PauloBR
Hi, I'm new to this forum.
I have Windows 10 mobile build 10149 installed on my Lumia 925. This build is pretty stable, but I'm facing one major issue...
Store (beta) has several apps that are simply stuck, frozen, in a limbo! Those apps are shown on the Downloads list, but once the downloads are completed, installation stop with an error.
Many of those apps are updates to apps already installed on the phone. Problem is that once a installation stops with an error on the beta store, I can't use that app anymore. Instead of opening the app, Windows opens the beta store and it all begins again...
I can't use several apps that are important for me, like HERE Maps, my bank app, and others.
Best regards,
Jimbo22
Build 10162 is for PCs, not for phones.
Ah crap....I completely missed that one bud....I'm having troubles of my own getting that build to install on my windows phone. I keep getting error 80072f8f; that windows is unable to connect to update. Some thing about date/time set incorrectly when search it....but mine is set correctly. So IDK....
Support hub
