Areng Permana
help guys its my first post on win7 forums, and i'm sorry i needed some help.
i recently building a new system consisting of:
amd phenom x6 1055t 2.8ghz torbo core and cnc active
msi 870a fuzion bios 8/08/2010 deafult setting
2 x 3 team elite ddr 1333
seagate 500gb 7200rpm
wdc blue caviar 320gb
a gts 250 vga and a 8800GT (running only one and both bsod too)
corsair hx1000watt
the system semms working fine but every 2 days or so it getting random bsod. i run memtest 2 pass and its show no error. the tset its about 2 hour.
i need help very much. sorry for my bad english. i'm running win 7 64bithere is my dumpreport.View attachment dump.rar
Hello,
Start out by removing Riva Tuner, as it was blamed by the Verifier-enabled dumps. If you are overclocking at all, reset that first.
While not blamed directly or indirectly, Avira has been known to cause some BSODs. I recommend that you remove it with this tool: Link Removed due to 404 Error
MSE is the recommended replacement: Link Removed
Choose what you want to do. Definitely remove Riva Tuner, and depending on your loyalty to Avira, remove that too.
...Summary of the dumps
[font=lucida console]
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Debug session time: Wed Nov 24 15:24:25.265 2010 (UTC - 5:00)
System Uptime: 0 days 0:47:27.670
Probably caused by : ntkrnlmp.exe ( nt!ObpRemoveObjectRoutine+70 )...
Pleasr refer to this thread, it may solve your problem. This guy was experiencing the same issue!
Link Removed - Invalid URL
Hello,
PROCESS_NAME:  System
BUGCHECK_STR:  0x7E
DEFAULT_BUCKET_ID:  NULL_CLASS_PTR_DEREFERENCE
FAILURE_BUCKET_ID:  X64_0x7E_nt!ObpRemoveObjectRoutine+70
Debug session time: Wed Nov 24 14:30:32.020 2010 (UTC - 5:00)
System Uptime: 0 days 0:46:35.065
Probably caused by : memory_corruption ( nt!MiBadShareCount+4c )
BUGCHECK_STR:  0x4E_99
PROCESS_NAME:  plugin-contain
FAILURE_BUCKET_ID:  X64_0x4E_99_nt!MiBadShareCount+4c
Debug session time: Tue Nov 23 08:42:56.697 2010 (UTC - 5:00)
System Uptime: 0 days 2:26:57.102
Probably caused by : fileinfo.sys ( fileinfo!FIStreamGet+52 )
BUGCHECK_STR:  0x1E_c0000005
PROCESS_NAME:  svchost.exe
FAILURE_BUCKET_ID:  X64_0x1E_c0000005_fileinfo!FIStreamGet+52
Debug session time: Tue Nov 23 03:53:05.873 2010 (UTC - 5:00)
System Uptime: 0 days 18:03:15.003
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+2c2be )
BUGCHECK_STR:  0x1a_783
FAILURE_BUCKET_ID:  X64_0x1a_783_nt!_??_::FNODOBFM::_string_+2c2be
Debug session time: Mon Nov 22 09:46:22.603 2010 (UTC - 5:00)
System Uptime: 0 days 9:41:38.717
Probably caused by : dxgmms1.sys ( dxgmms1!VidMmQueryAllocationSizeInSystemMemory+7 )
BUGCHECK_STR:  0x3B
PROCESS_NAME:  L2.bin
FAILURE_BUCKET_ID:  X64_0x3B_dxgmms1!VidMmQueryAllocationSizeInSystemMemory+7
Debug session time: Mon Nov 22 00:02:21.482 2010 (UTC - 5:00)
System Uptime: 1 days 17:16:13.939
Probably caused by : memory_corruption ( nt!MiFindNodeOrParent+0 )
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID:  X64_0xA_nt!MiFindNodeOrParent+0
Debug session time: Thu Nov 18 13:56:18.097 2010 (UTC - 5:00)
System Uptime: 0 days 0:01:11.533
*** WARNING: Unable to verify timestamp for RivaTuner64.sys
*** ERROR: Module load completed but symbols could not be loaded for RivaTuner64.sys
Probably caused by : RivaTuner64.sys ( RivaTuner64+1fc1 )
BUGCHECK_STR:  0xc4_f6
DEFAULT_BUCKET_ID:  VERIFIER_ENABLED_VISTA_MINIDUMP
PROCESS_NAME:  RivaTuner.exe
FAILURE_BUCKET_ID:  X64_0xc4_f6_VRF_RivaTuner64+1fc1
Debug session time: Thu Nov 18 13:54:28.211 2010 (UTC - 5:00)
System Uptime: 0 days 0:01:07.647
Debug session time: Thu Nov 18 13:52:18.552 2010 (UTC - 5:00)
System Uptime: 0 days 0:00:56.988
Debug session time: Thu Nov 18 12:44:01.272 2010 (UTC - 5:00)
System Uptime: 0 days 0:19:44.708
Probably caused by : dxgmms1.sys ( dxgmms1!VIDMM_SEGMENT::SafeUnlockPages+31 )
BUGCHECK_STR:  0x4E_7
FAILURE_BUCKET_ID:  X64_0x4E_7_dxgmms1!VIDMM_SEGMENT::SafeUnlockPages+31
Debug session time: Thu Nov 18 12:21:33.941 2010 (UTC - 5:00)
System Uptime: 0 days 4:24:04.986
Debug session time: Thu Nov 18 07:55:49.971 2010 (UTC - 5:00)
System Uptime: 1 days 5:02:45.100
Probably caused by : memory_corruption ( nt!MiAddViewsForSection+11f )
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID:  X64_0xA_nt!MiAddViewsForSection+11f
[/font]
Hello,
[FONT=lucida console]
BUGCHECK_STR:  0x7E
BUGCHECK_STR:  0x3B
BUGCHECK_STR:  0xA
BUGCHECK_STR:  0xA
[/FONT]
i have uninstaled riva tuner already. when i use driver debugger (ms verifier) it indeed show the error. but its still crashing. i'm updating driver all of it and bios two days ago and stil crashing. all in my dump report. in case there is another blue screen i upload the new dump again. right now i will try your suggestion removing avira. i'll try to update as fast as i can. and thank you very much for your fast respond ;). i'm so desperate to make my new system stable.
