Corrupted icons. Help please
When I want to delete something, my recycle bin icon is missing :
After a Windows update, my disk drives went corrupted as well :
Any fixes? Please help!
You probably need to run a chkdsk to look at your drives.
Then open an Administrative command prompt and check your system files:
SFC /scannow
Then a couple of Anti-virus utilities may find something.
If Windows Update is causing problems, what anti-virus are you running, and do you see any warning messages or failed updates regarding Windows Update?
