Here is the sf diagnostic and alll of the slots on the cpuz are the same so i only posted the one. Rammon file couldnt be uploaded so here u go
Number of Memory Devices: 6 Total Physical Memory: 8182 MB (12288 MB) Total Available Physical Memory: 6101 MB Memory Load: 25%
Item | Slot #1 | Slot #2 | Slot #3 | Slot #4 | Slot #5 | Slot #6 |
[TD="class: value, width: 240"]Ram Type [/TD]
[TD="class: altvalue"]DDR3 [/TD]
[TD="class: value, width: 240"] Standard Name [/TD]
[TD="class: altvalue"]DDR3-1333 [/TD]
[TD="class: value, width: 240"] Module Name [/TD]
[TD="class: altvalue"]PC3-10600 [/TD]
[TD="class: value, width: 240"]Memory Capacity (MB) [/TD]
[TD="class: altvalue"]2048 [/TD]
[TD="class: value, width: 240"]Bus Clockspeed (Mhz) [/TD]
[TD="class: altvalue"]666.67 [/TD]
[TD="class: value, width: 240"]Jedec Manufacture Name [/TD]
[TD="class: altvalue"]Elpida [/TD]
[TD="class: value, width: 240"]Search Amazon.com [/TD]
[TD="class: altvalue"]Search! [/TD]
[TD="class: value, width: 240"]SPD Revision [/TD]
[TD="class: altvalue"]1.0 [/TD]
[TD="class: value, width: 240"]Registered [/TD]
[TD="class: altvalue"]No [/TD]
[TD="class: value, width: 240"]ECC [/TD]
[TD="class: value, width: 240"]DIMM Slot # [/TD]
[TD="class: altvalue"]1 [/TD]
[TD="class: altvalue"]2 [/TD]
[TD="class: altvalue"]3 [/TD]
[TD="class: altvalue"]4 [/TD]
[TD="class: altvalue"]5 [/TD]
[TD="class: altvalue"]6 [/TD]
[TD="class: value, width: 240"]Manufactured [/TD]
[TD="class: altvalue"]Year 0 [/TD]
[TD="class: value, width: 240"]Module Part # [/TD]
[TD="class: altvalue"]EBJ21UE8BDF0-DJ-F [/TD]
[TD="class: value, width: 240"]Module Revision [/TD]
[TD="class: altvalue"]0x3020 [/TD]
[TD="class: value, width: 240"]Module Serial # [/TD]
[TD="class: altvalue"]0x190E2A70 [/TD]
[TD="class: altvalue"]0x180E2A70 [/TD]
[TD="class: altvalue"]0xE00D2A6F [/TD]
[TD="class: altvalue"]0x230E2A71 [/TD]
[TD="class: altvalue"]0x200E2A70 [/TD]
[TD="class: altvalue"]0x1E0E2A71 [/TD]
[TD="class: value, width: 240"]Module Manufacturing Location [/TD]
[TD="class: altvalue"]75 [/TD]
[TD="class: value, width: 240"]# of Row Addressing Bits [/TD]
[TD="class: altvalue"]14 [/TD]
[TD="class: value, width: 240"]# of Column Addressing Bits [/TD]
[TD="class: altvalue"]10 [/TD]
[TD="class: value, width: 240"]# of Banks [/TD]
[TD="class: altvalue"]8 [/TD]
[TD="class: value, width: 240"]# of Ranks [/TD]
[TD="class: value, width: 240"]Device Width in Bits [/TD]
[TD="class: value, width: 240"]Bus Width in Bits [/TD]
[TD="class: altvalue"]64 [/TD]
[TD="class: value, width: 240"]Module Voltage [/TD]
[TD="class: altvalue"]1.5V [/TD]
[TD="class: value, width: 240"]CAS Latencies Supported [/TD]
[TD="class: altvalue"]6 7 8 9 [/TD]
[TD="class: value, width: 240"]Timings @ Max Frequency [/TD]
[TD="class: altvalue"]9-9-9-24 [/TD]
[TD="class: value, width: 240"] Minimum Clock Cycle Time, tCK (ns) [/TD]
[TD="class: altvalue"]1.500 [/TD]
[TD="class: value, width: 240"] Minimum CAS Latency Time, tAA (ns) [/TD]
[TD="class: altvalue"]13.125 [/TD]
