Windows 7 Bsod Bcp4: Fffffa80060Cc000?
Rosefire
Problem signature:
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional information about the problem:
BCCode: fe
BCP1: 0000000000000008
BCP2: 0000000000000006
BCP3: 0000000000000006
BCP4: FFFFFA80060CC000
OS Version: 6_1_7601
Service Pack: 1_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\072712-16832-01.dmp
C:\Users\user\AppData\Local\Temp\WER-30388-0.sysdata.xml
I can find info on the first 3 BCP's, It has to do with hibernation on my laptop.
But cannot find anything that has to do with BCP4: FFFFFA80060CC000
Using Win 7 64 bit.
New at this, please go easy on me? LOL:confused:
Hi there, and welcome to the Forums. Could you please send the descriptive files?
Since your Bug Check Code is FE, this link might help. But it seems to be related to your USB devices.
Bug Check 0xFE: BUGCODE_USB_DRIVER
There is a BSOD forum in you want to check the sticky on how to ask for help. It will go through some of the possibly information you could supply.