i've read it the only thing i havent do is check disk. i try that now and see what happend . ty so much
PS: that l2.bin is my lineage2 online game. it crashing ussually when i exit the game...-.-''
Be sure to follow suggestions above. Ensure that the clocks are all set default as recommended. Also, uninstall ASTRA:
ASTRA64.sys Wed May 04 06:33:22 2005
Sysinfo Lab
If you're still getting crashes after the updates, run memtest overnight:
RAM - Test with Memtest86+ - Windows 7 Forums
Loading Dump File [F:\a\Minidump\D M P\112510-20295-01.dmp]
BugCheck 4E, {99, 1178e3, 0, 1183e3}
Followup: MachineOwner
PFN_LIST_CORRUPT (4e)
Typically caused by drivers passing bad memory descriptor lists (ie: calling
MmUnlockPages twice with the same list, etc).  If a kernel debugger is
available get the stack trace.
Arguments:
Arg1: 0000000000000099, A PTE or PFN is corrupt
Arg2: 00000000001178e3, page frame number
Arg3: 0000000000000000, current page state
Arg4: 00000000001183e3, 0
Debugging Details:
CUSTOMER_CRASH_COUNT:  1
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from fffff80002b6032c to fffff80002ad1f00
STACK_TEXT:
fffff880`0a6b1f88 fffff800`02b6032c : 00000000`0000004e 00000000`00000099 00000000`001178e3 00000000`00000000 : nt!KeBugCheckEx
fffff880`0a6b1f90 fffff800`02a87557 : 00000000`00000000 fffff680`003f7ea8 00000000`00000002 00000000`00000001 : nt!MiBadShareCount+0x4c
fffff880`0a6b1fd0 fffff800`02aa6493 : fffffa80`06e007e0 fffff700`00002f68 0000007f`fffffff8 fffff8a0`0367f7a8 : nt! ?? ::FNODOBFM::`string'+0x322be
fffff880`0a6b2060 fffff800`02aa4eee : fffffa80`06e007e0 fffffa80`00000000 fffff8a0`000020c0 fffff880`00000005 : nt!MiDeleteAddressesInWorkingSet+0x307
fffff880`0a6b2910 fffff800`02db47af : fffff8a0`02df75c0 fffff880`0a6b2c20 00000000`00000000 fffffa80`056383c0 : nt!MmCleanProcessAddressSpace+0x96
fffff880`0a6b2960 fffff800`02d8eb3d : 00000000`c0000005 00000000`c0000001 00000000`7ef95000 fffffa80`0556c790 : nt!PspExitThread+0x47f
fffff880`0a6b2a30 fffff800`02aaea43 : 00000000`00000100 fffffa80`05638480 00000000`00000001 fffff800`02ad925d : nt!PsExitSpecialApc+0x1d
fffff880`0a6b2a60 fffff800`02aaee80 : 00000000`00000000 fffff880`0a6b2ae0 fffff800`02d8f710 00000000`00000001 : nt!KiDeliverApc+0x2eb
fffff880`0a6b2ae0 fffff800`02ad11f7 : fffffa80`056383c0 00000000`00000728 00000000`00000000 fffffa80`08a0c1f0 : nt!KiInitiateUserApc+0x70
fffff880`0a6b2c20 00000000`73c42dd9 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExit+0x9c
00000000`0377ed08 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x73c42dd9
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`02b6032c cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt!MiBadShareCount+4c
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc600
IMAGE_NAME:  memory_corruption
fffff880`04200000 fffff880`0423e000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00f7f000 fffff880`00fd6000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02cad000 fffff880`02d37000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`053a4000 fffff880`053ba000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`0426f000 fffff880`04284000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`010d3000 fffff880`010de000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`06270000 fffff880`06278000   ASTRA64  ASTRA64.sys  Wed May 04 06:33:22 2005 (4278A4F2)
fffff880`00dba000 fffff880`00dc3000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00dc3000 fffff880`00ded000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`01480000 fffff880`01488000   AtiPcie  AtiPcie.sys  Tue May 05 11:00:22 2009 (4A005486)
fffff880`083cd000 fffff880`083ea000   avgntflt avgntflt.sys Fri May 07 12:05:34 2010 (4BE43A4E)
fffff880`00c1e000 fffff880`00c40000   avipbb   avipbb.sys   Mon Feb 22 05:08:50 2010 (4B8257B2)
fffff880`013d0000 fffff880`013d7000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`02c83000 fffff880`02c94000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`06388000 fffff880`063a6000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`006f0000 fffff960`00717000   cdd      cdd.dll      Mon Jul 13 21:25:40 2009 (4A5BDE94)
fffff880`014be000 fffff880`014e8000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`03c46000 fffff880`03d9f000   cfosspeed6 cfosspeed6.sys Thu Nov 18 11:44:24 2010 (4CE557E8)
