I bought a brand new ASUS laptop and it start giving me BSOD. The message prompted me to search for driver_power_State_failure with no success. I have uploaded the latest dmp file which I think is a minidump.
Yeah I thought the entry was odd, doesn't seem to be pointing at a real driver per-say, could be the dump analysis doesn't have enough information. pci.sys is a generic driver that comes with windows. Do you have any other dump files?
I do but I think not all are minidumps. Should I zip them all or just the minidump ones. The BSOD usually occur during boot ups on battery, or after wake up from sleep mode if it helps.
Hi, try going into advanced power settings and make sure 'Hybrid sleep' is enabled. I checked over the dump file and driver wise your in pretty good shapeish. There are one or two old drivers but I doubt they are involved with the issue. Hopefully the above solution should stop the issue.
