BSOD Problems
Mark Sziklai
i keep getting BSOD and also random freezes i have a minidump file and will also add a dxdiag file to see if you can find a problems
cybercore
091910-21512-01.dmp
BugCheck 3B, {c0000005, fffff80002ebe905, fffff88007595fa0, 0}
Probably caused by : ntkrnlmp.exe ( nt!ExpInterlockedPopEntrySListFault16+0 )
SYSTEM_SERVICE_EXCEPTION (3b)
Bug Check 0x3B: SYSTEM_SERVICE_EXCEPTION
An exception happened while executing a system service routine
PROCESS_NAME: RelicCOHOWW.ex
FAILURE_BUCKET_ID: X64_0x3B_nt!ExpInterlockedPopEntrySListFault16+0
You may want to update these drivers, please do so:
AsIO.sys Mon Aug 03 10:03:16 2009
ASUS Probe
ASUSTeK Computer Inc.-Support-
jswpslwfx.sys Tue Apr 29 02:59:25 2008
D-Link USB Wireless Adapter Driver
D-Link - Tech Support Product List
Rt64win7.sys Thu Nov 05 16:15:41 2009
Realtek 8101E/8168/8169 NDIS 6.20 64-bit Driver
Realtek
091910-21512-01.dmp
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [F:\a\Minidump\091910-21512-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02e4b000 PsLoadedModuleList = 0xfffff800`03088e50
System Uptime: 0 days 5:24:00.868
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Followup: MachineOwner
2: kd> !analyze -v
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80002ebe905, Address of the exception record for the exception that caused the bugcheck
Arg3: fffff88007595fa0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - <Unable to get error code text>
FAULTING_IP:
fffff800`02ebe905 498b08          mov     rcx,qword ptr [r8]
CONTEXT:  fffff88007595fa0 -- (.cxr 0xfffff88007595fa0)
rax=0000001b110e0007 rbx=fffffa80039e5570 rcx=fffff88002d63ca0
rdx=00fffa8006e9ca91 rsi=fffff88002d63ca0 rdi=0000000000000000
rip=fffff80002ebe905 rsp=fffff88007596970 rbp=fffff8000304a880
 r8=00fffa8006e9ca90  r9=fffff80002e4b000 r10=fffff88002d63ca0
r11=fffff88007596aa0 r12=0000000000000008 r13=0000000000000000
r14=0000000000000002 r15=00000000e16d6553
iopl=0         nv up ei pl nz na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010206
nt!ExpInterlockedPopEntrySListFault16:
fffff800`02ebe905 498b08          mov     rcx,qword ptr [r8] ds:002b:00fffa80`06e9ca90=????????????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x3B
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff80002ebe905
STACK_TEXT:
fffff880`07596970 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!ExpInterlockedPopEntrySListFault16
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!ExpInterlockedPopEntrySListFault16+0
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4c1c44a9
STACK_COMMAND:  .cxr 0xfffff88007595fa0 ; kb
fffff800`00ba2000 fffff800`00bac000   kdcom    kdcom.dll    Tue Jul 14 04:31:07 2009 (4A5BDFDB)
fffff800`02e02000 fffff800`02e4b000   hal      hal.dll      Tue Jul 14 04:27:36 2009 (4A5BDF08)
fffff800`02e4b000 fffff800`03427000   nt       ntkrnlmp.exe Sat Jun 19 07:16:41 2010 (4C1C44A9)
fffff880`00c00000 fffff880`00ca4000   Wdf01000 Wdf01000.sys Tue Jul 14 02:22:07 2009 (4A5BC19F)
fffff880`00cb0000 fffff880`00cbd000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 04:29:09 2009 (4A5BDF65)
