lonepalm
Came across this site while looking for some answers for about 3 weeks now. Decided it was time to seek extra help from people who know more than I do. I am a newbie here (and would like to offer my thanks, in advance, for all of the analyzing and time that will go into this thread). I read through some stickies threads about how to post for BSOD help, and I even downloaded the tool that collects all the info (thanks for that)! So, I apologize if there is missing information that is needed that I did not provide. I will do my best.
Anyway, I encounter a bunch of different BSOD errors on the first startup of the day. When the BSOD occurs, it dumps to the file then restarts. I figured out that if I hold the power button after the system restarts but before Windows starts, that when I start it the second time, the BSOD error(s) don't return on the next startup.
I found a dump file reader program and most of the errors seem to refer to ntoskrnl.exe. When trying suggested things found around the web, I have found that the errors have not stopped. I really don't know what has changed that would cause this, as I have had a major computer crash and have replaced some components in the PC and re-installed Windows 7 64bit. Attached is the zip file with the results of the program sponsored here to gather the info. PLEASE give me ANY help, no matter how big or small it may be. I am at my witts end and I have invested a lot of time and money in building this PC! Thanks again, and I apologize for the many hours that may be put into this.
View attachment lonepalm_seven_forums.zip
Hello and welcome.
There's really no complicated bsods. We can easily fix these from happening shortly.
First, uninstall the notorious AVG in safe mode using the tool found here:
AV Uninstallers - Windows 7 Forums
Reboot and install MSE to replace.
Update your laser printer driver from Samsung's site. If you don't have one, then see this link for what it could be for:
DgiVecp DgiVecp.sys Thu Oct 30 23:38:29 2008
DgiVecp.sys Windows process - What is it?
Update this old Realtek lan driver. Type systeminfo in a command prompt then press enter. It will show you which Realtek number you have. If it's 8111, use the following link to update. If it's anything else, search the left side of the...
lonepalm
Ok, first startup today...internet connection did not start right away, which is odd. Eventually, a BSOD appeared, but had no error "code" associated with it. Attached is the next set of files. Webcam uninstalled and drivers removed. Scanned with Malwarebytes and removed two files. Did the chkdsk on all drives and all looked fine I guess. Thanks!
View attachment lonepalm_seven_forums_five.zip
TorrentG
Banned
One of your hard drives is having issues now as this is a 0x24 NTFS error. Run this command from an elevated command prompt for each drive letter on the machine, changing C to match the letters each time. Also remove all external hard drives and usb flash memory.
chkdsk /r C:
3: kd> !analyze -v
NTFS_FILE_SYSTEM (24)
    If you see NtfsExceptionFilter on the stack then the 2nd and 3rd
    parameters are the exception record and context record. Do a .cxr
    on the 3rd parameter and then kb to obtain a more informative stack
    trace.
Arguments:
Arg1: 00000000001904fb
Arg2: fffff8800a2703e8
Arg3: fffff8800a26fc50
Arg4: fffff800030d7905
Debugging Details:
EXCEPTION_RECORD:  fffff8800a2703e8 -- (.exr 0xfffff8800a2703e8)
ExceptionAddress: fffff800030d7905 (nt!ExpInterlockedPopEntrySListFault16)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
CONTEXT:  fffff8800a26fc50 -- (.cxr 0xfffff8800a26fc50)
rax=0000000025060033 rbx=fffffa8007109100 rcx=fffff880012a5380
rdx=2020202020202021 rsi=fffffa8007951a18 rdi=fffff8a003a2ce60
rip=fffff800030d7905 rsp=fffff8800a270620 rbp=0000000000000000
 r8=2020202020202020  r9=fffff8a003a2cd00 r10=fffff880012a5380
r11=0000000000000001 r12=fffff8800a25ab30 r13=fffff8a003a2cb40
r14=0000000000000002 r15=fffff8800a25aac0
iopl=0         nv up ei pl nz na pe nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010202
nt!ExpInterlockedPopEntrySListFault16:
fffff800`030d7905 498b08          mov     rcx,qword ptr [r8] ds:002b:20202020`20202020=????????????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  WerFault.exe
CURRENT_IRQL:  0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  ffffffffffffffff
READ_ADDRESS:  ffffffffffffffff
FOLLOWUP_IP:
Ntfs!NtfsOpenAttribute+580
fffff880`012fadd0 488bf8          mov     rdi,rax
FAULTING_IP:
nt!ExpInterlockedPopEntrySListFault16+0
BUGCHECK_STR:  0x24
LAST_CONTROL_TRANSFER:  from fffff880012fadd0 to fffff800030d7905
STACK_TEXT:
fffff880`0a270620 fffff880`012fadd0 : 00000000`00000000 fffff880`0a25aa00 fffff8a0`00000002 fffff8a0`03a2ced8 : nt!ExpInterlockedPopEntrySListFault16
fffff880`0a270630 fffff880`012e8e45 : fffffa80`071091f0 fffffa80`07951a18 fffffa80`064f2180 fffff8a0`03a2ced8 : Ntfs!NtfsOpenAttribute+0x580
fffff880`0a270740 fffff880`012e578b : fffff880`0a25aac0 fffffa80`071091f0 fffff8a0`03a2ced8 fffff8a0`00000024 : Ntfs!NtfsOpenExistingAttr+0x145
fffff880`0a270800 fffff880`012e5eff : fffffa80`071091f0 fffffa80`079516c0 fffff8a0`03a2ced8 fffff880`00000024 : Ntfs!NtfsOpenAttributeInExistingFile+0x5ab
fffff880`0a270990 fffff880`012f6e76 : fffffa80`071091f0 fffffa80`079516c0 fffff8a0`03a2ced8 00000000`00000701 : Ntfs!NtfsOpenExistingPrefixFcb+0x1ef
fffff880`0a270a80 fffff880`012f128d : fffffa80`071091f0 fffffa80`079516c0 fffff880`0a270c60 fffff880`0a270ca8 : Ntfs!NtfsFindStartingNode+0x5e6
fffff880`0a270b50 fffff880`0125ac0d : fffffa80`071091f0 fffffa80`079516c0 fffff880`0a25aac0 fffffa80`06822300 : Ntfs!NtfsCommonCreate+0x3dd
fffff880`0a270d30 fffff800`030cc5c7 : fffff880`0a25aa30 00000000`00000000 00000000`00000000 00000000`00000000 : Ntfs!NtfsCommonCreateCallout+0x1d
fffff880`0a270d60 fffff800`030cc581 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KySwitchKernelStackCallout+0x27
fffff880`0a25a900 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSwitchKernelStackContinue
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  Ntfs!NtfsOpenAttribute+580
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: Ntfs
IMAGE_NAME:  Ntfs.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc14f
STACK_COMMAND:  .cxr 0xfffff8800a26fc50 ; kb
FAILURE_BUCKET_ID:  X64_0x24_Ntfs!NtfsOpenAttribute+580
Followup: MachineOwner
lonepalm
chkdsk /r C:
3: kd> !analyze -v
    trace.
Arguments:
Debugging Details:
NumberParameters: 2
CURRENT_IRQL:  0
FOLLOWUP_IP:
FAULTING_IP:
BUGCHECK_STR:  0x24
STACK_TEXT:
MODULE_NAME: Ntfs
I ran these all last night. I will do it again now. It takes a while to go through, so I will probably have a reply tomorrow. Thanks!
lonepalm
Ok, test completed. I did not see anything that looked like there was a problem. Is there some report or file I can post so that can be verified?
cybercore
Run HDDScan
Same error as above:
100510-19500-01.dmp
Ntfs.sys ( Ntfs!NtfsOpenAttribute+580 )
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [F:\a\Minidump\100510-19500-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`03064000 PsLoadedModuleList = 0xfffff800`032a1e50
System Uptime: 0 days 0:01:12.839
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 24, {1904fb, fffff8800a2703e8, fffff8800a26fc50, fffff800030d7905}
Probably caused by : Ntfs.sys ( Ntfs!NtfsOpenAttribute+580 )
3: kd> !analyze -v
    trace.
