Gerard Ryant
The BSOD will came randomly and i don't know how to fix it. Here are the W7F File.
C: drive only has about 7% free space. Windows likes 15% free space in order to perform stuff "behind the scenes" without adversely affecting the system's performance. Please free up 15% on ALL hard drives (you can get away with 10% on larger drives and won't notice a large performance penalty)
This device has a problem:
SBRE ROOT\LEGACY_SBRE\0000 This device is not present, is not working properly, or does not have all its drivers installed.
Please locate this device in Device Manager (you may have to enable the viewing of hidden devices) and un-install it by right clicking and selecting "Un-install:
Please update these older drivers. Links are included to assist in looking up the source of the drivers. If unable...
YOU MUST UPDATE THIS DRIVER:
SFEP.sys Fri Aug 3 01:35:53 2007 (46B2BEB9)
Sony Firmware Extension Parser driver - 2007 version has BSOD issues in Win7
btwl2cap.sys Fri Apr 3 20:28:45 2009 (49D6A9BD)
Broadcom Bluetooth L2CAP Servicen
ArcSoftKsUFilter.sys Mon May 25 04:27:31 2009 (4A1A5673)
ArcSoft Magic-i Visual Effect
btusbflt.sys Tue Jun 9 17:46:26 2009 (4A2ED832)
Widcomm Bluetooth USB Filter by Broadcom
risdsne64.sys Wed Jul 1 00:50:14 2009 (4A4AEB06)
RICOH Memory Stick driver
If all of this doesn't stop the BSOD's, please run these free hardware diagnostics (because the memory dump points to a hardware problem with the hard drive): Link Removed. Let us know the results and we can move on from there.
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Thu Apr  4 22:41:23.087 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040513-35053-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].18044.amd64fre.win7sp1_gdr.130104-1431
System Uptime:[B]0 days 0:03:43.148[/B]
Probably caused by :[B]hardware_disk[/B]
BugCheck [B]1000007E, {ffffffffc0000006, fffff80003a5b26b, fffff8800956f828, fffff8800956f080}[/B]
BugCheck Info: [B]Link Removed[/B]
Arguments:
Arg1: ffffffffc0000006, The exception code that was not handled
Arg2: fffff80003a5b26b, The address that the exception occurred at
Arg3: fffff8800956f828, Exception Record Address
Arg4: fffff8800956f080, Context Record Address
PROCESS_NAME:  System
BUGCHECK_STR:  0x7E
FAILURE_BUCKET_ID: [B]X64_0x7E_IMAGE_hardware_disk[/B]
CPUID:        "Intel(R) Core(TM) i5 CPU       M 520  @ 2.40GHz"
MaxSpeed:     2400
CurrentSpeed: [B]2394[/B]
  BIOS Version                  R0300Y8
  BIOS Release Date             07/20/2010
  Manufacturer                  Sony Corporation
  Product Name                  VPCEA16FG
[/font]
3rd Party Drivers:
[COLOR=RED][B]SFEP.sys                    Fri Aug  3 01:35:53 2007 (46B2BEB9)[/B][/COLOR]
[COLOR=RED][B]btwl2cap.sys                Fri Apr  3 20:28:45 2009 (49D6A9BD)[/B][/COLOR]
[COLOR=RED][B]ArcSoftKsUFilter.sys        Mon May 25 04:27:31 2009 (4A1A5673)[/B][/COLOR]
[COLOR=RED][B]btusbflt.sys                Tue Jun  9 17:46:26 2009 (4A2ED832)[/B][/COLOR]
[COLOR=RED][B]risdsne64.sys               Wed Jul  1 00:50:14 2009 (4A4AEB06)[/B][/COLOR]
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
btwavdt.sys                 Tue Aug 25 16:35:17 2009 (4A944B05)
btwaudio.sys                Tue Aug 25 16:36:15 2009 (4A944B3F)
btwrchid.sys                Tue Aug 25 16:36:32 2009 (4A944B50)
HECIx64.sys                 Thu Sep 17 15:54:16 2009 (4AB293E8)
SynTP.sys                   Fri Oct  9 19:51:45 2009 (4ACFCC91)
rimssne64.sys               Fri Oct 16 06:49:46 2009 (4AD84FCA)
PxHlpa64.sys                Tue Oct 20 14:08:42 2009 (4ADDFCAA)
Impcd.sys                   Mon Oct 26 16:39:41 2009 (4AE6090D)
iaStor.sys                  Fri Nov 20 18:09:41 2009 (4B0721B5)
RTKVHD64.sys                Mon Nov 30 07:39:43 2009 (4B13BD0F)
RtHDMIVX.sys                Wed Dec  2 01:33:25 2009 (4B160A35)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
WmXlCore.sys                Tue Apr 27 16:09:26 2010 (4BD74476)
WmBEnum.sys                 Tue Apr 27 16:10:19 2010 (4BD744AB)
NETwNs64.sys                Wed Jul 14 07:42:54 2010 (4C3DA2BE)
atikmpag.sys                Mon Sep 20 21:20:30 2010 (4C98085E)
atikmdag.sys                Mon Sep 20 21:50:23 2010 (4C980F5F)
GEARAspiWDM.sys             Thu May  3 15:56:17 2012 (4FA2E2E1)
MpFilter.sys                Wed Oct 31 18:43:06 2012 (5091A97A)
[/font]
Sony Firmware Extension Parser still dates from 2007.
It must be updated as it's a known cause of BSOD's in these systems.
No new memory dumps in the uploaded files.