fffff880`00cbd000 fffff880`00cd1000   PSHED    PSHED.dll    Tue Jul 14 04:32:23 2009 (4A5BE027)
fffff880`00cd1000 fffff880`00d2f000   CLFS     CLFS.SYS     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00d2f000 fffff880`00def000   CI       CI.dll       Tue Jul 14 04:32:13 2009 (4A5BE01D)
fffff880`00def000 fffff880`00dfe000   WDFLDR   WDFLDR.SYS   Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00e00000 fffff880`00e1a000   mountmgr mountmgr.sys Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00e1a000 fffff880`00e23000   atapi    atapi.sys    Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`00e23000 fffff880`00e4d000   ataport  ataport.SYS  Tue Jul 14 02:19:52 2009 (4A5BC118)
fffff880`00e4d000 fffff880`00e58000   amdxata  amdxata.sys  Tue May 19 20:56:59 2009 (4A12F2EB)
fffff880`00e58000 fffff880`00ea4000   fltmgr   fltmgr.sys   Tue Jul 14 02:19:59 2009 (4A5BC11F)
fffff880`00eaf000 fffff880`00f06000   ACPI     ACPI.sys     Tue Jul 14 02:19:34 2009 (4A5BC106)
fffff880`00f06000 fffff880`00f0f000   WMILIB   WMILIB.SYS   Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00f0f000 fffff880`00f19000   msisadrv msisadrv.sys Tue Jul 14 02:19:26 2009 (4A5BC0FE)
fffff880`00f19000 fffff880`00f4c000   pci      pci.sys      Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00f4c000 fffff880`00f59000   vdrvroot vdrvroot.sys Tue Jul 14 03:01:31 2009 (4A5BCADB)
fffff880`00f59000 fffff880`00f6e000   partmgr  partmgr.sys  Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`00f6e000 fffff880`00f83000   volmgr   volmgr.sys   Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00f83000 fffff880`00fdf000   volmgrx  volmgrx.sys  Tue Jul 14 02:20:33 2009 (4A5BC141)
fffff880`00fdf000 fffff880`00fe6000   pciide   pciide.sys   Tue Jul 14 02:19:49 2009 (4A5BC115)
fffff880`00fe6000 fffff880`00ff6000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`01000000 fffff880`0103a000   rdyboost rdyboost.sys Tue Jul 14 02:34:34 2009 (4A5BC48A)
fffff880`0103a000 fffff880`01074000   fvevol   fvevol.sys   Sat Sep 26 05:34:26 2009 (4ABD7DB2)
fffff880`01074000 fffff880`010a4000   CLASSPNP CLASSPNP.SYS Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`010bb000 fffff880`010cf000   fileinfo fileinfo.sys Tue Jul 14 02:34:25 2009 (4A5BC481)
fffff880`010cf000 fffff880`0112d000   msrpc    msrpc.sys    Tue Jul 14 02:21:32 2009 (4A5BC17C)
fffff880`0112d000 fffff880`011a0000   cng      cng.sys      Tue Jul 14 02:49:40 2009 (4A5BC814)
fffff880`011a0000 fffff880`011ec000   volsnap  volsnap.sys  Tue Jul 14 02:20:08 2009 (4A5BC128)
fffff880`01200000 fffff880`01211000   pcw      pcw.sys      Tue Jul 14 02:19:27 2009 (4A5BC0FF)
fffff880`01211000 fffff880`0121b000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 02:19:45 2009 (4A5BC111)
fffff880`0121b000 fffff880`01231000   disk     disk.sys     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`01242000 fffff880`013e5000   Ntfs     Ntfs.sys     Tue Jul 14 02:20:47 2009 (4A5BC14F)
fffff880`013e5000 fffff880`013ff000   ksecdd   ksecdd.sys   Tue Jul 14 02:20:54 2009 (4A5BC156)
fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Tue Jul 14 02:21:46 2009 (4A5BC18A)