Arguments:
Debugging Details:
NumberParameters: 2
CURRENT_IRQL:  0
ERROR_CODE: (NTSTATUS) 0xc0000005 - <Unable to get error code text>
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - <Unable to get error code text>
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff8000330c0e0
 ffffffffffffffff
FOLLOWUP_IP:
FAULTING_IP:
BUGCHECK_STR:  0x24
STACK_TEXT:
MODULE_NAME: Ntfs
fffff800`00bbc000 fffff800`00bc6000   kdcom    kdcom.dll    Tue Jul 14 04:31:07 2009 (4A5BDFDB)
fffff800`0301b000 fffff800`03064000   hal      hal.dll      Tue Jul 14 04:27:36 2009 (4A5BDF08)
fffff800`03064000 fffff800`03640000   nt       ntkrnlmp.exe Sat Jun 19 07:16:41 2010 (4C1C44A9)
fffff880`00c00000 fffff880`00ca4000   Wdf01000 Wdf01000.sys Tue Jul 14 02:22:07 2009 (4A5BC19F)
fffff880`00cab000 fffff880`00cb8000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 04:29:09 2009 (4A5BDF65)
fffff880`00cb8000 fffff880`00ccc000   PSHED    PSHED.dll    Tue Jul 14 04:32:23 2009 (4A5BE027)
fffff880`00ccc000 fffff880`00d2a000   CLFS     CLFS.SYS     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00d2a000 fffff880`00dea000   CI       CI.dll       Tue Jul 14 04:32:13 2009 (4A5BE01D)
fffff880`00dea000 fffff880`00df9000   WDFLDR   WDFLDR.SYS   Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00e00000 fffff880`00e10000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`00e10000 fffff880`00e2a000   mountmgr mountmgr.sys Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00e2a000 fffff880`00e33000   atapi    atapi.sys    Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`00e33000 fffff880`00e5d000   ataport  ataport.SYS  Tue Jul 14 02:19:52 2009 (4A5BC118)
fffff880`00e5d000 fffff880`00e68000   amdxata  amdxata.sys  Tue May 19 20:56:59 2009 (4A12F2EB)
fffff880`00e68000 fffff880`00eb4000   fltmgr   fltmgr.sys   Tue Jul 14 02:19:59 2009 (4A5BC11F)
fffff880`00ec1000 fffff880`00f18000   ACPI     ACPI.sys     Tue Jul 14 02:19:34 2009 (4A5BC106)
fffff880`00f18000 fffff880`00f21000   WMILIB   WMILIB.SYS   Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00f21000 fffff880`00f2b000   msisadrv msisadrv.sys Tue Jul 14 02:19:26 2009 (4A5BC0FE)
fffff880`00f2b000 fffff880`00f5e000   pci      pci.sys      Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00f5e000 fffff880`00f6b000   vdrvroot vdrvroot.sys Tue Jul 14 03:01:31 2009 (4A5BCADB)
fffff880`00f6b000 fffff880`00f80000   partmgr  partmgr.sys  Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`00f80000 fffff880`00f95000   volmgr   volmgr.sys   Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00f95000 fffff880`00ff1000   volmgrx  volmgrx.sys  Tue Jul 14 02:20:33 2009 (4A5BC141)
fffff880`00ff1000 fffff880`00ff8000   pciide   pciide.sys   Tue Jul 14 02:19:49 2009 (4A5BC115)
fffff880`01000000 fffff880`0104c000   volsnap  volsnap.sys  Tue Jul 14 02:20:08 2009 (4A5BC128)
fffff880`0104c000 fffff880`01086000   rdyboost rdyboost.sys Tue Jul 14 02:34:34 2009 (4A5BC48A)
fffff880`01086000 fffff880`010c0000   fvevol   fvevol.sys   Sat Sep 26 05:34:26 2009 (4ABD7DB2)
fffff880`010d3000 fffff880`010e7000   fileinfo fileinfo.sys Tue Jul 14 02:34:25 2009 (4A5BC481)
fffff880`010e7000 fffff880`01145000   msrpc    msrpc.sys    Tue Jul 14 02:21:32 2009 (4A5BC17C)
fffff880`01145000 fffff880`011b8000   cng      cng.sys      Tue Jul 14 02:49:40 2009 (4A5BC814)
fffff880`011b8000 fffff880`011ce000   disk     disk.sys     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`011ce000 fffff880`011fe000   CLASSPNP CLASSPNP.SYS Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`01200000 fffff880`0121a000   ksecdd   ksecdd.sys   Tue Jul 14 02:20:54 2009 (4A5BC156)
fffff880`0121a000 fffff880`0122b000   pcw      pcw.sys      Tue Jul 14 02:19:27 2009 (4A5BC0FF)
fffff880`0122b000 fffff880`01235000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 02:19:45 2009 (4A5BC111)
fffff880`01249000 fffff880`013ec000   Ntfs     Ntfs.sys     Tue Jul 14 02:20:47 2009 (4A5BC14F)
fffff880`01406000 fffff880`014f8000   ndis     ndis.sys     Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`014f8000 fffff880`01558000   NETIO    NETIO.SYS    Tue Jul 14 02:21:46 2009 (4A5BC18A)
fffff880`01558000 fffff880`01583000   ksecpkg  ksecpkg.sys  Fri Dec 11 08:03:32 2009 (4B21E0B4)
fffff880`01583000 fffff880`015cd000   fwpkclnt fwpkclnt.sys Tue Jul 14 02:21:08 2009 (4A5BC164)
fffff880`015cd000 fffff880`015dd000   vmstorfl vmstorfl.sys Tue Jul 14 02:42:54 2009 (4A5BC67E)
fffff880`015dd000 fffff880`015e5000   spldr    spldr.sys    Mon May 11 19:56:27 2009 (4A0858BB)
fffff880`015e5000 fffff880`015f7000   mup      mup.sys      Tue Jul 14 02:23:45 2009 (4A5BC201)
fffff880`015f7000 fffff880`01600000   hwpolicy hwpolicy.sys Tue Jul 14 02:19:22 2009 (4A5BC0FA)
fffff880`01600000 fffff880`017fd000   tcpip    tcpip.sys    Mon Jun 14 06:39:04 2010 (4C15A458)
fffff880`02a00000 fffff880`02a45000   netbt    netbt.sys    Tue Jul 14 02:21:28 2009 (4A5BC178)
fffff880`02a45000 fffff880`02a9f000   usbhub   usbhub.sys   Tue Jul 14 03:07:09 2009 (4A5BCC2D)
fffff880`02ad7000 fffff880`02b01000   cdrom    cdrom.sys    Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`02b01000 fffff880`02b2e000   MpFilter MpFilter.sys Sat Mar 20 07:58:08 2010 (4BA463F0)
fffff880`02b2e000 fffff880`02b37000   Null     Null.SYS     Tue Jul 14 02:19:37 2009 (4A5BC109)
fffff880`02b37000 fffff880`02b3e000   Beep     Beep.SYS     Tue Jul 14 03:00:13 2009 (4A5BCA8D)
fffff880`02b3e000 fffff880`02b4c000   vga      vga.sys      Tue Jul 14 02:38:47 2009 (4A5BC587)
fffff880`02b4c000 fffff880`02b71000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 02:38:51 2009 (4A5BC58B)
fffff880`02b71000 fffff880`02b81000   watchdog watchdog.sys Tue Jul 14 02:37:35 2009 (4A5BC53F)
fffff880`02b81000 fffff880`02b8a000   RDPCDD   RDPCDD.sys   Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`02b8a000 fffff880`02b93000   rdpencdd rdpencdd.sys Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`02b93000 fffff880`02b9c000   rdprefmp rdprefmp.sys Tue Jul 14 03:16:35 2009 (4A5BCE63)
fffff880`02b9c000 fffff880`02ba7000   Msfs     Msfs.SYS     Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`02ba7000 fffff880`02bb8000   Npfs     Npfs.SYS     Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`02bb8000 fffff880`02bd6000   tdx      tdx.sys      Tue Jul 14 02:21:15 2009 (4A5BC16B)
fffff880`02bd6000 fffff880`02be3000   TDI      TDI.SYS      Tue Jul 14 02:21:18 2009 (4A5BC16E)
fffff880`03c00000 fffff880`03c51000   rdbss    rdbss.sys    Tue Jul 14 02:24:09 2009 (4A5BC219)
fffff880`03c51000 fffff880`03c5d000   nsiproxy nsiproxy.sys Tue Jul 14 02:21:02 2009 (4A5BC15E)
fffff880`03c5d000 fffff880`03c68000   mssmbios mssmbios.sys Tue Jul 14 02:31:10 2009 (4A5BC3BE)
fffff880`03c68000 fffff880`03c77000   discache discache.sys Tue Jul 14 02:37:18 2009 (4A5BC52E)
fffff880`03c84000 fffff880`03d0e000   afd      afd.sys      Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`03d0e000 fffff880`03d17000   wfplwf   wfplwf.sys   Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`03d17000 fffff880`03d3d000   pacer    pacer.sys    Tue Jul 14 03:09:41 2009 (4A5BCCC5)
fffff880`03d3d000 fffff880`03d53000   vwififlt vwififlt.sys Tue Jul 14 03:07:22 2009 (4A5BCC3A)
fffff880`03d5c000 fffff880`03d6b000   netbios  netbios.sys  Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`03d6b000 fffff880`03d88000   serial   serial.sys   Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`03d88000 fffff880`03da3000   wanarp   wanarp.sys   Tue Jul 14 03:10:21 2009 (4A5BCCED)
fffff880`03da3000 fffff880`03db7000   termdd   termdd.sys   Tue Jul 14 03:16:36 2009 (4A5BCE64)
fffff880`03e00000 fffff880`03e43000   ks       ks.sys       Thu Mar 04 06:32:25 2010 (4B8F37D9)
fffff880`03e43000 fffff880`03e55000   umbus    umbus.sys    Tue Jul 14 03:06:56 2009 (4A5BCC20)
fffff880`03e55000 fffff880`03e6a000   NDProxy  NDProxy.SYS  Tue Jul 14 03:10:05 2009 (4A5BCCDD)
fffff880`03e6a000 fffff880`03e8b000   WudfPf   WudfPf.sys   Tue Jul 14 03:05:37 2009 (4A5BCBD1)
fffff880`03e8b000 fffff880`03ea0000   lltdio   lltdio.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`03ea6000 fffff880`03f29000   csc      csc.sys      Tue Jul 14 02:24:26 2009 (4A5BC22A)
fffff880`03f29000 fffff880`03f47000   dfsc     dfsc.sys     Tue Jul 14 02:23:44 2009 (4A5BC200)
fffff880`03f47000 fffff880`03f58000   blbdrive blbdrive.sys Tue Jul 14 02:35:59 2009 (4A5BC4DF)
