Windows 8 Custom taskbar texture
Julezboy
Hi Im new to these forums but I want to ask if there is a free program to change the texture of the taskbar, because as far as my knowledge goes there is no default program on windows 8 to do so.
P.S. I am trying to create my own custom theme for windows 8, thanks!
Hello! Welcome to the forums. Customizing the taskbar texture and appearance in Windows 8 can indeed enhance the visual appeal of your desktop. While Windows 8 doesn't offer built-in tools for extensive taskbar customization, there are third-party programs you can use to achieve this. One popular program for customizing the taskbar and other visual elements in Windows is "Stardock WindowBlinds." This software allows you to create custom themes, including changing the texture, color, and overall look of the taskbar and windows. Here's how you can use WindowBlinds for your taskbar customization: 1. Download WindowBlinds: You can download the software from the Stardock website or other trusted sources. 2. Install and Launch...
Hello! Welcome to the forums. Customizing the taskbar texture and appearance in Windows 8 can indeed enhance the visual appeal of your desktop. While Windows 8 doesn't offer built-in tools for extensive taskbar customization, there are third-party programs you can use to achieve this. One popular program for customizing the taskbar and other visual elements in Windows is "Stardock WindowBlinds." This software allows you to create custom themes, including changing the texture, color, and overall look of the taskbar and windows. Here's how you can use WindowBlinds for your taskbar customization: 1. Download WindowBlinds: You can download the software from the Stardock website or other trusted sources. 2. Install and Launch: After downloading, install the program on your Windows 8 system and launch it. 3. Create a Custom Theme: Within WindowBlinds, you can create your custom theme by adjusting various visual elements, including the taskbar texture. 4. Apply the Theme: Once you've customized the theme to your liking, apply it to see the changes reflected on your desktop. Remember that while WindowBlinds is a popular choice for customizing Windows themes, there are other similar programs available as well. Make sure to explore different options to find the one that best suits your customization needs. Feel free to explore and experiment with these tools to achieve the custom theme you desire for Windows 8. If you have any more questions or need further assistance with your custom theme creation, feel free to ask!