fffff880`01460000 fffff880`0148b000   ksecpkg  ksecpkg.sys  Fri Dec 11 08:03:32 2009 (4B21E0B4)
fffff880`0148b000 fffff880`0149d000   mup      mup.sys      Tue Jul 14 02:23:45 2009 (4A5BC201)
fffff880`0149d000 fffff880`014a6000   hwpolicy hwpolicy.sys Tue Jul 14 02:19:22 2009 (4A5BC0FA)
fffff880`014b6000 fffff880`015a8000   ndis     ndis.sys     Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`015a8000 fffff880`015f2000   fwpkclnt fwpkclnt.sys Tue Jul 14 02:21:08 2009 (4A5BC164)
fffff880`015f2000 fffff880`015fa000   spldr    spldr.sys    Mon May 11 19:56:27 2009 (4A0858BB)
fffff880`01601000 fffff880`017fe000   tcpip    tcpip.sys    Mon Jun 14 06:39:04 2010 (4C15A458)
fffff880`02a00000 fffff880`02a8a000   afd      afd.sys      Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`02a8a000 fffff880`02a93000   wfplwf   wfplwf.sys   Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`02a9b000 fffff880`02ac5000   cdrom    cdrom.sys    Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`02ac5000 fffff880`02af2000   MpFilter MpFilter.sys Sat Mar 20 07:58:08 2010 (4BA463F0)
fffff880`02af2000 fffff880`02afb000   Null     Null.SYS     Tue Jul 14 02:19:37 2009 (4A5BC109)
fffff880`02afb000 fffff880`02b02000   Beep     Beep.SYS     Tue Jul 14 03:00:13 2009 (4A5BCA8D)
fffff880`02b02000 fffff880`02b10000   vga      vga.sys      Tue Jul 14 02:38:47 2009 (4A5BC587)
fffff880`02b10000 fffff880`02b35000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 02:38:51 2009 (4A5BC58B)
fffff880`02b35000 fffff880`02b45000   watchdog watchdog.sys Tue Jul 14 02:37:35 2009 (4A5BC53F)
fffff880`02b45000 fffff880`02b4e000   RDPCDD   RDPCDD.sys   Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`02b4e000 fffff880`02b57000   rdpencdd rdpencdd.sys Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`02b57000 fffff880`02b60000   rdprefmp rdprefmp.sys Tue Jul 14 03:16:35 2009 (4A5BCE63)
fffff880`02b60000 fffff880`02b6b000   Msfs     Msfs.SYS     Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`02b6b000 fffff880`02b7c000   Npfs     Npfs.SYS     Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`02b7c000 fffff880`02b9a000   tdx      tdx.sys      Tue Jul 14 02:21:15 2009 (4A5BC16B)
fffff880`02b9a000 fffff880`02ba7000   TDI      TDI.SYS      Tue Jul 14 02:21:18 2009 (4A5BC16E)
fffff880`02ba7000 fffff880`02bec000   netbt    netbt.sys    Tue Jul 14 02:21:28 2009 (4A5BC178)
fffff880`03c00000 fffff880`03c1e000   dfsc     dfsc.sys     Tue Jul 14 02:23:44 2009 (4A5BC200)
fffff880`03c1e000 fffff880`03c2f000   blbdrive blbdrive.sys Tue Jul 14 02:35:59 2009 (4A5BC4DF)
fffff880`03c2f000 fffff880`03c35000   AsUpIO   AsUpIO.sys   Mon Jul 06 05:21:38 2009 (4A515FB2)
fffff880`03c35000 fffff880`03c3b000   AsIO     AsIO.sys     Mon Aug 03 10:03:16 2009 (4A768BB4)
fffff880`03c3b000 fffff880`03c61000   tunnel   tunnel.sys   Tue Jul 14 03:09:37 2009 (4A5BCCC1)
fffff880`03c61000 fffff880`03c76000   amdppm   amdppm.sys   Tue Jul 14 02:19:25 2009 (4A5BC0FD)
fffff880`03c76000 fffff880`03ca5000   ndiswan  ndiswan.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`03ca5000 fffff880`03cc6000   raspptp  raspptp.sys  Tue Jul 14 03:10:18 2009 (4A5BCCEA)
