Windows 7 BSOD When using HRD (Ham Radio Deluxe)
kse615
Hello Everyone and Thank you so much for reading,
I am an Amateur Radio operator and I have the ability to control my radio from my computer... When I actually run the program (Ham Radio Deluxe) and connect between my radio, it works for a while.. then of course.. BSOD!.. I'm not sure why..
Attached are some DMP files (Two files only 10 minutes apart from two attempts at running the program)
and a screenshot of all my systems info via CPU-Z
Thanks and a happy new year to all!
Henry N2HJS
It seems there was an issue retrieving the files you uploaded. Could you please try uploading them again so that I can analyze the DMP files and the CPU-Z screenshot to help identify the cause of the BSOD you're experiencing? Thank you!