fffff880`00ce0000 fffff880`00da0000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01450000 fffff880`01480000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c82000 fffff880`00ce0000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`014ec000 fffff880`0155f000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`05394000 fffff880`053a4000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`08329000 fffff880`08337000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`02c00000 fffff880`02c83000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`03c26000 fffff880`03c44000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`03c17000 fffff880`03c26000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`0143a000 fffff880`01450000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`082f5000 fffff880`08317000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`08343000 fffff880`0834c000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`08337000 fffff880`08343000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0834c000 fffff880`0835f000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`0831d000 fffff880`08329000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`04298000 fffff880`0438c000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`0438c000 fffff880`043d2000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`0112a000 fffff880`0113e000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`010de000 fffff880`0112a000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01570000 fffff880`0157a000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01400000 fffff880`0143a000   fvevol   fvevol.sys   Mon Jul 13 19:22:15 2009 (4A5BC1A7)
fffff880`01600000 fffff880`0164a000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`02a17000 fffff800`02a60000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`0532e000 fffff880`05352000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`0836d000 fffff880`08386000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`08386000 fffff880`0838e080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`0835f000 fffff880`0836d000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`062c0000 fffff880`06388000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`01662000 fffff880`0166b000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`061e4000 fffff880`061ef000   HydraPGU_EEP HydraPGU_EEP.sys Tue Oct 05 07:15:20 2010 (4CAB08C8)
fffff880`04284000 fffff880`04298000   HydraWDDM HydraWDDM.sys Sun Oct 24 12:35:58 2010 (4CC4606E)
fffff880`0535e000 fffff880`0537c000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0537c000 fffff880`0538b000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00bc6000 fffff800`00bd0000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`064de000 fffff880`06521000   ks       ks.sys       Mon Jul 13 20:00:31 2009 (4A5BCA9F)
fffff880`013ad000 fffff880`013c7000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`017bf000 fffff880`017ea000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`08317000 fffff880`0831c200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`08021000 fffff880`08036000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`083aa000 fffff880`083cd000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c61000 fffff880`00c6e000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`0839c000 fffff880`083aa000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`064cd000 fffff880`064dc000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0838f000 fffff880`0839c000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00da0000 fffff880`00dba000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`063a6000 fffff880`063be000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`063be000 fffff880`063ea000   mrxsmb   mrxsmb.sys   Mon Jul 13 19:23:59 2009 (4A5BC20F)
fffff880`06200000 fffff880`0624d000   mrxsmb10 mrxsmb10.sys Mon Jul 13 19:24:08 2009 (4A5BC218)
fffff880`0624d000 fffff880`06270000   mrxsmb20 mrxsmb20.sys Mon Jul 13 19:24:05 2009 (4A5BC215)
fffff880`011ca000 fffff880`011d5000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fdf000 fffff880`00fe9000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`0113e000 fffff880`0119c000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`03c0c000 fffff880`03c17000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`017ea000 fffff880`017fc000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01010000 fffff880`0109c000   mv91xx   mv91xx.sys   Wed Jun 30 21:55:14 2010 (4C2BF582)
fffff880`010cb000 fffff880`010d3000   mvxxmm   mvxxmm.sys   Wed Jun 30 21:54:57 2010 (4C2BF571)