fffff880`03f58000 fffff880`03f7e000   tunnel   tunnel.sys   Tue Jul 14 03:09:37 2009 (4A5BCCC1)
fffff880`03f7e000 fffff880`03f93000   amdppm   amdppm.sys   Tue Jul 14 02:19:25 2009 (4A5BC0FD)
fffff880`03f93000 fffff880`03f9c000   wmiacpi  wmiacpi.sys  Tue Jul 14 02:31:02 2009 (4A5BC3B6)
fffff880`03f9c000 fffff880`03fb6000   rassstp  rassstp.sys  Tue Jul 14 03:10:25 2009 (4A5BCCF1)
fffff880`03fb6000 fffff880`03fc1000   rdpbus   rdpbus.sys   Tue Jul 14 03:17:46 2009 (4A5BCEAA)
fffff880`03fc1000 fffff880`03fd0000   kbdclass kbdclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`03fd0000 fffff880`03fdf000   mouclass mouclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`04000000 fffff880`04010000   CompositeBus CompositeBus.sys Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`04010000 fffff880`04011480   swenum   swenum.sys   Tue Jul 14 03:00:18 2009 (4A5BCA92)
fffff880`04019000 fffff880`0410d000   dxgkrnl  dxgkrnl.sys  Fri Oct 02 04:00:14 2009 (4AC5509E)
fffff880`0410d000 fffff880`04153000   dxgmms1  dxgmms1.sys  Tue Jul 14 02:38:32 2009 (4A5BC578)
fffff880`04153000 fffff880`041aa000   Rt64win7 Rt64win7.sys Fri Sep 03 08:58:32 2010 (4C808E88)
fffff880`041aa000 fffff880`041b5000   usbohci  usbohci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`041b5000 fffff880`041c6000   usbehci  usbehci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`041c6000 fffff880`041ea000   HDAudBus HDAudBus.sys Tue Jul 14 03:06:13 2009 (4A5BCBF5)
fffff880`041ea000 fffff880`041f6000   serenum  serenum.sys  Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`06a00000 fffff880`06a0c000   usbprint usbprint.sys Tue Jul 14 03:38:18 2009 (4A5BD37A)
fffff880`06a0c000 fffff880`06a27000   USBSTOR  USBSTOR.SYS  Tue Jul 14 03:06:34 2009 (4A5BCC0A)
fffff880`06a27000 fffff880`06a35000   crashdmp crashdmp.sys Tue Jul 14 03:01:01 2009 (4A5BCABD)
fffff880`06a35000 fffff880`06a41000   dump_dumpata dump_dumpata.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`06a41000 fffff880`06a4a000   dump_atapi dump_atapi.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`06a4a000 fffff880`06a5d000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 02:21:51 2009 (4A5BC18F)
fffff880`06a5d000 fffff880`06a69000   Dxapi    Dxapi.sys    Tue Jul 14 02:38:28 2009 (4A5BC574)
fffff880`06a69000 fffff880`06a77000   monitor  monitor.sys  Tue Jul 14 02:38:52 2009 (4A5BC58C)
fffff880`06a77000 fffff880`06a9a000   luafv    luafv.sys    Tue Jul 14 02:26:13 2009 (4A5BC295)
fffff880`06aa9000 fffff880`06b05000   HdAudio  HdAudio.sys  Tue Jul 14 03:06:59 2009 (4A5BCC23)
fffff880`06b05000 fffff880`06b42000   portcls  portcls.sys  Tue Jul 14 03:06:27 2009 (4A5BCC03)
fffff880`06b42000 fffff880`06b64000   drmk     drmk.sys     Tue Jul 14 04:01:25 2009 (4A5BD8E5)
fffff880`06b64000 fffff880`06b69200   ksthunk  ksthunk.sys  Tue Jul 14 03:00:19 2009 (4A5BCA93)
fffff880`06b6a000 fffff880`06b87000   usbccgp  usbccgp.sys  Tue Jul 14 03:06:45 2009 (4A5BCC15)
fffff880`06b87000 fffff880`06b88f00   USBD     USBD.SYS     Tue Jul 14 03:06:23 2009 (4A5BCBFF)
fffff880`06b89000 fffff880`06b9b000   dc3d     dc3d.sys     Thu Jul 01 13:07:45 2010 (4C2C68F1)
fffff880`06b9b000 fffff880`06ba3080   HIDPARSE HIDPARSE.SYS Tue Jul 14 03:06:17 2009 (4A5BCBF9)
fffff880`06ba4000 fffff880`06bb2000   hidusb   hidusb.sys   Tue Jul 14 03:06:22 2009 (4A5BCBFE)
fffff880`06bb2000 fffff880`06bcb000   HIDCLASS HIDCLASS.SYS Tue Jul 14 03:06:21 2009 (4A5BCBFD)
fffff880`06bcb000 fffff880`06bd9000   kbdhid   kbdhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`06bd9000 fffff880`06be6000   mouhid   mouhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`06be6000 fffff880`06bf6000   point64  point64.sys  Tue Jun 29 11:54:31 2010 (4C29B4C7)
fffff880`08000000 fffff880`08068000   srv2     srv2.sys     Tue Jun 22 06:20:47 2010 (4C202C0F)
fffff880`080c4000 fffff880`08117000   nwifi    nwifi.sys    Tue Jul 14 03:07:23 2009 (4A5BCC3B)
fffff880`08117000 fffff880`0812a000   ndisuio  ndisuio.sys  Tue Jul 14 03:09:25 2009 (4A5BCCB5)
fffff880`0812a000 fffff880`08142000   rspndr   rspndr.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`08142000 fffff880`081e8000   peauth   peauth.sys   Tue Jul 14 04:01:19 2009 (4A5BD8DF)
fffff880`08400000 fffff880`08423000   mrxsmb20 mrxsmb20.sys Sat Feb 27 09:52:26 2010 (4B88CF3A)
fffff880`08423000 fffff880`0842e000   secdrv   secdrv.SYS   Wed Sep 13 16:18:38 2006 (4508052E)
fffff880`0842e000 fffff880`0845b000   srvnet   srvnet.sys   Tue Jun 22 06:20:32 2010 (4C202C00)
fffff880`08468000 fffff880`08530000   HTTP     HTTP.sys     Tue Jul 14 02:22:16 2009 (4A5BC1A8)
fffff880`08530000 fffff880`0854e000   bowser   bowser.sys   Tue Jul 14 02:23:50 2009 (4A5BC206)
fffff880`0854e000 fffff880`08566000   mpsdrv   mpsdrv.sys   Tue Jul 14 03:08:25 2009 (4A5BCC79)
fffff880`08566000 fffff880`08593000   mrxsmb   mrxsmb.sys   Sat Feb 27 09:52:19 2010 (4B88CF33)
fffff880`08593000 fffff880`085e1000   mrxsmb10 mrxsmb10.sys Sat Feb 27 09:52:28 2010 (4B88CF3C)
fffff880`085e1000 fffff880`085f3000   tcpipreg tcpipreg.sys Tue Jul 14 03:09:49 2009 (4A5BCCCD)
fffff880`09af7000 fffff880`09b8d000   srv      srv.sys      Tue Jun 22 06:21:11 2010 (4C202C27)
fffff880`09b8d000 fffff880`09b9d000   MpNWMon  MpNWMon.sys  Sat Mar 20 07:58:00 2010 (4BA463E8)
fffff880`13c00000 fffff880`13c1d000   parport  parport.sys  Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`13c1d000 fffff880`13c33000   AgileVpn AgileVpn.sys Tue Jul 14 03:10:24 2009 (4A5BCCF0)
fffff880`13c33000 fffff880`13c57000   rasl2tp  rasl2tp.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`13c57000 fffff880`13c63000   ndistapi ndistapi.sys Tue Jul 14 03:10:00 2009 (4A5BCCD8)
fffff880`13c63000 fffff880`13c92000   ndiswan  ndiswan.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`13c92000 fffff880`13cad000   raspppoe raspppoe.sys Tue Jul 14 03:10:17 2009 (4A5BCCE9)
fffff880`13cad000 fffff880`13cce000   raspptp  raspptp.sys  Tue Jul 14 03:10:18 2009 (4A5BCCEA)
fffff880`13cd5000 fffff880`14966e00   nvlddmkm nvlddmkm.sys Sat Jul 10 00:15:58 2010 (4C37918E)
fffff880`14967000 fffff880`14968180   nvBridge nvBridge.kmd Sat Jul 10 00:07:54 2010 (4C378FAA)
fffff880`14969000 fffff880`149bf000   USBPORT  USBPORT.SYS  Tue Jul 14 03:06:31 2009 (4A5BCC07)
fffff880`149bf000 fffff880`149fd000   1394ohci 1394ohci.sys Tue Jul 14 03:07:12 2009 (4A5BCC30)
fffff960`00030000 fffff960`0033f000   win32k   win32k.sys   Sat Jun 19 07:31:59 2010 (4C1C483F)
fffff960`00420000 fffff960`0042a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`00720000 fffff960`00747000   cdd      cdd.dll      Wed May 19 22:48:26 2010 (4BF4408A)
fffff960`00900000 fffff960`00961000   ATMFD    ATMFD.DLL    Thu May 27 07:11:31 2010 (4BFDF0F3)
Unloaded modules:
fffff880`09b9d000 fffff880`09bce000   WUDFRd.sys
    Checksum:  00000000
fffff880`01235000 fffff880`01243000   crashdmp.sys
    Checksum:  00000000
fffff880`013ec000 fffff880`013f8000   dump_ataport
    Checksum:  00000000
fffff880`010c0000 fffff880`010c9000   dump_atapi.s
    Checksum:  00000000
fffff880`02ac4000 fffff880`02ad7000   dump_dumpfve
    Checksum:  00000000
fffff880`03d53000 fffff880`03d5c000   anodlwfx.sys
    Checksum:  00000000
Loading Dump File [F:\a\Minidump\100610-22230-01.dmp]
Machine Name:
Kernel base = 0xfffff800`0305a000 PsLoadedModuleList = 0xfffff800`03297e50
System Uptime: 0 days 0:00:29.359
BugCheck 3B, {c0000005, fffff800033a674d, fffff8800397e770, 0}
Probably caused by : ntkrnlmp.exe ( nt!CmpKcbCacheLookup+1dd )
2: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff800033a674d, Address of the exception record for the exception that caused the bugcheck
Arg3: fffff8800397e770, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
FAULTING_IP:
fffff800`033a674d 418b45f4        mov     eax,dword ptr [r13-0Ch]
CONTEXT:  fffff8800397e770 -- (.cxr 0xfffff8800397e770)
rax=0000000000000000 rbx=0000000000000000 rcx=0000000000000a8c
rdx=000000000732cbb7 rsi=fffff8a000133608 rdi=fffff8800397f2c0
rip=fffff800033a674d rsp=fffff8800397f140 rbp=fffff8a000133010
 r8=0000000000000009  r9=0000000000000000 r10=0000000000000007
r11=fffff8800397f2c0 r12=fffff8a002519b98 r13=006e00690057005c
r14=0000000000000000 r15=0000000000000001
iopl=0         nv up ei pl nz na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010206
nt!CmpKcbCacheLookup+0x1dd:
fffff800`033a674d 418b45f4        mov     eax,dword ptr [r13-0Ch] ds:002b:006e0069`00570050=????????
