Windows 10 Choosing the Right File System for Pen Drives: FAT32 vs. exFAT
Peterr
Fantastic Member
Is fat 32 acceptable for most pen drives.
I have read that exFat is also a choice; is it true?
fat32 and exfat are fairly similar for compatibly use exfat.
yes I would go exfat if you want to jump from Windows to some other system... just be aware of the size limits and stay under 2g
exfat does large volumes greater than 2gb, I have my 64gb formatted to it for my windows installs
Thank you all-good thing for alerts as I never got an email. better check my settings.
I dual-boot between Windows-10 and a Linux OS. So I don't use exFAT, because Linux doesn't support it. It comes with restrictive license which doesn't allow open-source operating system to implement it natively.
Linux has no problems with NTFS, so I format my usb-sticks with it.