fffff880`0166d000 fffff880`0175f000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`053de000 fffff880`053ea000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`0643d000 fffff880`0646c000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`065a5000 fffff880`065ba000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`03d9f000 fffff880`03dae000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02d37000 fffff880`02d7c000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`0175f000 fffff880`017bf000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`011d5000 fffff880`011e6000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03c00000 fffff880`03c0c000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02a60000 fffff800`0303d000   nt       ntkrnlmp.exe Mon Jul 13 19:40:48 2009 (4A5BC600)
fffff880`0120a000 fffff880`013ad000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`013c7000 fffff880`013d0000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`06533000 fffff880`0654b000   nusb3hub nusb3hub.sys Thu Apr 22 21:34:35 2010 (4BD0F92B)
fffff880`0527d000 fffff880`052ad000   nusb3xhc nusb3xhc.sys Thu Apr 22 21:34:36 2010 (4BD0F92C)
fffff880`061e2000 fffff880`061e3180   nvBridge nvBridge.kmd Sat Oct 16 13:06:16 2010 (4CB9DB88)
fffff880`05608000 fffff880`061e1a80   nvlddmkm nvlddmkm.sys Sat Oct 16 13:12:46 2010 (4CB9DD0E)
fffff880`02d85000 fffff880`02dab000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00e40000 fffff880`00e55000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00e00000 fffff880`00e33000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00fe9000 fffff880`00ff0000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00ff0000 fffff880`01000000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0155f000 fffff880`01570000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`094fe000 fffff880`095a4000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`082b8000 fffff880`082f5000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c6e000 fffff880`00c82000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`053ba000 fffff880`053de000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0646c000 fffff880`06487000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`06487000 fffff880`064a8000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`064a8000 fffff880`064c2000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02dab000 fffff880`02dfc000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`064c2000 fffff880`064cd000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`013f5000 fffff880`013fe000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01200000 fffff880`01209000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`011c1000 fffff880`011ca000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`015c6000 fffff880`01600000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`08036000 fffff880`0804e000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`05226000 fffff880`0527d000   Rt64win7 Rt64win7.sys Fri Sep 03 01:58:32 2010 (4C808E88)
fffff880`08071000 fffff880`082b7e00   RTKVHD64 RTKVHD64.sys Tue Jun 08 05:08:08 2010 (4C0E0878)
fffff880`0109c000 fffff880`010cb000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`095a4000 fffff880`095af000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`05352000 fffff880`0535e000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`03dae000 fffff880`03dcb000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`0165a000 fffff880`01662000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`0a8e0000 fffff880`0a951000   spsys    spsys.sys    Mon May 11 13:20:58 2009 (4A085E7A)
fffff880`09467000 fffff880`094fd000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`09400000 fffff880`09467000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`095af000 fffff880`095dc000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`064dc000 fffff880`064dd480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01800000 fffff880`019fd000   tcpip    tcpip.sys    Mon Jul 13 19:25:34 2009 (4A5BC26E)
fffff880`095dc000 fffff880`095ee000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`011e6000 fffff880`011f3000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`00c00000 fffff880`00c1e000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`03de6000 fffff880`03dfa000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`005d0000 fffff960`005da000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`04249000 fffff880`0426f000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`06521000 fffff880`06533000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`052ad000 fffff880`052aef00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`0531d000 fffff880`0532e000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`052af000 fffff880`052bc000   usbfilter usbfilter.sys Tue Dec 22 03:26:22 2009 (4B3082AE)