BUGCHECK_STR:  0x3B
PROCESS_NAME:  csrss.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff800033a674d
STACK_TEXT:
fffff880`0397f140 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!CmpKcbCacheLookup+0x1dd
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!CmpKcbCacheLookup+1dd
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4c1c44a9
STACK_COMMAND:  .cxr 0xfffff8800397e770 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_nt!CmpKcbCacheLookup+1dd
Captain Jack
Former Moderator
Hello,
Seems like a hardware issue. Run a Hardware Diagnostic follow this link for instructions Link Removed - Invalid URL Make sure you run the MemTest86+ over night atleast 7 to 8 passes. Download Speedfan and check the temperatures. Make sure it's not heat issue. Post us back for further issues.
Bugcheck:
MEMORY_MANAGEMENT (1a)
    # Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000041201, The subtype of the bugcheck.
Arg2: fffff68000013450
Arg3: 9cc00000b6a9e867
Arg4: fffffa8007533180
Debugging Details:
BUGCHECK_STR:  0x1a_41201
PROCESS_NAME:  AWC.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff800030e0b3e to fffff80003082740
STACK_TEXT:
fffff880`098129b8 fffff800`030e0b3e : 00000000`0000001a 00000000`00041201 fffff680`00013450 9cc00000`b6a9e867 : nt!KeBugCheckEx
fffff880`098129c0 fffff800`03050b6e : fffff880`00961000 fffffa80`07cbeb60 00000000`00000202 9cc00000`b6a9e867 : nt! ?? ::FNODOBFM::`string'+0x13bb2
fffff880`09812a00 fffff800`0305080a : fffffa80`07533180 fffffa80`07947060 fffffa80`07947060 00000000`0268a000 : nt!MiQueryAddressState+0x2ae
fffff880`09812a50 fffff800`03369c38 : fffff880`00000004 00000000`0268b000 fffffa80`07533180 00000000`00000000 : nt!MiQueryAddressSpan+0xaa
fffff880`09812ac0 fffff800`03081993 : 00000000`0000048c fffffa80`07cbeb60 fffff880`09812bc8 00000000`0009dda8 : nt!NtQueryVirtualMemory+0x386
fffff880`09812bb0 00000000`771bff8a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0009dd88 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x771bff8a
STACK_COMMAND:  kb
FOLLOWUP_IP:
nt! ?? ::FNODOBFM::`string'+13bb2
fffff800`030e0b3e cc              int     3
SYMBOL_NAME:  nt! ?? ::FNODOBFM::`string'+13bb2
MODULE_NAME: nt
FAILURE_BUCKET_ID:  X64_0x1a_41201_nt!_??_::FNODOBFM::_string_+13bb2
Hope this helps,
Captain
lonepalm
Hello,
Bugcheck:
Arguments:
Debugging Details:
CURRENT_IRQL:  0
STACK_TEXT:
STACK_COMMAND:  kb
FOLLOWUP_IP:
MODULE_NAME: nt
Hope this helps,
Captain
Here are the results from speedfan:
GPU : 129F
Temp1: 100F
Temp2: 95F
Temp3: 99F
Core: 99F
I will start the memtest now and post when it finishes. Advanced System Care uninstalled. Here are the latest BSOD files.
View attachment lonepalm_9.zip
cybercore
Pool_Corruption ( nt!ExDeferredFreePool+233 )
The drivers are all perfect. Do the memtest now.
9.10.2010
Loading Dump File [F:\a\Minidump\D M P\100910-17269-01.dmp]
Machine Name:
Kernel base = 0xfffff800`0300f000 PsLoadedModuleList = 0xfffff800`0324ce50
Debug session time: Sat Oct  9 15:43:38.694 2010 (GMT-5)
System Uptime: 0 days 0:00:16.426
BugCheck 3B, {c0000005, fffff800031b30bf, fffff88003a61fa0, 0}
Probably caused by : Pool_Corruption ( nt!ExDeferredFreePool+233 )
Followup: Pool_corruption
1: kd> !analyze -v
Arguments:
Arg2: fffff800031b30bf, Address of the exception record for the exception that caused the bugcheck
Arg3: fffff88003a61fa0, Address of the context record for the exception that caused the bugcheck
Debugging Details:
FAULTING_IP:
fffff800`031b30bf 4c395008        cmp     qword ptr [rax+8],r10
CONTEXT:  fffff88003a61fa0 -- (.cxr 0xfffff88003a61fa0)
rax=0000000000000000 rbx=0000000000000001 rcx=fffffa80039612d0
rdx=fffff8a000f25290 rsi=0000000000000000 rdi=fffff8a000f2cd30
rip=fffff800031b30bf rsp=fffff88003a62970 rbp=0000000000000000
 r8=fffff8a000f2cd80  r9=fffff8a000f252a0 r10=fffff8a000f252b0
r11=0000000000000001 r12=fffffa8003961140 r13=0000000000000000
r14=0000000000000003 r15=0000000000000001
iopl=0         nv up ei ng nz na pe nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010282
nt!ExDeferredFreePool+0x233:
fffff800`031b30bf 4c395008        cmp     qword ptr [rax+8],r10 ds:002b:00000000`00000008=????????????????
BUGCHECK_STR:  0x3B
PROCESS_NAME:  lsass.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff800031b30bf
STACK_TEXT:
fffff880`03a62970 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!ExDeferredFreePool+0x233
FOLLOWUP_IP:
SYMBOL_NAME:  nt!ExDeferredFreePool+233
FOLLOWUP_NAME:  Pool_corruption
IMAGE_NAME:  Pool_Corruption
DEBUG_FLR_IMAGE_TIMESTAMP:  0
MODULE_NAME: Pool_Corruption
STACK_COMMAND:  .cxr 0xfffff88003a61fa0 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_nt!ExDeferredFreePool+233
fffff800`00baa000 fffff800`00bb4000   kdcom    kdcom.dll    Tue Jul 14 04:31:07 2009 (4A5BDFDB)
fffff800`0300f000 fffff800`035eb000   nt       ntkrnlmp.exe Sat Jun 19 07:16:41 2010 (4C1C44A9)
fffff800`035eb000 fffff800`03634000   hal      hal.dll      Tue Jul 14 04:27:36 2009 (4A5BDF08)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Tue Jul 14 04:32:13 2009 (4A5BE01D)
fffff880`00ce9000 fffff880`00cf6000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 04:29:09 2009 (4A5BDF65)
fffff880`00cf6000 fffff880`00d0a000   PSHED    PSHED.dll    Tue Jul 14 04:32:23 2009 (4A5BE027)
fffff880`00d0a000 fffff880`00d68000   CLFS     CLFS.SYS     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00d68000 fffff880`00dc4000   volmgrx  volmgrx.sys  Tue Jul 14 02:20:33 2009 (4A5BC141)
fffff880`00dc4000 fffff880`00dee000   ataport  ataport.SYS  Tue Jul 14 02:19:52 2009 (4A5BC118)
fffff880`00e00000 fffff880`00e33000   pci      pci.sys      Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00e33000 fffff880`00e40000   vdrvroot vdrvroot.sys Tue Jul 14 03:01:31 2009 (4A5BCADB)
fffff880`00e40000 fffff880`00e55000   partmgr  partmgr.sys  Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`00e55000 fffff880`00e6a000   volmgr   volmgr.sys   Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00e6a000 fffff880`00e71000   pciide   pciide.sys   Tue Jul 14 02:19:49 2009 (4A5BC115)
fffff880`00e71000 fffff880`00e81000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`00e81000 fffff880`00e9b000   mountmgr mountmgr.sys Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00e9b000 fffff880`00ea4000   atapi    atapi.sys    Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`00ea4000 fffff880`00eaf000   amdxata  amdxata.sys  Tue May 19 20:56:59 2009 (4A12F2EB)
fffff880`00ec1000 fffff880`00f65000   Wdf01000 Wdf01000.sys Tue Jul 14 02:22:07 2009 (4A5BC19F)
fffff880`00f65000 fffff880`00f74000   WDFLDR   WDFLDR.SYS   Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00f74000 fffff880`00fcb000   ACPI     ACPI.sys     Tue Jul 14 02:19:34 2009 (4A5BC106)
fffff880`00fcb000 fffff880`00fd4000   WMILIB   WMILIB.SYS   Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00fd4000 fffff880`00fde000   msisadrv msisadrv.sys Tue Jul 14 02:19:26 2009 (4A5BC0FE)
fffff880`01000000 fffff880`0104a000   fwpkclnt fwpkclnt.sys Tue Jul 14 02:21:08 2009 (4A5BC164)
fffff880`0104a000 fffff880`01096000   volsnap  volsnap.sys  Tue Jul 14 02:20:08 2009 (4A5BC128)
fffff880`010a7000 fffff880`010f3000   fltmgr   fltmgr.sys   Tue Jul 14 02:19:59 2009 (4A5BC11F)
fffff880`010f3000 fffff880`01107000   fileinfo fileinfo.sys Tue Jul 14 02:34:25 2009 (4A5BC481)
fffff880`01107000 fffff880`01165000   msrpc    msrpc.sys    Tue Jul 14 02:21:32 2009 (4A5BC17C)
fffff880`01165000 fffff880`011d8000   cng      cng.sys      Tue Jul 14 02:49:40 2009 (4A5BC814)
fffff880`01200000 fffff880`01211000   pcw      pcw.sys      Tue Jul 14 02:19:27 2009 (4A5BC0FF)
fffff880`01211000 fffff880`0121b000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 02:19:45 2009 (4A5BC111)
fffff880`01238000 fffff880`013db000   Ntfs     Ntfs.sys     Tue Jul 14 02:20:47 2009 (4A5BC14F)
fffff880`013db000 fffff880`013f5000   ksecdd   ksecdd.sys   Tue Jul 14 02:20:54 2009 (4A5BC156)
fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Tue Jul 14 02:21:46 2009 (4A5BC18A)
fffff880`01460000 fffff880`0148b000   ksecpkg  ksecpkg.sys  Fri Dec 11 08:03:32 2009 (4B21E0B4)
fffff880`0148b000 fffff880`0149b000   vmstorfl vmstorfl.sys Tue Jul 14 02:42:54 2009 (4A5BC67E)
fffff880`0149b000 fffff880`014a3000   spldr    spldr.sys    Mon May 11 19:56:27 2009 (4A0858BB)
fffff880`014a3000 fffff880`014b5000   mup      mup.sys      Tue Jul 14 02:23:45 2009 (4A5BC201)
fffff880`014b5000 fffff880`014be000   hwpolicy hwpolicy.sys Tue Jul 14 02:19:22 2009 (4A5BC0FA)
fffff880`014d2000 fffff880`015c4000   ndis     ndis.sys     Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`015c4000 fffff880`015fe000   rdyboost rdyboost.sys Tue Jul 14 02:34:34 2009 (4A5BC48A)
fffff880`01602000 fffff880`017ff000   tcpip    tcpip.sys    Mon Jun 14 06:39:04 2010 (4C15A458)
fffff880`01800000 fffff880`01823000   luafv    luafv.sys    Tue Jul 14 02:26:13 2009 (4A5BC295)
fffff880`01839000 fffff880`01873000   fvevol   fvevol.sys   Sat Sep 26 05:34:26 2009 (4ABD7DB2)
fffff880`01873000 fffff880`01889000   disk     disk.sys     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`01889000 fffff880`018b9000   CLASSPNP CLASSPNP.SYS Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`018b9000 fffff880`018da000   WudfPf   WudfPf.sys   Tue Jul 14 03:05:37 2009 (4A5BCBD1)
fffff880`018ef000 fffff880`01919000   cdrom    cdrom.sys    Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`01919000 fffff880`01946000   MpFilter MpFilter.sys Sat Mar 20 07:58:08 2010 (4BA463F0)
fffff880`01946000 fffff880`0194f000   Null     Null.SYS     Tue Jul 14 02:19:37 2009 (4A5BC109)
fffff880`0194f000 fffff880`01956000   Beep     Beep.SYS     Tue Jul 14 03:00:13 2009 (4A5BCA8D)
fffff880`01956000 fffff880`01964000   vga      vga.sys      Tue Jul 14 02:38:47 2009 (4A5BC587)
fffff880`01964000 fffff880`01989000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 02:38:51 2009 (4A5BC58B)
fffff880`01989000 fffff880`01999000   watchdog watchdog.sys Tue Jul 14 02:37:35 2009 (4A5BC53F)
fffff880`01999000 fffff880`019a2000   RDPCDD   RDPCDD.sys   Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`019a2000 fffff880`019ab000   rdpencdd rdpencdd.sys Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`019ab000 fffff880`019b4000   rdprefmp rdprefmp.sys Tue Jul 14 03:16:35 2009 (4A5BCE63)
fffff880`019b4000 fffff880`019bf000   Msfs     Msfs.SYS     Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`019bf000 fffff880`019d0000   Npfs     Npfs.SYS     Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`019d0000 fffff880`019ee000   tdx      tdx.sys      Tue Jul 14 02:21:15 2009 (4A5BC16B)
fffff880`019ee000 fffff880`019fb000   TDI      TDI.SYS      Tue Jul 14 02:21:18 2009 (4A5BC16E)
fffff880`02c00000 fffff880`02c0b000   mssmbios mssmbios.sys Tue Jul 14 02:31:10 2009 (4A5BC3BE)
fffff880`02c0b000 fffff880`02c1a000   discache discache.sys Tue Jul 14 02:37:18 2009 (4A5BC52E)
fffff880`02c27000 fffff880`02c6c000   netbt    netbt.sys    Tue Jul 14 02:21:28 2009 (4A5BC178)
fffff880`02c6c000 fffff880`02cf6000   afd      afd.sys      Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`02cf6000 fffff880`02cff000   wfplwf   wfplwf.sys   Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`02cff000 fffff880`02d25000   pacer    pacer.sys    Tue Jul 14 03:09:41 2009 (4A5BCCC5)
fffff880`02d25000 fffff880`02d3b000   vwififlt vwififlt.sys Tue Jul 14 03:07:22 2009 (4A5BCC3A)
fffff880`02d44000 fffff880`02d53000   netbios  netbios.sys  Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`02d53000 fffff880`02d70000   serial   serial.sys   Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`02d70000 fffff880`02d8b000   wanarp   wanarp.sys   Tue Jul 14 03:10:21 2009 (4A5BCCED)
fffff880`02d8b000 fffff880`02d9f000   termdd   termdd.sys   Tue Jul 14 03:16:36 2009 (4A5BCE64)
fffff880`02d9f000 fffff880`02df0000   rdbss    rdbss.sys    Tue Jul 14 02:24:09 2009 (4A5BC219)
fffff880`02df0000 fffff880`02dfc000   nsiproxy nsiproxy.sys Tue Jul 14 02:21:02 2009 (4A5BC15E)
fffff880`03e00000 fffff880`03e57000   Rt64win7 Rt64win7.sys Fri Sep 03 08:58:32 2010 (4C808E88)
fffff880`03e57000 fffff880`03ead000   USBPORT  USBPORT.SYS  Tue Jul 14 03:06:31 2009 (4A5BCC07)
fffff880`03ead000 fffff880`03ed1000   HDAudBus HDAudBus.sys Tue Jul 14 03:06:13 2009 (4A5BCBF5)
fffff880`03edb000 fffff880`03f5e000   csc      csc.sys      Tue Jul 14 02:24:26 2009 (4A5BC22A)
fffff880`03f5e000 fffff880`03f7c000   dfsc     dfsc.sys     Tue Jul 14 02:23:44 2009 (4A5BC200)
fffff880`03f7c000 fffff880`03f8d000   blbdrive blbdrive.sys Tue Jul 14 02:35:59 2009 (4A5BC4DF)
fffff880`03f8d000 fffff880`03fb3000   tunnel   tunnel.sys   Tue Jul 14 03:09:37 2009 (4A5BCCC1)
fffff880`03fb3000 fffff880`03fc8000   amdppm   amdppm.sys   Tue Jul 14 02:19:25 2009 (4A5BC0FD)
fffff880`03fc8000 fffff880`03fd1000   wmiacpi  wmiacpi.sys  Tue Jul 14 02:31:02 2009 (4A5BC3B6)
fffff880`03fd1000 fffff880`03fec000   USBSTOR  USBSTOR.SYS  Tue Jul 14 03:06:34 2009 (4A5BCC0A)
fffff880`04017000 fffff880`04055000   1394ohci 1394ohci.sys Tue Jul 14 03:07:12 2009 (4A5BCC30)
fffff880`04055000 fffff880`04061000   serenum  serenum.sys  Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`04061000 fffff880`0407e000   parport  parport.sys  Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`0407e000 fffff880`0408e000   CompositeBus CompositeBus.sys Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`0408e000 fffff880`040a4000   AgileVpn AgileVpn.sys Tue Jul 14 03:10:24 2009 (4A5BCCF0)
fffff880`040a4000 fffff880`040c8000   rasl2tp  rasl2tp.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`040c8000 fffff880`040d4000   ndistapi ndistapi.sys Tue Jul 14 03:10:00 2009 (4A5BCCD8)
fffff880`040d4000 fffff880`04103000   ndiswan  ndiswan.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`04103000 fffff880`0411e000   raspppoe raspppoe.sys Tue Jul 14 03:10:17 2009 (4A5BCCE9)
