDIT* Sorry I forgot the CPU-Z and RAMMon reports... I attached them as well... thanks and sorry for any mistake.. it's my first tiem posting here thanks!
Problem signature:
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional information about the problem:
BCCode: 1000007e
BCP1: C0000005
BCP2: 8D8428DC
BCP3: 97B69C08
BCP4: 97B697E0
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\030514-21340-01.dmp
C:\Users\Gian\AppData\Local\Temp\WER-133614-0.sysdata.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
BugCheck 1000007E, {c0000005, 8d8428dc, 97b69c08, 97b697e0}
Probably caused by : lvrs.sys ( lvrs+c8dc )
Followup: MachineOwner
all your dump files point to the same driver lvrs.sys which is a Logicool Qcam driver:
lvrs.sys Fri Aug 19 10:23:28 2011: Please update...
lvrs.sys Fri Aug 19 10:23:28 2011: Please update:
http://www.logitech.com/en-us/support
BiosVersion = F2
BiosReleaseDate = 02/11/2011
Your bios has updates pending but please make sure you have the correct motherboard revision before downloading. You can find which version of motherboard you have by looking on the actual board itself.
http://www.gigabyte.com/products/product-page.aspx?pid=3756#bios
When you say upgraded desktop, what was actually upgraded? If it was the RAM try removing and see if bsod stops as it's quite feasible to purchase faulty RAM.
(RAM also popped up the dump file)
If you didn't upgrade test RAM using this app:
http://www.memtest.org/
nusb3hub.sys Fri Nov 19 01:34:11 2010: These are NEC USB3 drivers and the 2010 version is known for bsods. The actual chip is NEC D720200F1 and the latest driver I can find is here:
See how you go after changing the above I have to rush off to the docs but will be back later..
hyddro
thanks for the reply.. currently I am experiencing another issue.... After my last crash (which wasnt a BSOD, was just a crash in which the system became completely unresponsive and had to force a restart) windows wont boot... the screen shows the windows 7 logo and the 'starting windows' but it has been almost 30 min and it won't go away... :( any suggestions?
EDIT*
The system loaded after windows attempted to repair the problem (Which in the end said it couldnt repair it)... I will proceed to update and the do the things you told me to. thanks
EDIT2*
Forgot to answer your question.. I meant went from windows xp to windows 7. no hardware update though.. just software update.. my desktop is about 2.5 years old..
hyddro
I have updated my webcam but when I try updating my bios I get the following error (see attachment). Either the .exe or the flashspi gives me the error.
EDIT*
I also updated the USB3 drivers... I will soon run the RAM test and post the results
hyddro
I ran the memtest and this is the result... i didnt know how to run it so I decided to attached a picture... it kept running after saying **pass complete, no errors, pres Esc to exit** (see attachment)
Now I am trying to install my bios updates, atm i cant.. thanks
EDIT* uff so many edits... sorry about it.. i was able to update the bios using gigabyte's @bios software... I will use my pc at its fullest capacity and see if it crashes or get a BSOD.. For now.. thanks and hope for the best!!!!
Hey Hyddro,
your RAM looks ok and good job on the updating.. :) If you do get further bsods then please post the new dump files. Good luck.. :)
hyddro
Hi, i just wanted to inform you all that it's been 2 days since these updates and I have had no BSOD yet... this is a new record considering that I used to get 1 or 2 BSOD daily... This is a major victory ! :D Thanks Kemical you are a boss!! If I ever get a BSOD (which i doubt I will), i will post the dump files again... hopefully that wont happen.
Also, I think updating the USB3.0 drivers was the real solution (though hard to tell)... I noticed that after every BSOD my USB wireless adapter and my External HD wouldnt work unless I re-plugged them in. to their respective USB3.0 ports... (may actually tell you something right?).. anyways thanks and God bless you.
Excellent news! Much thanks on updating your thread as this helps a great deal for others finding solutions to their own issues.
hyddro
Hi, unfortunately yesterday while playing video games my computer froze and became unresponsive and had to force a reboot... :( i am planning on upgrading to windows 8.1 since school provides students with a free copy of the OS. Should I do that and see if it fixes the problem?
chances are that if it's a temp issue it will only return if you go with 8.1. Freezing whilst gaming is usually a classic sign of overheating so try monitoring your temps, both GPU and CPU to see if there's an issue..
hyddro
Hi kemical,
thanks for your help, much appreciated.
I will do so once I get back home (currently out of state)... is there any way I can open up a log after a freezing occurs just to see what caused it? Like in apple computers there is an app called 'console' which basically shows log entries... I onced used it to figure out a wifi card problem...is there anything similar in windows?
Have a nice one!
hyddro
I have upgraded to windows 8.1.. havent gotten any problems yet.. if i come across anything i will post it. Thanks
