CVE-2025-68233: Tegra DRM PID Leak Fixed in Linux Kernel
A small but important Linux kernel fix published in mid‑December 2025 addresses a resource‑leak in the Tegra DRM driver by adding a missing call to put_pid, closing a PID ownership gap in host1x_memory_context_alloc that could otherwise accumulate kernel PID references over time and lead to resource exhaustion on affected systems.
Neon teal Tegra chip at center, surrounded by PID icons forming a circle, citing CVE-2025-68233.Background / Overview​
The patch tracked as CVE‑2025‑68233 fixes a one‑line ownership bug in the drm/tegra code path: a PID reference returned by get_task_pid was not released in the corresponding allocation path, and the upstream remedy is to call put_pid so the kernel does not leak this reference. This vulnerability record (assigned and published on December 16, 2025) is cataloged in standard vulnerability databases and mirrored across open‑source trackers. The OSV entry and public CVE mirrors summarize the change as “drm/tegra: Add call to put_pid” and link the remediation to several stable kernel commits. At first glance this is not a memory‑corruption or code‑execution bug: it is an ownership/leak correctness fix. But correctness bugs in kernel drivers are operationally significant. Left unpatched, a leak of pid references in a frequently exercised driver path can cause gradual resource exhaustion or unexpected failures in long‑running systems, particularly on embedded devices, appliances, or multi‑tenant hosts that load Tegra DRM components and keep them running for extended periods.
What changed: technical summary​
The root cause in plain language​
The Tegra DRM host1x memory context allocator calls get_task_pid to obtain a reference to a PID structure associated with a task. The code path that performs allocation did not take ownership of that PID reference—meaning it never balanced the get_task_pid with a matching put_pid. Over time, repeated allocations could accumulate unreleased PID references.
The upstream fix simply inserts the corresponding put_pid call at the appropriate failure/cleanup exit so that every get_task_pid is matched by a put_pid when the host1x memory context no longer needs the reference. This turns an indefinite leak into properly paired reference accounting.
Why the fix is correct and low‑risk​
  • It follows standard kernel reference‑counting practice: every get/get that takes a reference must be paired by a put_ when the reference is no longer required.
  • The change is surgical and local to the allocation/teardown path. It does not alter public APIs or widen behavior for legitimate callers.
  • Because the remediation is a simple addition of a put_pid in cleanup paths, it is straightforward to review and backport into stable kernel branches. Upstream maintainers merged the change across stable commits identified in the kernel tree.
Affected components and realistic risk​
Which code and platforms are touched​
  • Component: drm/tegra (Tegra SoC DRM driver). The bug lives in the host1x memory context allocation code invoked when the Tegra DRM stack interacts with task/PID bookkeeping.
  • Affected kernel trees: the fix is recorded in the stable kernel repository and mapped to multiple stable commit hashes; trackers list the stable commits that remediate the issue. The OSV entry maps these commits to the stable tree.
Who should worry most​
  • Embedded devices and appliances shipping vendor/OEM kernels that include Tegra DRM (for example, Tegra‑based automotive, infotainment, robotics, and some IoT gateways).
  • Long‑uptime systems where a leaking kernel object can accumulate over days or weeks and degrade system availability.
  • Multi‑tenant hosts or developer CI runners that may repeatedly mount or use GPU/DRM paths; while Tegra is more common on embedded SoCs than cloud servers, any system that loads the affected driver and exercises the allocation path at scale could be impacted.
Vendor kernel forks (Android device kernels, appliance images) are the long‑tail risk: they sometimes lag upstream stable releases and may omit small patches unless vendors rebase or backport them. The practical exposure for standard desktop distributions will depend on whether the distribution kernels include the Tegra DRM driver and whether that path is exercised often on those machines.
Impact model​
  • Primary impact: availability — resource leakage that over time may surface as kernel resource exhaustion or stability problems.
  • Exploitability: local — the bug does not enable remote code execution on its own; it requires the code path that performs the allocation to be executed on the target system.
  • Short‑term urgency: moderate for enterprise and multi‑tenant infrastructure, high for embedded fleets and devices expected to run continuously without frequent reboots.
How to verify whether you are affected​
Because this is a reference‑leak rather than a crash‑on‑use bug, direct, obvious kernel oops traces may not be present. Use the following pragmatic checks:
  • Identify whether your kernel loads the Tegra DRM modules:
  • lsmod | grep -i tegra
  • lsmod | grep -i drm
  • Check whether your device tree / platform is Tegra‑based (embedded devices, certain SoC‑based boards).
  • Inspect your kernel package changelog or vendor security advisories for CVE‑2025‑68233 or the stable commit IDs listed in the public trackers.
  • If you build kernels from source, search the driver source for the matching put_pid addition (search for put_pid in drivers/gpu/drm/tegra or host1x code paths).
Vendors and distributions commonly map CVE entries to specific kernel package versions in their security trackers; confirm via the vendor changelog rather than relying solely on kernel version numbers. When in doubt, request the vendor to confirm the presence of the specific remedial commit in their kernel binaries.
Detection, hunting, and triage guidance​
Because the vulnerability is a leak, detection is focused on the observable consequences and source‑code verification rather than a reproducible crash signature.
Signals to hunt for​
  • Gradual increase in kernel memory allocations or kernel objects tied to PID bookkeeping on Tegra systems.
  • Service degradations, failures, or OOM‑killer interventions after long uptimes on devices that use Tegra DRM.
  • If you have advanced kernel telemetry (kmem, slabinfo, debugfs counters), look for rising counts in the slab caches associated with pid structures or host1x context objects.
Logs and artifacts​
  • Unlike NULL‑dereference or race bugs, leaked references typically do not produce oops frames. Preserve long‑term telemetry and cumulative memory statistics from representative devices to detect trending leaks.
  • If a device becomes unstable, collect persistent journal logs, dmesg, and any kernel memory diagnostic outputs (kmem, slabinfo). Those traces are useful when interacting with vendors or upstream maintainers.
Practical triage steps​
  • Reproduce in a lab: run the workload that exercises Tegra DRM repeatedly and observe whether object counts or memory use steadily increase.
  • Use kernel debugging tools (slabinfo, kmem) to monitor the specific caches and identify growth patterns.
  • If you build your own kernels, verify the source contains the put_pid fix (search git history for the commit IDs noted in the public trackers).
For broader DRM/driver vulnerabilities and operational guidance on detection and mitigations, the community playbooks for similar DRM fixes provide useful patterns: restrict untrusted access to device nodes, avoid exposing DRM device files to untrusted containers, and maintain careful kernel package inventories for backport verification. These recommendations are consistent with prior advisories for DRM‑related CVEs and are applicable here.
Remediation: patching and mitigations​
Definitive fix​
  • Install a kernel build or vendor package that includes the upstream stable commit(s) fixing CVE‑2025‑68233 and reboot into that kernel. Because this is a kernel‑level change, a reboot is required to remove the vulnerable code path.
How to obtain and verify the patch​
  • Check your distribution’s security tracker or vendor advisory for CVE‑2025‑68233. Look for explicit package versions that include the fix or references to the upstream stable commit IDs.
  • If you compile kernels yourself, pull the stable tree that contains the remedial commit(s) or cherry‑pick the commit hashes referenced in public trackers into your own kernel tree.
  • Verify the source change: confirm the code now includes a put_pid call in the host1x memory context cleanup/teardown path.
  • After installing the updated kernel package, reboot and validate that the running kernel contains the fix (check the package changelog or search the kernel tree used to build the running kernel).
Because vendor kernels may differ significantly from upstream, always confirm the vendor has explicitly included the fix in their release notes or changelogs before considering a device patched. If a vendor patch is not available for embedded images, coordinate with the vendor to request a backport or consider rebuilding kernels with the upstream patch for controlled fleets.
Interim mitigations (if you cannot patch immediately)​
  • Reduce blast radius: limit who can trigger the Tegra DRM path. For embedded appliances, avoid exposing debug interfaces to untrusted users.
  • Shorten uptime windows: schedule periodic safe reboots for devices where a leak could otherwise accumulate state over many days (this is a compensating control, not a substitute for patching).
  • Increase monitoring: add telemetry to detect growing kernel memory usage or slab cache growth and alert when thresholds are crossed.
