Windows 10 Can't delete an extension in both Chrome and Edge.
LOL
Member
I check the extension menu in Chrome and Edge, it have an extension name yGiftFace and it said that is a developement extension thing. It make Google and Edge randomly open random pages. If I detele it, it will restart Edge or Chrome then it install again. Pls help me
It looks like your browser has been hijacked. To get rid if it you need to have or create a shortcut on you desktop then open the browser with that instead of the normal way in programs. when it opens you should then be able to delete the tab that keeps opening. Close the browser then open as normal. Hopefully this will solve your problem. If more then one has this issue you will need to do this for each one. Good luck!
helpifIcan
Fantastic Member
  • Like
Reactions: LOL
