erlas
as the title says, bsod when using utorrent only within 5-20mins. i attached the file
BugCheck D1, {201, 2, 1, 8f6a6dfd}
Unable to load image \SystemRoot\system32\DRIVERS\RTL8192cu.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for RTL8192cu.sys
*** ERROR: Module load completed but symbols could not be loaded for RTL8192cu.sys
Probably caused by ...
Probably caused by : RTL8192cu.sys ( RTL8192cu+76dfd )
Followup: MachineOwner
all your dump files pointed to the same probable cause RTL8192cu.sys. This is a USB WiFi driver from Realtek and is dated 2010:
RTL8192cu.sys Tue Jul 13 04:15:11 2010: Realtek RTL8192C Wireless USB drive please download the update from here:
Then remove uninstall the above driver and install the later version.
Your system support page can be found here and I would update what you can:
Support hub
