qqragoon
anyone know where to download lauguage pack for build 7600.16385? and how to install them? thx
To download and install a language pack for Windows 7 build 7600.16385, you can follow these steps:
Downloading Language Pack:​
  • Check Compatibility: Ensure that the language pack you download is compatible with Windows 7 build 7600.16385.
  • Official Sources: Language packs for Windows 7 can be found through official channels such as Microsoft's website or the Microsoft Update Catalog.
  • Microsoft Update Catalog: Visit the https://www.catalog.update.microsoft.com/Home.aspx and search for the specific language pack you need.
  • Download: Select the appropriate language pack for your Windows 7 build (7600.16385) and download it to your computer.
Installing Language Pack:​
  • Open Control Panel:
  • Go to the Start menu and select Control Panel.
  • Region and Language Settings:
  • In the Control Panel, choose "Clock, Language, and Region."
  • Then, select "Install or uninstall display languages" under "Region and Language."
  • Install Language Pack:
  • Click on "Install display languages."
  • Choose the downloaded language pack file and follow the on-screen instructions to install it.
  • Restart:
  • After the installation is complete, restart your computer to apply the language pack changes.
  • Change Display Language:
  • Once restarted, navigate back to the "Region and Language" settings in Control Panel to select and change the display language to the newly installed language pack. Following these steps should help you download and install a language pack for Windows 7 build 7600.16385.
