BSOD Help!!
I keep getting random BSOD have no idea they just start happening this past week. I re install windows to narrow down the drivers that could have cause the problem. I had over 19 since then 3 not to long ago.
Elmer
Hi jade4life and Welcome to The Forum.
Your latest dump file Memory_Corruption as the probable cause which usually indicates out of date Drivers, incorrectly configured Memory Timings, mismatched Memory or Bad Memory.
As a Priority:
Make sure your system is fully updated including SP1.
Download and install the correct system readiness tool prior to installing SP1.
System Update Readiness Tool for 32bit (x86)
System Update Readiness Tool for 64bit (x64)
Please see: How to ask for help with a BSOD problem Following Method 2:
Download
and run the SF Diagnostics Tool. Right click the SF Diag tool and select Run as Administrator before running. When the reports have been created, zip them up and attach to a post.
Download and run CPU-Z. Take screenshots**/snips of the CPU tab, Mainboard tab, Memory tab and all the slot #'s under the SPD tab.
Go to Post Reply, click on the Go Advanced button and attach the screenshots**/snips to your post for all the RAM experts to see by using the paper clip you will find on the top toolbar. Do not zip them up.
If screenshots, please crop.
I did check that page and everything is in the zip file