fffff880`0654b000 fffff880`065a5000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`052bc000 fffff880`052c7000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`052c7000 fffff880`0531d000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`00e33000 fffff880`00e40000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`013d7000 fffff880`013e5000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`0119c000 fffff880`011c1000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`0164a000 fffff880`0165a000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00e55000 fffff880`00e6a000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e6a000 fffff880`00ec6000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`0157a000 fffff880`015c6000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`03dcb000 fffff880`03de6000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`013e5000 fffff880`013f5000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00ecc000 fffff880`00f70000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f70000 fffff880`00f7f000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02d7c000 fffff880`02d85000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00030000 fffff960`0033f000   win32k   win32k.sys   Mon Jul 13 19:40:16 2009 (4A5BC5E0)
fffff880`0538b000 fffff880`05394000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00fd6000 fffff880`00fdf000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`08000000 fffff880`08021000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`01488000 fffff880`01496000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01496000 fffff880`014a2000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`014a2000 fffff880`014ab000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`014ab000 fffff880`014be000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Sysinfo Lab
Arguments:
Debugging Details:
CURRENT_IRQL:  2
STACK_TEXT:
STACK_COMMAND:  kb
FOLLOWUP_IP:
MODULE_NAME: nt
Unloaded modules:
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000C000
    Checksum:  00000000
    ImageSize:  00009000
    Checksum:  00000000
    ImageSize:  00013000
i will do as you say sir. i uninstaled astra32 now. i'll keep u informed my progress. and right now i switch pus from corsair hx1000w with fsp kingcraft 1000w. i'll inform if there is another bluescreen. tq for forum fast respond ( actually wow...this forum member is soo good ;))
The RAM is defective or set unwell in the bios.
Please post a screen shot of the SPD and Memory tabs of free software called CPU-Z.
Test overnight with Memtest86+ until errors show, at least 8-10 passes. When they do, contact the company and tell them your findings so they can replace the RAM or the entire machine, depending on how their warranty practices are.
Show them this thread here if needed, and how it is for sure faulty RAM here.
i will do the test again sir . i gonna test 8-10 passes
INFO: another crash just in :(
here is the dump. it crash when i exit my game
View attachment 112610-16598-01.dmp
The last crash before this one that you had was involving the FAT file system. Since you don't even have any FAT volumes, that means that the memory is defective. I've seen it before in a few instances and replacing the RAM has always solved this type of crash.
Anyhow, I would absolutely uninstall cFosSpeed:
That software is not stable by any means. There is nothing to say it is causing any crashes, but like I said, it is not stable.
Okay sir , i'll try. if tonight memtest shows error for 10 pases. i gonna banged the shops sales hard for giving me this memory :rolleyes:. ty four your atention. i'll update my process
You're welcome. ANd one further thing:
Google can not find anything on these drivers. They are likely malware. Scan the machine with Malwarebyte after unpdating definitions. Let it remove all it finds.
But I still am fairly sure that the RAM is defective, as has been in all the FAT volume 0x23 stop cases.
You're welcome.
CACHE_MANAGER (34)
    See the comment for FAT_FILE_SYSTEM (0x23)
Arguments:
Arg1: 0000000000050830
Arg2: fffff88003161488
Arg3: fffff88003160ce0
Arg4: fffff80002add523
Debugging Details:
:confused: dear sir i have test the ram for 16 pases.and no errors found. but agonna rma all my new hardware in case there is error. i gonna send the proccie, mobos, and the ram. i'll inform you if there any bsod since thenb-(
problem solved, the ram is defective. also the GPU is unstable. i RMA my RAm and it goes so fine after that. thank you windows 7 forums u guys here are truly expert:redface:
