Microsoft has published an advisory for CVE‑2025‑62218, an elevation‑of‑privilege vulnerability in the Microsoft Wireless Provisioning System that can be triggered locally by an authenticated user and, when successfully exploited, allow a low‑privilege account to gain elevated system privileges. The flaw is described as a race condition / improper synchronization in the Wireless Provisioning component; vendor guidance and multiple independent trackers indicate patches are available and administrators should treat this as a high‑priority local escalation risk for endpoints where the Wireless Provisioning subsystem is present.
Two runners chase a glowing lock atop a pedestal labeled provcore.dll in a cyber security scene.Background / Overview​
What is the Microsoft Wireless Provisioning System?​
The Microsoft Wireless Provisioning System (components often shipped as provcore.dll / provsvc and related modules) is part of Windows’ wireless connectivity stack and provisioning workflows. It handles onboarding, configuration and provisioning of wireless profiles and related device settings for Wi‑Fi and other wireless features. Components in this family interact with drivers, user sessions and privileged system services — which makes defects here more consequential than they would appear at first glance. A missing synchronization primitive or lifecycle check in a privileged provisioning component can expose powerful local escalation primitives because those services commonly execute with elevated privileges.
What the advisory says (concise)​
Microsoft’s Security Update Guide entry for CVE‑2025‑62218 identifies the vulnerability as an elevation‑of‑privilege issue in the Wireless Provisioning System; the vendor lists affected Windows builds and publishes updates to remediate the issue. Independent CVE trackers report the technical class as a race condition that yields a local privilege escalation when triggered by an authorized local account. Public vulnerability aggregators show a base severity in the high range (Feedly lists CVSS ≈ 7.0 for this entry at the time of publication). Administrators should consult Microsoft’s update guide for the exact KB→build mappings before deploying fixes.
Technical analysis​
The flaw: a race condition in a privileged provisioning path​
Race conditions arise when two or more threads or asynchronous operations access shared state without proper synchronization, and the relative timing of their operations produces an unsafe or unexpected state. In privileged Windows services that handle device provisioning, the code frequently creates and releases transient objects (session contexts, device handles, IPC structures) across multiple threads and callbacks. If those lifecycles are not properly coordinated, an attacker who can trigger provisioning flows may force a timing window where a freed resource is reused or referenced incorrectly — enabling memory corruption or logic confusion that escalates privileges. Public reporting for CVE‑2025‑62218 explicitly characterizes the bug as a race/synchronization issue in the Wireless Provisioning System that enables local escalation when exploited.
Likely exploitation chain (high level)​
The canonical exploit chain for this class of vulnerability usually follows predictable steps:
  • Achieve a local foothold — run code as a standard (non‑privileged) user or convince a user to run a local binary or macro.
  • Trigger provisioning flows that allocate short‑lived objects inside the Wireless Provisioning component (for example: profile create/update, device pairing sequence).
  • Force or time a race window where an object is freed while a stale reference remains reachable.
  • Reallocate the freed memory (heap grooming) or otherwise manipulate control/state so that the privileged service later dereferences stale data under SYSTEM context.
  • Convert the resulting memory or logic corruption into token impersonation, service injection, or code execution in the elevated service context.
This UAF/race → control primitive pattern has been used repeatedly in recent Windows escalations and is well understood by exploitation teams — meaning that an initial local foothold plus public PoC material or well‑researched exploitation techniques yields a meaningful risk of full host compromise.
Preconditions and attacker model​
  • Attack vector: Local (authenticated). An attacker needs the ability to run code or otherwise interact locally on the target host. This typically arises from a prior compromise, malicious insider, or tricking a user into running a program.
  • Privileges required: Low (standard user) in most public assessments — the vulnerability is valuable because it elevates from that low privilege to SYSTEM or equivalent.
  • Complexity: Medium to High — reliable exploitation of race conditions often requires careful timing, heap manipulation, or use of replication techniques to increase reliability; however, skilled exploit authors can and do automate these steps.