[TD="class: value, width: 240"] Minimum RAS to CAS Delay, tRCD (ns) [/TD]
[TD="class: value, width: 240"] Minimum Row Precharge Time, tRP (ns) [/TD]
[TD="class: value, width: 240"] Minimum Active to Precharge Time, tRAS (ns) [/TD]
[TD="class: altvalue"]36.000 [/TD]
[TD="class: value, width: 240"] Minimum Row Active to Row Active Delay, tRRD (ns) [/TD]
[TD="class: altvalue"]6.000 [/TD]
[TD="class: value, width: 240"] Minimum Auto-Refresh to Active/Auto-Refresh Time, tRC (ns) [/TD]
[TD="class: altvalue"]49.125 [/TD]
[TD="class: value, width: 240"] Minimum Auto-Refresh to Active/Auto-Refresh Command Period, tRFC (ns) [/TD]
[TD="class: altvalue"]110.000 [/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[TD="class: value, width: 240"]DDR3 Specific SPD Attributes [/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[TD="class: value, width: 240"] Write Recovery Time, tWR (ns) [/TD]
[TD="class: altvalue"]15.000 [/TD]
[TD="class: value, width: 240"] Internal Write to Read Command Delay, tWTR (ns) [/TD]
[TD="class: altvalue"]7.500 [/TD]
[TD="class: value, width: 240"] Internal Read to Precharge Command Delay, tRTP (ns) [/TD]
[TD="class: value, width: 240"] Minimum Four Activate Window Delay, tFAW (ns) [/TD]
[TD="class: altvalue"]30.000 [/TD]
[TD="class: value, width: 240"] RZQ / 6 Supported [/TD]
[TD="class: altvalue"]Yes [/TD]
[TD="class: value, width: 240"] RZQ / 7 Supported [/TD]
[TD="class: value, width: 240"] DLL-Off Mode Supported [/TD]
[TD="class: value, width: 240"] Maximum Operating Temperature (C) [/TD]
[TD="class: altvalue"]95 [/TD]
[TD="class: value, width: 240"] Refresh Rate at Extended Operating Temperature Range [/TD]
[TD="class: altvalue"]1X [/TD]
[TD="class: value, width: 240"] Auto-self Refresh Supported [/TD]
[TD="class: value, width: 240"] On-die Thermal Sensor Readout Supported [/TD]
[TD="class: value, width: 240"] Partial Array Self Refresh Supported [/TD]
[TD="class: value, width: 240"] Thermal Sensor Present [/TD]
[TD="class: value, width: 240"] Non-standard SDRAM Type [/TD]
[TD="class: altvalue"]Standard Monolithic [/TD]
[TD="class: value, width: 240"] Module Type [/TD]
[TD="class: altvalue"]UDIMM [/TD]
[TD="class: value, width: 240"] Module Height (mm) [/TD]
[TD="class: altvalue"]30 [/TD]
[TD="class: value, width: 240"] Module Thickness (front), (mm) [/TD]
[TD="class: value, width: 240"] Module Thickness (back), (mm) [/TD]
[TD="class: value, width: 240"] Module Width (mm) [/TD]
[TD="class: altvalue"]133.5 [/TD]
[TD="class: value, width: 240"] Reference Raw Card Used [/TD]
[TD="class: altvalue"]Raw Card B Rev. 0 [/TD]
[TD="class: value, width: 240"] DRAM Manufacture ID [/TD]
[TD="class: altvalue"]766 [/TD]
[TD="class: value, width: 240"] # of DRAM Rows [/TD]
[TD="class: altvalue"]0 [/TD]
[TD="class: value, width: 240"] # of Registers [/TD]
[TD="class: value, width: 240"] Register Manufacturer [/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[TD="class: value, width: 240"] Register Type [/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[TD="class: value, width: 240"] Register Revision [/TD]