fffff880`0411e000 fffff880`0413f000   raspptp  raspptp.sys  Tue Jul 14 03:10:18 2009 (4A5BCCEA)
fffff880`0413f000 fffff880`04159000   rassstp  rassstp.sys  Tue Jul 14 03:10:25 2009 (4A5BCCF1)
fffff880`04159000 fffff880`04164000   rdpbus   rdpbus.sys   Tue Jul 14 03:17:46 2009 (4A5BCEAA)
fffff880`04164000 fffff880`04173000   kbdclass kbdclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`04173000 fffff880`04182000   mouclass mouclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`04182000 fffff880`04183480   swenum   swenum.sys   Tue Jul 14 03:00:18 2009 (4A5BCA92)
fffff880`04184000 fffff880`041c7000   ks       ks.sys       Thu Mar 04 06:32:25 2010 (4B8F37D9)
fffff880`041c7000 fffff880`041d9000   umbus    umbus.sys    Tue Jul 14 03:06:56 2009 (4A5BCC20)
fffff880`041d9000 fffff880`041e9000   point64  point64.sys  Tue Jun 29 11:54:31 2010 (4C29B4C7)
fffff880`041e9000 fffff880`041f7000   monitor  monitor.sys  Tue Jul 14 02:38:52 2009 (4A5BC58C)
fffff880`06400000 fffff880`0640e000   kbdhid   kbdhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`0640e000 fffff880`0641b000   mouhid   mouhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`0641b000 fffff880`06427000   Dxapi    Dxapi.sys    Tue Jul 14 02:38:28 2009 (4A5BC574)
fffff880`06428000 fffff880`06482000   usbhub   usbhub.sys   Tue Jul 14 03:07:09 2009 (4A5BCC2D)
fffff880`06482000 fffff880`06497000   NDProxy  NDProxy.SYS  Tue Jul 14 03:10:05 2009 (4A5BCCDD)
fffff880`06497000 fffff880`064f3000   HdAudio  HdAudio.sys  Tue Jul 14 03:06:59 2009 (4A5BCC23)
fffff880`064f3000 fffff880`06530000   portcls  portcls.sys  Tue Jul 14 03:06:27 2009 (4A5BCC03)
fffff880`06530000 fffff880`06552000   drmk     drmk.sys     Tue Jul 14 04:01:25 2009 (4A5BD8E5)
fffff880`06552000 fffff880`06557200   ksthunk  ksthunk.sys  Tue Jul 14 03:00:19 2009 (4A5BCA93)
fffff880`06558000 fffff880`06566000   crashdmp crashdmp.sys Tue Jul 14 03:01:01 2009 (4A5BCABD)
fffff880`06566000 fffff880`06572000   dump_dumpata dump_dumpata.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`06572000 fffff880`0657b000   dump_atapi dump_atapi.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`0657b000 fffff880`0658e000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 02:21:51 2009 (4A5BC18F)
fffff880`0658e000 fffff880`0659a000   usbprint usbprint.sys Tue Jul 14 03:38:18 2009 (4A5BD37A)
fffff880`0659a000 fffff880`0659bf00   USBD     USBD.SYS     Tue Jul 14 03:06:23 2009 (4A5BCBFF)
fffff880`0659c000 fffff880`065b9000   usbccgp  usbccgp.sys  Tue Jul 14 03:06:45 2009 (4A5BCC15)
fffff880`065b9000 fffff880`065cb000   dc3d     dc3d.sys     Thu Jul 01 13:07:45 2010 (4C2C68F1)
fffff880`065cb000 fffff880`065d3080   HIDPARSE HIDPARSE.SYS Tue Jul 14 03:06:17 2009 (4A5BCBF9)
fffff880`065d4000 fffff880`065e2000   hidusb   hidusb.sys   Tue Jul 14 03:06:22 2009 (4A5BCBFE)
fffff880`065e2000 fffff880`065fb000   HIDCLASS HIDCLASS.SYS Tue Jul 14 03:06:21 2009 (4A5BCBFD)
fffff880`13e00000 fffff880`13e0b000   usbohci  usbohci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`13e0b000 fffff880`13e1c000   usbehci  usbehci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`13e2a000 fffff880`14abbe00   nvlddmkm nvlddmkm.sys Sat Jul 10 00:15:58 2010 (4C37918E)
fffff880`14abc000 fffff880`14abd180   nvBridge nvBridge.kmd Sat Jul 10 00:07:54 2010 (4C378FAA)
fffff880`14abe000 fffff880`14bb2000   dxgkrnl  dxgkrnl.sys  Fri Oct 02 04:00:14 2009 (4AC5509E)
fffff880`14bb2000 fffff880`14bf8000   dxgmms1  dxgmms1.sys  Tue Jul 14 02:38:32 2009 (4A5BC578)
fffff960`00000000 fffff960`0030f000   win32k   win32k.sys   Sat Jun 19 07:31:59 2010 (4C1C483F)
fffff960`004b0000 fffff960`004ba000   TSDDD    TSDDD.dll    Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff960`006a0000 fffff960`006c7000   cdd      cdd.dll      unavailable (00000000)
fffff960`00920000 fffff960`00981000   ATMFD    ATMFD.DLL    Thu May 27 07:11:31 2010 (4BFDF0F3)
Unloaded modules:
fffff880`018b9000 fffff880`018c7000   crashdmp.sys
    Checksum:  00000000
fffff880`018c7000 fffff880`018d3000   dump_ataport
    Checksum:  00000000
fffff880`018d3000 fffff880`018dc000   dump_atapi.s
    Checksum:  00000000
fffff880`018dc000 fffff880`018ef000   dump_dumpfve
    Checksum:  00000000
fffff880`02d3b000 fffff880`02d44000   anodlwfx.sys
    Checksum:  00000000
TorrentG
Banned
Agreed with Cybercore. However, I noticed that anodlwfx.sys is becoming unloaded with each crash. I would find that driver, probably in C:\Windows\System32\drivers, and rename it to anodlwfx.BAK then reboot.
lonepalm
Ok, the memtest had 9 passes and found NO errors.
anodlwfx.sys has been renamed anodlwfx.BAK. When I boot up tomorrow morning, I'll have the chance to see if I still get the BSOD. Thanks everyone for the help you have given me thus far!
cybercore
You may want to enable Driver Verifier so it hopefully better locates the driver of the malfunctioning device.
Driver Verifier - Enable and Disable - Windows 7 Forums
101010-17362-01.dmp (10.10.2010)
BugCheck 3B, {c0000005, ...}
nt!CmpAllocateKeyControlBlock+72
It still could be your RAM. Sometimes it takes to test the same stick in different slots.
You haven't tested the videocard yet FurMark: VGA Stress Test, Graphics Card and GPU Stability Test, OpenGL Benchmark and GPU Temperature | oZone3D.Net and the CPU CPU - Stress Test with Prime95 - Windows 7 Forums. With Prime95 do both 'Blend' and 'Torture'.
I still see this old driver:
speedfan.sys Sun Sep 24 16:26:48 2006
SPEEDFAN
Reformat and clean install. If the crashes persist, upgrade the bios. If they still persist, it's something with your hardware:
RAM - memtest
HDD - hdd scan S.M.A.R.T.
VGA - Furmark, Future mark vantage
CPU - prime95
Motherboard
Unplug/Remove/Disable devices to locate the cause.
Loading Dump File [F:\a\Minidump\D M P\101010-17362-01.dmp]
Machine Name:
Kernel base = 0xfffff800`03007000 PsLoadedModuleList = 0xfffff800`03244e50
Debug session time: Sun Oct 10 15:18:34.731 2010 (GMT-5)
System Uptime: 0 days 0:00:22.464
BugCheck 3B, {c0000005, fffff80003356916, fffff8800822fad0, 0}
Probably caused by : ntkrnlmp.exe ( nt!CmpAllocateKeyControlBlock+72 )
3: kd> !analyze -v
Arguments:
Arg2: fffff80003356916, Address of the exception record for the exception that caused the bugcheck
Arg3: fffff8800822fad0, Address of the context record for the exception that caused the bugcheck
Debugging Details:
FAULTING_IP:
fffff800`03356916 48895808        mov     qword ptr [rax+8],rbx
CONTEXT:  fffff8800822fad0 -- (.cxr 0xfffff8800822fad0)
rax=0000000000000000 rbx=fffff8000327d040 rcx=fffff8a000c189c0
rdx=fffff88008230508 rsi=0000000000000001 rdi=0000000000000001
rip=fffff80003356916 rsp=fffff880082304a0 rbp=0000000000fd1478
 r8=fffff8a005bc947c  r9=fffff8a0017534a8 r10=fffff8a0010d79a8
r11=0000000000000000 r12=0000000000fd1478 r13=ffffffffffffffff
r14=fffff8a005bc947c r15=fffff8a0017534a8
nt!CmpAllocateKeyControlBlock+0x72:
fffff800`03356916 48895808        mov     qword ptr [rax+8],rbx ds:002b:00000000`00000008=????????????????