  • Scope: Single host — this is not a remote unauthenticated wormable RCE by default, but it is a potent post‑compromise escalation primitive that supports lateral movement and persistence.
These characteristics make CVE‑2025‑62218 particularly dangerous in multi‑stage attacks: an adversary who already has code execution as a local user can often convert that foothold into full host control by leveraging this bug.
Confirmed facts and verification​
  • Microsoft lists CVE‑2025‑62218 in its Security Update Guide and has published remediation guidance and updates for affected Windows builds. Administrators should use the vendor’s update guide to map CVE→KB→build before patching. (Vendor advisory reference).
  • Independent vulnerability trackers that aggregate CVE metadata characterize the weakness as a race condition in the Wireless Provisioning System and show a high‑severity impact with local privilege escalation potential; at publication Feedly reported a CVSS in the 7.x range and stated patches are available for supported Windows 10 and Windows 11 branches. If your environment uses these provisioning components, assume the component is probably present across multiple servicing branches until your inventory proves otherwise.
  • Historical context: similar vulnerabilities affecting privileged Windows components — for example use‑after‑free and race conditions in the Windows Connected Devices Platform Service and other networking components — have been used by attackers to pivot from local user to SYSTEM, prompting immediate vendor updates during earlier 2025 patch cycles. The pattern here mirrors those prior incidents: privileged provisioning code + asynchronous workflows = high‑value escalation opportunities.
If any specific technical constant, function name, or exploit‑level detail is encountered in third‑party write‑ups, treat those claims as researcher findings and validate against Microsoft’s official advisories or test systems before using them to build detection or mitigation logic.
Impact assessment​
Who is affected?​
  • Any Windows host that includes the Wireless Provisioning subsystem and the specific vulnerable binaries listed in Microsoft’s advisory (check the Security Update Guide for exact file and KB mappings). Many modern Windows 10 and Windows 11 builds include wireless provisioning components; enterprise images with Wi‑Fi stacks enabled, laptops, and some servers used for management or wireless gateway scenarios are the primary surface. Feedly and other aggregators report the vendor has patched multiple Windows 10 and Windows 11 servicing ladders.
Business impact​
  • On a single compromised endpoint, a successful exploitation can yield SYSTEM privileges. From there an attacker can:
  • Disable security tooling and telemetry.
  • Create persistent services or scheduled tasks.
  • Dump credentials or escalate into domain contexts (via credential harvesting and lateral movement).
  • Tamper with local policy or endpoint configuration.
  • In a targeted environment (for example a laptop used by a privileged administrator), the blow‑out impact is magnified: an attacker who gains SYSTEM on an admin workstation can abuse management tools, sign code, or compromise update/trust tokens.
Risk profile for enterprises​
  • The vulnerability is not a pre‑auth remote exploit, but it is a top priority for defenders because it materially lowers the cost of achieving full host control for any adversary who already has a local foothold.
  • Attackers engaged in nation‑scale or opportunistic intrusions prize high‑reliability escalation primitives like this for lateral movement and persistence.
  • The immediate operational risk is: if endpoints in your environment allow local code execution by non‑privileged users (e.g., developers, contractors, untrusted USB access), the vulnerability increases the probability of rapid host takeover after initial compromise. Historical advisories about the Connected Devices Platform and other privileged service races echo this operational imperative.
Detection, telemetry & hunting guidance​
Short, practical hunt and detection signals defenders should add to EDR/SIEM playbooks:
  • Monitor for crashes or repeated restarts of Wireless Provisioning service components and related modules (provcore.dll or provisioning service names). Sudden or frequent faults in these components can indicate attempts to abuse race conditions. (Service crash telemetry is a high‑signal indicator.
  • Hunt for unexpected process creations from privileged services that historically do not spawn child processes (SYSTEM processes spawning cmd.exe, PowerShell, or unusual binaries).
  • Look for local privilege escalation indicators: scheduled task creation by non‑admin users, creation of new services by unprivileged accounts, or suspicious registry modifications under HKLM\Software\Microsoft\Windows\CurrentVersion\Run.
  • Correlate EDR alerts with local file writes in ProgramData and unexpected modifications to system directories following prov* or wireless stack crashes.
  • Increase logging on host systems that are high value (admin workstations, engineering laptops) and centralize Windows Event Log entries for suspicious service behavior.
  • If your environment supports it, enable advanced memory protection (Attack Surface Reduction rules, WDAC / AppLocker, SmartScreen) and monitor for blocked execution attempts that coincide with provisioning component anomalies.
These detection patterns are built from observed behaviors in analogous Windows EoP incidents patched earlier in 2025 and reflect pragmatic, high‑signal telemetry to prioritize triage.
Mitigation and remediation — prioritized steps​
  • Confirm exposure and affected builds
  • Use Microsoft’s Security Update Guide to map CVE‑2025‑62218 to KB article(s) for each Windows build in your estate. Do not rely on a third‑party CVE string alone; vendor KB mappings are the authoritative source for patch selection.
  • Patch quickly and in stages
  • Stage patches to a pilot group that reflects your diverse hardware and software baseline (laptops, VDI, engineering machines).
  • Verify the patch applied successfully (check KB install state, updated file versions, and that the offending service no longer crashes).
  • Roll out to the broader estate in phased waves; monitor for regressions.
  • If you cannot patch immediately — apply compensating controls
  • Restrict local code execution for non‑admin users: enforce least privilege, remove local admin from standard workstation users, and tighten USB removable media policies.
  • Harden high‑value endpoints (admin workstations) with WDAC/AppLocker to restrict untrusted binaries and script execution.
  • Temporarily limit local access to Wi‑Fi management operations where business processes allow (note: disabling core network services may impact functionality — evaluate risk vs. utility).
  • Increase detection and logging for hosts that cannot be patched within the first 72 hours.
  • Validate and verify patch efficacy
  • After patching, run smoke tests for wireless workflows (profile provisioning, connection, device pairing) and validate that provisioning functionality remains intact where required.
  • Reconcile patch inventory: confirm KB presence across endpoints and remediate failed installations.
  • Post‑patch monitoring
  • Maintain heightened EDR/SIEM hunts for at least 14 days after the mass rollout for residual exploitation attempts or late‑stage adversary activity.
These steps reflect a pragmatic, defense‑in‑depth approach: vendor remediation is primary; compensating controls reduce likelihood when patch windows are constrained.
Critical analysis — strengths, weaknesses, and operational risks​
Strengths (what vendors and defenders did well)​
  • Microsoft published an advisory and supplied updates mapped to affected servicing branches; timely vendor patches remain the most effective countermeasure for memory/logic flaws in privileged components.
  • Independent tracking and community aggregation of the vulnerability class (race condition / EoP) has been rapid, enabling defenders to assess the risk and prioritize patching across affected Windows branches. Feedly and other aggregators report the fixes and affected builds quickly, which helps administrators plan remediations.
Weaknesses and residual risks​
  • Local EoP vulnerabilities by definition depend on a prior foothold. In many enterprise environments, initial access is the main barrier — but the presence of easily exploitable EoP primitives raises the impact of any single initial compromise.
  • Race conditions are notoriously tricky to exploit reliably; however, they can be automated and tuned. Once public proof‑of‑concept code or exploitation frameworks appear, exploitability tends to increase rapidly. At the time of disclosure, public PoCs were not widely reported, but public researcher write‑ups and aggregated trackers often accelerate weaponization. Defenders should assume that reach‑back exploit scripts will proliferate.
  • A recurring operational problem is CVE→KB mapping fragmentation — third‑party CVE feeds or vulnerability scanners sometimes mis‑map identifiers to KBs or builds. Administrators must always validate patch GUIDs against Microsoft’s Security Update Guide to avoid incomplete remediation. This particular issue has been highlighted in other 2025 Windows advisories and remains a material source of patching errors.