fffff880`03cd0000 fffff880`03cf6000   pacer    pacer.sys    Tue Jul 14 03:09:41 2009 (4A5BCCC5)
fffff880`03cf6000 fffff880`03d0c000   vwififlt vwififlt.sys Tue Jul 14 03:07:22 2009 (4A5BCC3A)
fffff880`03d0c000 fffff880`03d19000   jswpslwfx jswpslwfx.sys Tue Apr 29 02:59:25 2008 (481664DD)
fffff880`03d19000 fffff880`03d28000   netbios  netbios.sys  Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`03d28000 fffff880`03d45000   serial   serial.sys   Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`03d45000 fffff880`03d60000   wanarp   wanarp.sys   Tue Jul 14 03:10:21 2009 (4A5BCCED)
fffff880`03d60000 fffff880`03d74000   termdd   termdd.sys   Tue Jul 14 03:16:36 2009 (4A5BCE64)
fffff880`03d74000 fffff880`03dc5000   rdbss    rdbss.sys    Tue Jul 14 02:24:09 2009 (4A5BC219)
fffff880`03dc5000 fffff880`03dd1000   nsiproxy nsiproxy.sys Tue Jul 14 02:21:02 2009 (4A5BC15E)
fffff880`03dd1000 fffff880`03ddc000   mssmbios mssmbios.sys Tue Jul 14 02:31:10 2009 (4A5BC3BE)
fffff880`03ddc000 fffff880`03deb000   discache discache.sys Tue Jul 14 02:37:18 2009 (4A5BC52E)
fffff880`03e00000 fffff880`03e3e000   1394ohci 1394ohci.sys Tue Jul 14 03:07:12 2009 (4A5BCC30)
fffff880`03e3e000 fffff880`03e4e000   CompositeBus CompositeBus.sys Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`03e4e000 fffff880`03e64000   AgileVpn AgileVpn.sys Tue Jul 14 03:10:24 2009 (4A5BCCF0)
fffff880`03e64000 fffff880`03e88000   rasl2tp  rasl2tp.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`03e8e000 fffff880`03f82000   dxgkrnl  dxgkrnl.sys  Fri Oct 02 04:00:14 2009 (4AC5509E)
fffff880`03f82000 fffff880`03fc8000   dxgmms1  dxgmms1.sys  Tue Jul 14 02:38:32 2009 (4A5BC578)
fffff880`03fc8000 fffff880`03fec000   HDAudBus HDAudBus.sys Tue Jul 14 03:06:13 2009 (4A5BCBF5)
fffff880`03fec000 fffff880`03ffe000   dc3d     dc3d.sys     Thu Jul 01 13:07:45 2010 (4C2C68F1)
fffff880`04000000 fffff880`04056000   USBPORT  USBPORT.SYS  Tue Jul 14 03:06:31 2009 (4A5BCC07)
fffff880`04056000 fffff880`04067000   usbehci  usbehci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`04067000 fffff880`04073000   ndistapi ndistapi.sys Tue Jul 14 03:10:00 2009 (4A5BCCD8)
fffff880`04075000 fffff880`04165000   athrx    athrx.sys    Thu Jul 03 03:55:13 2008 (486C2371)
fffff880`04165000 fffff880`041b0000   Rt64win7 Rt64win7.sys Thu Nov 05 16:15:41 2009 (4AF2DE0D)
fffff880`041b0000 fffff880`041bb000   usbohci  usbohci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`041bb000 fffff880`041d8000   parport  parport.sys  Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`041d8000 fffff880`041e0000   ASACPI   ASACPI.sys   Thu Jul 16 06:31:29 2009 (4A5E9F11)
fffff880`041e0000 fffff880`041ec000   serenum  serenum.sys  Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`041ec000 fffff880`041f5000   wmiacpi  wmiacpi.sys  Tue Jul 14 02:31:02 2009 (4A5BC3B6)
fffff880`04600000 fffff880`0461b000   raspppoe raspppoe.sys Tue Jul 14 03:10:17 2009 (4A5BCCE9)
fffff880`0461b000 fffff880`04629000   hidusb   hidusb.sys   Tue Jul 14 03:06:22 2009 (4A5BCBFE)
fffff880`0462b000 fffff880`051fbf00   nvlddmkm nvlddmkm.sys Sat Sep 11 07:24:42 2010 (4C8B048A)