BUGCHECK_STR:  0x3B
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff80003356916
STACK_TEXT:
fffff880`082304a0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!CmpAllocateKeyControlBlock+0x72
FOLLOWUP_IP:
SYMBOL_NAME:  nt!CmpAllocateKeyControlBlock+72
MODULE_NAME: nt
STACK_COMMAND:  .cxr 0xfffff8800822fad0 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_nt!CmpAllocateKeyControlBlock+72
fffff800`00bc6000 fffff800`00bd0000   kdcom    kdcom.dll    Tue Jul 14 04:31:07 2009 (4A5BDFDB)
fffff800`03007000 fffff800`035e3000   nt       ntkrnlmp.exe Sat Jun 19 07:16:41 2010 (4C1C44A9)
fffff800`035e3000 fffff800`0362c000   hal      hal.dll      Tue Jul 14 04:27:36 2009 (4A5BDF08)
fffff880`00c00000 fffff880`00c4c000   fltmgr   fltmgr.sys   Tue Jul 14 02:19:59 2009 (4A5BC11F)
fffff880`00c4c000 fffff880`00c60000   fileinfo fileinfo.sys Tue Jul 14 02:34:25 2009 (4A5BC481)
fffff880`00c69000 fffff880`00c76000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 04:29:09 2009 (4A5BDF65)
fffff880`00c76000 fffff880`00c8a000   PSHED    PSHED.dll    Tue Jul 14 04:32:23 2009 (4A5BE027)
fffff880`00c8a000 fffff880`00ce8000   CLFS     CLFS.SYS     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00ce8000 fffff880`00da8000   CI       CI.dll       Tue Jul 14 04:32:13 2009 (4A5BE01D)
fffff880`00da8000 fffff880`00db8000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`00db8000 fffff880`00dd2000   mountmgr mountmgr.sys Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00dd2000 fffff880`00dfc000   ataport  ataport.SYS  Tue Jul 14 02:19:52 2009 (4A5BC118)
fffff880`00e00000 fffff880`00e15000   partmgr  partmgr.sys  Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`00e15000 fffff880`00e2a000   volmgr   volmgr.sys   Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00e2a000 fffff880`00e86000   volmgrx  volmgrx.sys  Tue Jul 14 02:20:33 2009 (4A5BC141)
fffff880`00e86000 fffff880`00e8d000   pciide   pciide.sys   Tue Jul 14 02:19:49 2009 (4A5BC115)
fffff880`00e8d000 fffff880`00e96000   atapi    atapi.sys    Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`00e97000 fffff880`00f3b000   Wdf01000 Wdf01000.sys Tue Jul 14 02:22:07 2009 (4A5BC19F)
fffff880`00f3b000 fffff880`00f4a000   WDFLDR   WDFLDR.SYS   Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00f4a000 fffff880`00fa1000   ACPI     ACPI.sys     Tue Jul 14 02:19:34 2009 (4A5BC106)
fffff880`00fa1000 fffff880`00faa000   WMILIB   WMILIB.SYS   Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00faa000 fffff880`00fb4000   msisadrv msisadrv.sys Tue Jul 14 02:19:26 2009 (4A5BC0FE)
fffff880`00fb4000 fffff880`00fe7000   pci      pci.sys      Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00fe7000 fffff880`00ff4000   vdrvroot vdrvroot.sys Tue Jul 14 03:01:31 2009 (4A5BCADB)
fffff880`00ff4000 fffff880`00fff000   amdxata  amdxata.sys  Tue May 19 20:56:59 2009 (4A12F2EB)
fffff880`01000000 fffff880`01030000   CLASSPNP CLASSPNP.SYS Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`01030000 fffff880`0104b000   USBSTOR  USBSTOR.SYS  Tue Jul 14 03:06:34 2009 (4A5BCC0A)
fffff880`0104e000 fffff880`011f1000   Ntfs     Ntfs.sys     Tue Jul 14 02:20:47 2009 (4A5BC14F)
fffff880`01200000 fffff880`0124c000   volsnap  volsnap.sys  Tue Jul 14 02:20:08 2009 (4A5BC128)
fffff880`0124c000 fffff880`01286000   rdyboost rdyboost.sys Tue Jul 14 02:34:34 2009 (4A5BC48A)
fffff880`01286000 fffff880`0128f000   hwpolicy hwpolicy.sys Tue Jul 14 02:19:22 2009 (4A5BC0FA)
fffff880`0128f000 fffff880`012c9000   fvevol   fvevol.sys   Sat Sep 26 05:34:26 2009 (4ABD7DB2)
fffff880`012cf000 fffff880`0132d000   msrpc    msrpc.sys    Tue Jul 14 02:21:32 2009 (4A5BC17C)
fffff880`0132d000 fffff880`01347000   ksecdd   ksecdd.sys   Tue Jul 14 02:20:54 2009 (4A5BC156)
fffff880`01347000 fffff880`013ba000   cng      cng.sys      Tue Jul 14 02:49:40 2009 (4A5BC814)
fffff880`013ba000 fffff880`013cb000   pcw      pcw.sys      Tue Jul 14 02:19:27 2009 (4A5BC0FF)
fffff880`013cb000 fffff880`013d5000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 02:19:45 2009 (4A5BC111)
fffff880`013d5000 fffff880`013eb000   disk     disk.sys     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`01400000 fffff880`0144a000   fwpkclnt fwpkclnt.sys Tue Jul 14 02:21:08 2009 (4A5BC164)
fffff880`0144c000 fffff880`0153e000   ndis     ndis.sys     Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`0153e000 fffff880`0159e000   NETIO    NETIO.SYS    Tue Jul 14 02:21:46 2009 (4A5BC18A)
fffff880`0159e000 fffff880`015c9000   ksecpkg  ksecpkg.sys  Fri Dec 11 08:03:32 2009 (4B21E0B4)
fffff880`015c9000 fffff880`015d9000   vmstorfl vmstorfl.sys Tue Jul 14 02:42:54 2009 (4A5BC67E)
fffff880`015d9000 fffff880`015e1000   spldr    spldr.sys    Mon May 11 19:56:27 2009 (4A0858BB)
fffff880`015e1000 fffff880`015e8000   speedfan speedfan.sys Sun Sep 24 16:26:48 2006 (45168798)
fffff880`015e8000 fffff880`015fa000   mup      mup.sys      Tue Jul 14 02:23:45 2009 (4A5BC201)
fffff880`01601000 fffff880`017fe000   tcpip    tcpip.sys    Mon Jun 14 06:39:04 2010 (4C15A458)
fffff880`01c3a000 fffff880`01c57000   usbccgp  usbccgp.sys  Tue Jul 14 03:06:45 2009 (4A5BCC15)
fffff880`01c57000 fffff880`01c69000   dc3d     dc3d.sys     Thu Jul 01 13:07:45 2010 (4C2C68F1)
fffff880`01c69000 fffff880`01c71080   HIDPARSE HIDPARSE.SYS Tue Jul 14 03:06:17 2009 (4A5BCBF9)
fffff880`01c72000 fffff880`01c80000   hidusb   hidusb.sys   Tue Jul 14 03:06:22 2009 (4A5BCBFE)
fffff880`01c80000 fffff880`01c99000   HIDCLASS HIDCLASS.SYS Tue Jul 14 03:06:21 2009 (4A5BCBFD)
fffff880`01c99000 fffff880`01ca7000   kbdhid   kbdhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`01ca7000 fffff880`01cb4000   mouhid   mouhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`01cb4000 fffff880`01cc4000   point64  point64.sys  Tue Jun 29 11:54:31 2010 (4C29B4C7)
fffff880`01cc4000 fffff880`01cd2000   monitor  monitor.sys  Tue Jul 14 02:38:52 2009 (4A5BC58C)
fffff880`01cd2000 fffff880`01cf5000   luafv    luafv.sys    Tue Jul 14 02:26:13 2009 (4A5BC295)
fffff880`01cf5000 fffff880`01d16000   WudfPf   WudfPf.sys   Tue Jul 14 03:05:37 2009 (4A5BCBD1)
fffff880`01d16000 fffff880`01d2b000   lltdio   lltdio.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`01d2b000 fffff880`01d7e000   nwifi    nwifi.sys    Tue Jul 14 03:07:23 2009 (4A5BCC3B)
fffff880`01d7e000 fffff880`01d91000   ndisuio  ndisuio.sys  Tue Jul 14 03:09:25 2009 (4A5BCCB5)
fffff880`01d91000 fffff880`01da9000   rspndr   rspndr.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`01da9000 fffff880`01ddf000   fastfat  fastfat.SYS  Tue Jul 14 02:23:28 2009 (4A5BC1F0)
fffff880`02a00000 fffff880`02a22000   drmk     drmk.sys     Tue Jul 14 04:01:25 2009 (4A5BD8E5)
fffff880`02a22000 fffff880`02a35000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 02:21:51 2009 (4A5BC18F)
fffff880`02a35000 fffff880`02a41000   Dxapi    Dxapi.sys    Tue Jul 14 02:38:28 2009 (4A5BC574)
fffff880`02a41000 fffff880`02a4d000   usbprint usbprint.sys Tue Jul 14 03:38:18 2009 (4A5BD37A)
fffff880`02a51000 fffff880`02a7b000   cdrom    cdrom.sys    Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`02a7b000 fffff880`02aa8000   MpFilter MpFilter.sys Sat Mar 20 07:58:08 2010 (4BA463F0)
fffff880`02aa8000 fffff880`02ab1000   Null     Null.SYS     Tue Jul 14 02:19:37 2009 (4A5BC109)
fffff880`02ab1000 fffff880`02ab8000   Beep     Beep.SYS     Tue Jul 14 03:00:13 2009 (4A5BCA8D)
fffff880`02ab8000 fffff880`02ac6000   vga      vga.sys      Tue Jul 14 02:38:47 2009 (4A5BC587)
fffff880`02ac6000 fffff880`02aeb000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 02:38:51 2009 (4A5BC58B)
fffff880`02aeb000 fffff880`02afb000   watchdog watchdog.sys Tue Jul 14 02:37:35 2009 (4A5BC53F)
