Evan Volmering
My Windows 7 laptop is connected to a wireless network, with the other computer running Windows XP. My laptop has detected and installed the printer on the wireless network (HP Photosmart C4600), and says it is Ready. However, it still won't print. The furthest I've gotten is when the status said 'spooling', then nothing.
Printing a notepad document from my desktop gave me an Invalid Handle error, and printing in Chrome tells me there isn't a printer installed. Suggestions?
OK, so let's try this
Open Devices and Printers remove / delete all references to the problem printer and
Select add printer near the top menu bar
Select add local printer
Choose Create a new port and local port from drop down arrow Click Next
In the enter a port name do one of the following
1. \\MachineNameHostingPrinter\Printer'sShareName or
2. \\ipaddressOfMachineHostingPrinter\Printer'sShareName
In the install printer driver dialog box do one of the following
1. In the left panel select your printer manufacturer and in the right panel select your printer model (to use Win7 native drivers) or
2. Select the have disk button and direct the install process to the folder where you have download and extracted the Win 7...
OK. Thanks so much for the follow up and yes please be sure to keep us posted regarding your results.
Hello,
I am printing. Many thanks.
Regards,
Tom
Glad to hear it. Thanks for the follow-up and letting us know. Happy holidays.
Randy
Hi I am new to the forum and new to windows 7. I got a new pc for christmas and it runs windows 7. My old pc ran XP. Now I have a home network set up with three other laptops using it. I was able to print from each of those laptops but now I can find the new pc in the find printer section on the three laptops. I noticed that window 7 use's work groups not sure how to use them. Could someone help me with this.
Thanks Tim.
film2shoot;
We need a little more information.
Printer manufacturer, model name, model number?
How is it being made available as a network resource? (hosted printer connected to another PC, if so which and what operating system) integrated network card or wireless radio in the printer?
Make sure that you have the correct Windows 7 (32 or 64 bit) drivers for the printer.
Also since it would appear that you have introduced a new computer into an existing network, make sure that all computer have the same workgroup name and if your other network computers are down level clients like (XP and or Vista) please avoid creating and or joining a "Home Group" with the new Win7 machine.
You need to choose compatible driver in Windows 7. First, you have to click the ‘Start’ button and select and ‘All Programs’. Then, go to ‘Accessories’ and select ‘System Tools’ and then click ‘System Information’. Then, you have to select the ‘System Summary’ and then review the OS Name and System type to find out which version of operating system you are running. Then, accordingly choose the network printer driver for your computer.
Network printer not printing via TCP/IP