fffff880`051fc000 fffff880`051fd180   nvBridge nvBridge.kmd Sat Sep 11 07:21:30 2010 (4C8B03CA)
fffff880`05400000 fffff880`05422000   drmk     drmk.sys     Tue Jul 14 04:01:25 2009 (4A5BD8E5)
fffff880`05422000 fffff880`05427200   ksthunk  ksthunk.sys  Tue Jul 14 03:00:19 2009 (4A5BCA93)
fffff880`05428000 fffff880`0547c000   udfs     udfs.sys     Tue Jul 14 02:23:37 2009 (4A5BC1F9)
fffff880`0547c000 fffff880`05499000   usbccgp  usbccgp.sys  Tue Jul 14 03:06:45 2009 (4A5BCC15)
fffff880`05499000 fffff880`054b3000   rassstp  rassstp.sys  Tue Jul 14 03:10:25 2009 (4A5BCCF1)
fffff880`054b3000 fffff880`054c2000   kbdclass kbdclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`054c2000 fffff880`054d1000   mouclass mouclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`054d1000 fffff880`054d2480   swenum   swenum.sys   Tue Jul 14 03:00:18 2009 (4A5BCA92)
fffff880`054d3000 fffff880`05516000   ks       ks.sys       Tue Jul 14 03:00:31 2009 (4A5BCA9F)
fffff880`05516000 fffff880`05528000   umbus    umbus.sys    Tue Jul 14 03:06:56 2009 (4A5BCC20)
fffff880`05528000 fffff880`05582000   usbhub   usbhub.sys   Tue Jul 14 03:07:09 2009 (4A5BCC2D)
fffff880`05582000 fffff880`05597000   NDProxy  NDProxy.SYS  Tue Jul 14 03:10:05 2009 (4A5BCCDD)
fffff880`05597000 fffff880`055ba000   nvhda64v nvhda64v.sys Tue Jun 22 01:07:25 2010 (4C1FE29D)
fffff880`055ba000 fffff880`055f7000   portcls  portcls.sys  Tue Jul 14 03:06:27 2009 (4A5BCC03)
fffff880`06c00000 fffff880`06c13000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 02:21:51 2009 (4A5BC18F)
fffff880`06c13000 fffff880`06c1b080   HIDPARSE HIDPARSE.SYS Tue Jul 14 03:06:17 2009 (4A5BCBF9)
fffff880`06c1d000 fffff880`06db1000   viahduaa viahduaa.sys Fri Jul 10 06:07:01 2009 (4A56B055)
fffff880`06db1000 fffff880`06dbd000   Dxapi    Dxapi.sys    Tue Jul 14 02:38:28 2009 (4A5BC574)
fffff880`06dbd000 fffff880`06dd8000   USBSTOR  USBSTOR.SYS  Tue Jul 14 03:06:34 2009 (4A5BCC0A)
fffff880`06dd8000 fffff880`06dd9f00   USBD     USBD.SYS     Tue Jul 14 03:06:23 2009 (4A5BCBFF)
fffff880`06dda000 fffff880`06de8000   crashdmp crashdmp.sys Tue Jul 14 03:01:01 2009 (4A5BCABD)
fffff880`06de8000 fffff880`06df4000   dump_dumpata dump_dumpata.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`06df4000 fffff880`06dfd000   dump_atapi dump_atapi.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`07039000 fffff880`07052000   HIDCLASS HIDCLASS.SYS Tue Jul 14 03:06:21 2009 (4A5BCBFD)
fffff880`07052000 fffff880`07060000   kbdhid   kbdhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`07060000 fffff880`0706c000   NuidFltr NuidFltr.sys Tue Jun 29 11:54:32 2010 (4C29B4C8)
fffff880`0706c000 fffff880`07079000   mouhid   mouhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`07079000 fffff880`07089000   point64  point64.sys  Tue Jun 29 11:54:31 2010 (4C29B4C7)
fffff880`07089000 fffff880`07097000   monitor  monitor.sys  Tue Jul 14 02:38:52 2009 (4A5BC58C)
fffff880`07097000 fffff880`070ba000   luafv    luafv.sys    Tue Jul 14 02:26:13 2009 (4A5BC295)
fffff880`070ba000 fffff880`070db000   WudfPf   WudfPf.sys   Tue Jul 14 03:05:37 2009 (4A5BCBD1)