fffff880`02afb000 fffff880`02b04000   RDPCDD   RDPCDD.sys   Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`02b04000 fffff880`02b0d000   rdpencdd rdpencdd.sys Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`02b0d000 fffff880`02b16000   rdprefmp rdprefmp.sys Tue Jul 14 03:16:35 2009 (4A5BCE63)
fffff880`02b16000 fffff880`02b21000   Msfs     Msfs.SYS     Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`02b21000 fffff880`02b32000   Npfs     Npfs.SYS     Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`02b32000 fffff880`02b50000   tdx      tdx.sys      Tue Jul 14 02:21:15 2009 (4A5BC16B)
fffff880`02b50000 fffff880`02b5d000   TDI      TDI.SYS      Tue Jul 14 02:21:18 2009 (4A5BC16E)
fffff880`02b5d000 fffff880`02ba2000   netbt    netbt.sys    Tue Jul 14 02:21:28 2009 (4A5BC178)
fffff880`02ba2000 fffff880`02bfe000   HdAudio  HdAudio.sys  Tue Jul 14 03:06:59 2009 (4A5BCC23)
fffff880`03c00000 fffff880`03c3d000   portcls  portcls.sys  Tue Jul 14 03:06:27 2009 (4A5BCC03)
fffff880`03c3d000 fffff880`03c4b000   crashdmp crashdmp.sys Tue Jul 14 03:01:01 2009 (4A5BCABD)
fffff880`03c4e000 fffff880`03cd8000   afd      afd.sys      Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`03cd8000 fffff880`03ce1000   wfplwf   wfplwf.sys   Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`03ce1000 fffff880`03d07000   pacer    pacer.sys    Tue Jul 14 03:09:41 2009 (4A5BCCC5)
fffff880`03d07000 fffff880`03d1d000   vwififlt vwififlt.sys Tue Jul 14 03:07:22 2009 (4A5BCC3A)
fffff880`03d1d000 fffff880`03d2c000   netbios  netbios.sys  Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`03d2c000 fffff880`03d49000   serial   serial.sys   Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`03d49000 fffff880`03d64000   wanarp   wanarp.sys   Tue Jul 14 03:10:21 2009 (4A5BCCED)
fffff880`03d64000 fffff880`03d78000   termdd   termdd.sys   Tue Jul 14 03:16:36 2009 (4A5BCE64)
fffff880`03d78000 fffff880`03dc9000   rdbss    rdbss.sys    Tue Jul 14 02:24:09 2009 (4A5BC219)
fffff880`03dc9000 fffff880`03dd5000   nsiproxy nsiproxy.sys Tue Jul 14 02:21:02 2009 (4A5BC15E)
fffff880`03dd5000 fffff880`03de0000   mssmbios mssmbios.sys Tue Jul 14 02:31:10 2009 (4A5BC3BE)
fffff880`03de0000 fffff880`03def000   discache discache.sys Tue Jul 14 02:37:18 2009 (4A5BC52E)
fffff880`03def000 fffff880`03dfb000   dump_dumpata dump_dumpata.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`03e00000 fffff880`03e5a000   usbhub   usbhub.sys   Tue Jul 14 03:07:09 2009 (4A5BCC2D)
fffff880`03e5a000 fffff880`03e6f000   NDProxy  NDProxy.SYS  Tue Jul 14 03:10:05 2009 (4A5BCCDD)
fffff880`03e6f000 fffff880`03e74200   ksthunk  ksthunk.sys  Tue Jul 14 03:00:19 2009 (4A5BCA93)
fffff880`03e7c000 fffff880`03eff000   csc      csc.sys      Tue Jul 14 02:24:26 2009 (4A5BC22A)
fffff880`03eff000 fffff880`03f1d000   dfsc     dfsc.sys     Tue Jul 14 02:23:44 2009 (4A5BC200)
fffff880`03f1d000 fffff880`03f2e000   blbdrive blbdrive.sys Tue Jul 14 02:35:59 2009 (4A5BC4DF)
fffff880`03f2e000 fffff880`03f54000   tunnel   tunnel.sys   Tue Jul 14 03:09:37 2009 (4A5BCCC1)
fffff880`03f54000 fffff880`03f69000   amdppm   amdppm.sys   Tue Jul 14 02:19:25 2009 (4A5BC0FD)
fffff880`03f69000 fffff880`03f72000   wmiacpi  wmiacpi.sys  Tue Jul 14 02:31:02 2009 (4A5BC3B6)
fffff880`03f72000 fffff880`03f93000   raspptp  raspptp.sys  Tue Jul 14 03:10:18 2009 (4A5BCCEA)
fffff880`03f93000 fffff880`03fa2000   mouclass mouclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`03fa2000 fffff880`03fe5000   ks       ks.sys       Thu Mar 04 06:32:25 2010 (4B8F37D9)
fffff880`03fe5000 fffff880`03ff7000   umbus    umbus.sys    Tue Jul 14 03:06:56 2009 (4A5BCC20)
fffff880`03ff7000 fffff880`04000000   dump_atapi dump_atapi.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`04000000 fffff880`04057000   Rt64win7 Rt64win7.sys Fri Sep 03 08:58:32 2010 (4C808E88)
fffff880`04057000 fffff880`04062000   usbohci  usbohci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`04062000 fffff880`04073000   usbehci  usbehci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`04073000 fffff880`04097000   HDAudBus HDAudBus.sys Tue Jul 14 03:06:13 2009 (4A5BCBF5)
fffff880`04097000 fffff880`040a3000   serenum  serenum.sys  Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`040a3000 fffff880`040b3000   CompositeBus CompositeBus.sys Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`040b4000 fffff880`041a8000   dxgkrnl  dxgkrnl.sys  Fri Oct 02 04:00:14 2009 (4AC5509E)
fffff880`041a8000 fffff880`041ee000   dxgmms1  dxgmms1.sys  Tue Jul 14 02:38:32 2009 (4A5BC578)
fffff880`041ee000 fffff880`041fa000   ndistapi ndistapi.sys Tue Jul 14 03:10:00 2009 (4A5BCCD8)
fffff880`041fa000 fffff880`041fb480   swenum   swenum.sys   Tue Jul 14 03:00:18 2009 (4A5BCA92)
fffff880`041fc000 fffff880`041fdf00   USBD     USBD.SYS     Tue Jul 14 03:06:23 2009 (4A5BCBFF)
fffff880`07e00000 fffff880`07e4e000   mrxsmb10 mrxsmb10.sys Sat Feb 27 09:52:28 2010 (4B88CF3C)
fffff880`07e4e000 fffff880`07e71000   mrxsmb20 mrxsmb20.sys Sat Feb 27 09:52:26 2010 (4B88CF3A)
fffff880`07e71000 fffff880`07e81000   MpNWMon  MpNWMon.sys  Sat Mar 20 07:58:00 2010 (4BA463E8)
fffff880`07ead000 fffff880`07f75000   HTTP     HTTP.sys     Tue Jul 14 02:22:16 2009 (4A5BC1A8)
fffff880`07f75000 fffff880`07f93000   bowser   bowser.sys   Tue Jul 14 02:23:50 2009 (4A5BC206)
fffff880`07f93000 fffff880`07fab000   mpsdrv   mpsdrv.sys   Tue Jul 14 03:08:25 2009 (4A5BCC79)
fffff880`07fab000 fffff880`07fd8000   mrxsmb   mrxsmb.sys   Sat Feb 27 09:52:19 2010 (4B88CF33)
fffff880`13c57000 fffff880`13c86000   ndiswan  ndiswan.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`13c86000 fffff880`13ca1000   raspppoe raspppoe.sys Tue Jul 14 03:10:17 2009 (4A5BCCE9)
fffff880`13ca1000 fffff880`13cbb000   rassstp  rassstp.sys  Tue Jul 14 03:10:25 2009 (4A5BCCF1)
fffff880`13cbd000 fffff880`1494ee00   nvlddmkm nvlddmkm.sys Sat Jul 10 00:15:58 2010 (4C37918E)
fffff880`1494f000 fffff880`14950180   nvBridge nvBridge.kmd Sat Jul 10 00:07:54 2010 (4C378FAA)
fffff880`14951000 fffff880`149a7000   USBPORT  USBPORT.SYS  Tue Jul 14 03:06:31 2009 (4A5BCC07)
fffff880`149a7000 fffff880`149e5000   1394ohci 1394ohci.sys Tue Jul 14 03:07:12 2009 (4A5BCC30)
fffff880`149e5000 fffff880`149f0000   rdpbus   rdpbus.sys   Tue Jul 14 03:17:46 2009 (4A5BCEAA)
fffff880`149f0000 fffff880`149ff000   kbdclass kbdclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff960`000c0000 fffff960`003cf000   win32k   win32k.sys   Sat Jun 19 07:31:59 2010 (4C1C483F)
fffff960`00430000 fffff960`0043a000   TSDDD    TSDDD.dll    Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff960`007b0000 fffff960`007d7000   cdd      cdd.dll      unavailable (00000000)
fffff960`00910000 fffff960`00971000   ATMFD    ATMFD.DLL    Thu May 27 07:11:31 2010 (4BFDF0F3)
Unloaded modules:
fffff880`013eb000 fffff880`013f9000   crashdmp.sys
    Checksum:  00000000
fffff880`01030000 fffff880`0103c000   dump_ataport
    Checksum:  00000000
fffff880`0103c000 fffff880`01045000   dump_atapi.s
    Checksum:  00000000
fffff880`02a3e000 fffff880`02a51000   dump_dumpfve
    Checksum:  00000000
lonepalm
SPEEDFAN
RAM - memtest
CPU - prime95
Motherboard
Machine Name:
3: kd> !analyze -v
Arguments:
Debugging Details:
FAULTING_IP:
BUGCHECK_STR:  0x3B
CURRENT_IRQL:  0
STACK_TEXT:
FOLLOWUP_IP:
MODULE_NAME: nt
Unloaded modules:
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
Driver Verifier enabled. Downloaded the Furmark test, but need some advice on what is needed to run and what would help you diagnose it.
Could it possibly be the motherboard? Maybe the memory slots in the motherboard are somehow damaged? I switched the two sticks in the slots and ran the memtest and there was no errors found.... I am quickly running into dead ends here. Any suggestions? I already reformatted the drive and installed a clean version of Windows 7 before I even posted on these forums, so I am pretty sure that won't help at all. I don't know where else to go with this.
