Thank you. That's what I thought.. and that's a nasty one to have..
Usually requires a reinstall to get rid of it.. but we'll try to find another solution besides reinstalling first..
This error usually means there's malware or possibly a virus/trojan somewhere in your OS...
If you got your copy of the RC from an untrusted source (I'm not naming any, you know what I mean) than you may have gotten the one with a trojan/malware in it.. There was a corrupt ISO floating around....
Do you have any AV and Spyware/Adware removal apps installed? If so, then I'd start by running full scans with those and see if anything turns up.. If nothing turns up then we're going to have to dig a little deeper..
Is the error only coming up when...