fffff880`070db000 fffff880`070f0000   lltdio   lltdio.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`070f0000 fffff880`07143000   nwifi    nwifi.sys    Tue Jul 14 03:07:23 2009 (4A5BCC3B)
fffff880`07143000 fffff880`07156000   ndisuio  ndisuio.sys  Tue Jul 14 03:09:25 2009 (4A5BCCB5)
fffff880`07156000 fffff880`0716e000   rspndr   rspndr.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`0716e000 fffff880`071a4000   fastfat  fastfat.SYS  Tue Jul 14 02:23:28 2009 (4A5BC1F0)
fffff880`07200000 fffff880`0722d000   mrxsmb   mrxsmb.sys   Sat Feb 27 09:52:19 2010 (4B88CF33)
fffff880`0722d000 fffff880`0727b000   mrxsmb10 mrxsmb10.sys Sat Feb 27 09:52:28 2010 (4B88CF3C)
fffff880`0727b000 fffff880`0729e000   mrxsmb20 mrxsmb20.sys Sat Feb 27 09:52:26 2010 (4B88CF3A)
fffff880`0729e000 fffff880`072a7000   cpuz133_x64 cpuz133_x64.sys Tue May 11 12:58:57 2010 (4BE92A61)
fffff880`072f6000 fffff880`073be000   HTTP     HTTP.sys     Tue Jul 14 02:22:16 2009 (4A5BC1A8)
fffff880`073be000 fffff880`073dc000   bowser   bowser.sys   Tue Jul 14 02:23:50 2009 (4A5BC206)
fffff880`073dc000 fffff880`073f4000   mpsdrv   mpsdrv.sys   Tue Jul 14 03:08:25 2009 (4A5BCC79)
fffff880`07800000 fffff880`07868000   srv2     srv2.sys     Tue Jun 22 06:20:47 2010 (4C202C0F)
fffff880`078a9000 fffff880`0794f000   peauth   peauth.sys   Tue Jul 14 04:01:19 2009 (4A5BD8DF)
fffff880`0794f000 fffff880`0795a000   secdrv   secdrv.SYS   Wed Sep 13 16:18:38 2006 (4508052E)
fffff880`0795a000 fffff880`07987000   srvnet   srvnet.sys   Tue Jun 22 06:20:32 2010 (4C202C00)
fffff880`07987000 fffff880`07999000   tcpipreg tcpipreg.sys Tue Jul 14 03:09:49 2009 (4A5BCCCD)
fffff880`07a23000 fffff880`07ab9000   srv      srv.sys      Tue Jun 22 06:21:11 2010 (4C202C27)
fffff880`07ab9000 fffff880`07ac9000   MpNWMon  MpNWMon.sys  Sat Mar 20 07:58:00 2010 (4BA463E8)
fffff880`07ac9000 fffff880`07afa000   WUDFRd   WUDFRd.sys   Tue Jul 14 03:06:06 2009 (4A5BCBEE)
fffff880`07b6b000 fffff880`07b76000   asyncmac asyncmac.sys Tue Jul 14 03:10:13 2009 (4A5BCCE5)
fffff960`00030000 fffff960`0033f000   win32k   win32k.sys   Sat Jun 19 07:31:59 2010 (4C1C483F)
fffff960`00520000 fffff960`0052a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`00610000 fffff960`00637000   cdd      cdd.dll      Wed May 19 22:48:26 2010 (4BF4408A)
fffff960`00800000 fffff960`00861000   ATMFD    ATMFD.DLL    Thu May 27 07:11:31 2010 (4BFDF0F3)
Unloaded modules:
fffff880`07afa000 fffff880`07b6b000   spsys.sys
    Checksum:  00000000
fffff880`014a6000 fffff880`014b4000   crashdmp.sys
    Checksum:  00000000
fffff880`01231000 fffff880`0123d000   dump_ataport
    Checksum:  00000000
fffff880`010a4000 fffff880`010ad000   dump_atapi.s
    Checksum:  00000000
fffff880`011ec000 fffff880`011ff000   dump_dumpfve
    Checksum:  00000000
Mark Sziklai
thanks i think this hasd fixed my problems, so if anyone else is getting these problems just go to your device manager and go through each one, and try and update them all. it worked for me.
cybercore
You are much welcome. : )
One way to update is through the device manager, fine if it worked in this case. However, a better method is to download drivers from the support sites, as the device manager doesn't always update with the right drivers.