Where defenders can fail​
  • Delaying patch rollout for complex test matrices is understandable, but failure to prioritize high‑value endpoints (admin workstations, engineering machines, systems which permit local execution by many accounts) creates predictable risk.
  • Overly aggressive service disablement as a mitigation can break business functionality and drive risky shadow IT workarounds — mitigations must be balanced with operational continuity plans.
Confidence in the technical details and caveats​
  • The vendor (Microsoft) lists CVE‑2025‑62218 in its update guide, which is the authoritative confirmation of the vulnerability and the existence of patches. Treat Microsoft’s advisory as the final reference for KB numbers and affected build ranges.
  • Independent aggregators and security trackers classify the issue as a race condition leading to local privilege escalation; while these community write‑ups are consistent, fine‑grained exploit internals (exact function names, offsets, or private constructs) often appear only in researcher PoCs and should be validated before being used in detection logic. When specific code paths or hard‑coded constants appear in public analysis, label those as researcher claims until corroborated by multiple authoritative sources or vendor technical notes.
  • If your audit or scanning tools show this CVE but you cannot find a matching KB for your exact build, do not assume the host is unaffected — check the MSRC Security Update Guide entry and the exact package mapping, and validate the installed package versions on the host. Fragmented CVE mappings are a known operational hazard.
Practical playbook (quick reference)​
  • Inventory: list all endpoints running wireless provisioning components (provcore, provsvc).
  • Map: lookup CVE‑2025‑62218 in Microsoft Security Update Guide and map to KBs for each build.
  • Pilot: deploy patches to a small, representative pilot; verify functionality and collect telemetry.
  • Remediate: roll out patches broadly with staged windows; prioritize admin workstations and high‑risk devices.
  • Harden: enable WDAC / AppLocker on admin endpoints and enforce least privilege for standard users.
  • Hunt: monitor for provisioning service crashes, suspicious SYSTEM process executions, and local privilege escalation attempts.
  • Validate: confirm remediation via KB presence and file version checks; maintain post‑rollout monitoring.
Final assessment and what to do now​
CVE‑2025‑62218 is a material local elevation‑of‑privilege vulnerability in the Microsoft Wireless Provisioning System. While it is not a remote unauthenticated wormable flaw, it substantially increases the value of any local foothold by allowing reliable escalation to SYSTEM under the right conditions. Microsoft has published updates; independent trackers corroborate the race‑condition classification and recommend rapid patching. Administrators must:
  • Verify exact KB mappings in Microsoft’s Security Update Guide and apply patches promptly to affected builds.
  • Treat endpoints that permit local code execution (e.g., developer machines, admin workstations, BYOD devices) as high priority for remediation and containment.
  • Use compensating controls (least privilege, WDAC/AppLocker, restricted local admin accounts) where immediate patching is impossible.
  • Increase EDR/SIEM hunts for provisioning component crashes and indicators of local privilege escalation.
Finally, be mindful that community write‑ups and PoCs may appear after public disclosure; maintaining a patch‑fast posture and disciplined detection strategy is the most reliable way to blunt operational risk from this class of vulnerability.
An actionable checklist to take off‑the‑shelf now:
  • Confirm whether Wireless Provisioning components are present in your baseline images and inventories.
  • Map CVE‑2025‑62218 to the KB for your Windows builds using Microsoft’s Security Update Guide before deploying patches.
  • Patch pilot → canary → broad rollout; validate each wave.
  • Tighten local privilege and enforce application allow‑listing on high‑value endpoints.
  • Add or tune EDR hunts for service crashes and SYSTEM‑level child process creations immediately after patching.
This vulnerability is a stark reminder that asynchronous, privileged subsystems in modern OSes remain attractive targets for escalation. Prioritize remediation, validate your patch mapping, and harden controls for local code execution to reduce the blast radius of any initial compromise.