ASUS Probe is notorious for stability issues, telling you this from my own experience with it, so I'm not sure you can update it with the device manager. If it causes any problems, update it too.
Mark Sziklai
ok thanks again, i have had one freeze up and thats it sofar so i will update the asus probe and see if that works. but i have had no bsod's anymore which is nice. well sofar you have helped me out the most and am very greatful for it as i have posted a few times before.
Mark Sziklai
well i just got a bsod so i gues none of that actually solved it, even though it helped. so i will attach the new minidumps
TorrentG
Banned
Uninstall your version of MSI Afterburner or similar to remove this very old driver:
RTCore64 RTCore64.sys Wed May 25 02:39:12 2005
After the reboot, delete this entire folder if still there:
E:\Program Files (x86)\MSI Afterburner\
Navigate to C:\Windows\SysWow64\drivers or E:\Windows\SysWow64\drivers (whichever is relevant) and delete
AsUpIO.sys
Reboot and run Ccleaner to clean the registry.
Then, must update the wireless driver from the manufacturer's site:
jswpslwfx jswpslwfx.sys Mon Apr 28 19:59:25 2008
Mark Sziklai
ok thanks, hopefully this will work
TorrentG
Banned
It will fix it for sure. The only way it won't is if you have defective RAM. So, keep your fingers crossed that it will. Those drivers I mentioned that needed update or removal will absolutely cause the 0x3b memory errors you're getting.
So as I said, it will fix it or you have bad RAM, 100% either/or.
Old wireless drivers are quite notorious for this.
Mark Sziklai
i don't think it is the RAM as i was using it in my 32-bit system. but yer my fingers are well and truely crossed as RAM isn't cheap anymore
Mark Sziklai
do you think i should uninstall the wireless software first as well?
TorrentG
Banned
Not necessary at all, but you can if you want to remove all the software and then only install the new driver by using the device manager.
It doesn't really matter either way, as long as you run the installer from D-Link's site.
Mark Sziklai
well i can find this, DWA 556 version 2.20 which is software and driver built together
TorrentG
Banned
Yep, cool. As long as the updates is something much more recent than the 2008, go for it.
Mark Sziklai
i'm not sure if this will be a problem or not but i have a message that poped up after installing the wireless adaptor and in reads:-
Windows requires a digitally signed driver
A recently installed program tried to install an unsisned driver. This version of requires all drivers to have a valid digital signature. Thedriver in unavailable and the program that uses this driver might not work correctly.
Uninstall the program or device that uses this driver and check the publisher's support website to get a digitally signed driver.
Driver: Atheros Security NDIS 6.0 Filter Driver
Service: JumpStart Wireless Filter Driver
Publisher: Atheros Communications, Inc.
Location C:\Windows\System...\jswpslwfx,sys
TorrentG
Banned
Sure it's a problem. Download the driver only from the manufacturer D-Link's site and also make sure it's a 64 bit driver as opposed to 32 bit.
Mark Sziklai
well you can't download just a driver from d-links website as it only comes as a software and driver package, but it has a driver folder within the setup folder of this download. but the problem is it doesn't have any specific 64-bit driver and just has win7 and vista drivers.
TorrentG
Banned
Which link are you downloading from? I'll have a look at it.
Mark Sziklai
Link Removed due to 404 Error
this is the product download page, i hope you have some luck finding it.
TorrentG
Banned
Yeah, the 220 version is fine on that link.
What you want to do to make sure it's installed well is to extract it to a separate folder. Then go in device manager and right click on the wireless adapter. Choose update software. Browse. Let me pick. Have disk. Browse.
Now find and double click on the netathrx.inf in the Windows 7 extracted folder. Hit ok then hit next and it will install.