Vendor and distribution considerations​
  • Embedded/OEM kernels: these are the most likely to require vendor engagement. Many Tegra‑based products ship with vendor‑customized kernels and may not pick up small upstream commits until a larger rebase; vendors should be asked for explicit CVE mappings and backport schedules.
  • Major distributions: standard Linux distros that ship Tegra support in their kernels will typically propagate the upstream stable commits into their kernel packages; check your distro security tracker for mapped fixed versions. For cloud/enterprise images, verify whether Tegra DRM is even present in the kernels shipped to your environment.
Patching embedded fleets often requires device‑by‑device coordination; security teams should triage Tegra‑based devices by criticality and uptime sensitivity, and prioritize vendor‑backed fixes for high‑impact devices.
Risk analysis and operational guidance​
Why a “leak” matters in kernel space​
Even modest leaks in kernel reference counts can become significant on long‑running systems or in environments that stress the affected path. Unlike immediately exploitable memory corruption, leaks accumulate silently, often producing subtle performance degradation or eventual service interruption. For safety‑critical or long‑uptime devices (automotive, medical, industrial), these operational impacts can be costly.
Prioritization heuristic​
  • Highest priority: embedded or appliance fleets running Tegra DRM that must remain up continuously without frequent reboots.
  • High priority: devices or hosts where Tegra DRM is exposed to untrusted workloads or where repeated allocations are common.
  • Medium/low priority: single‑user workstations or systems where Tegra DRM is not loaded or workloads rarely exercise the allocation path.
Where long‑term availability is critical, err on the side of early patching and explicit vendor confirmation. For general‑purpose desktops without Tegra hardware, the practical risk is negligible.
What to say to management and stakeholders​
  • Brief summary: the kernel change fixes a PID reference leak in the Tegra DRM driver. It is a correctness fix to prevent resource leakage; it is not a direct remote code‑execution vulnerability.
  • Operational impact: unpatched embedded devices could, over time, experience degraded stability or service interruption due to leaking kernel PID references.
  • Recommended action: schedule a patch window to install vendor/distribution kernels that include CVE‑2025‑68233, or engage the vendor for backports on embedded devices. In the interim, strengthen monitoring and consider controlled reboots on devices where uptime scheduling permits.
Verification checklist for system administrators​
  • Inventory devices that load Tegra DRM (lsmod, device model checks).
  • Check vendor/distro security trackers for CVE‑2025‑68233 or for the stable commit IDs included in public trackers.
  • If building custom kernels, confirm the put_pid addition is present in the source and rebuild.
  • Deploy updated kernel packages to a test ring, validate device stability and expected functionality.
  • Roll out to production, monitoring kernel telemetry and slab/memory counters for anomalies.
A practical runbook for teams that cannot apply vendor updates immediately: (1) block or restrict access to any interfaces that trigger the vulnerable code path, (2) add memory/slab growth alerts, and (3) schedule reboots for devices at risk of accumulation while awaiting vendor patches.
For more general DRM‑driver hardening and detection playbooks (useful context for mitigation and hunting approaches), community writeups from prior DRM CVEs present tested detection recipes and staged mitigation steps—these are applicable patterns for CVE‑2025‑68233 as well.
Final assessment and cautions​
  • Strengths of the remediation: the upstream fix is minimal, follows kernel reference‑counting conventions, and is straightforward to backport across stable kernel branches; this makes vendor rollouts less risky and faster to deliver.
  • Residual risks: long‑tail devices running vendor kernels may remain exposed until vendors ship backports. Detection is inherently more difficult for leaks than for crash‑or‑oops defects, so telemetry and proactivity are essential.
  • Unverifiable claims / caution: public trackers list stable commit hashes and map affected kernel ranges, but the exact exposure for any given vendor image or product must be validated by inspecting that vendor’s changelog or confirming the commit hash in the vendor‑supplied kernel; do not assume a device is patched based solely on kernel version numbers.
CVE‑2025‑68233 is a focused, low‑surface‑area kernel fix that closes a PID ownership gap in drm/tegra by adding a missing put_pid call. It is not a classical remote code‑execution flaw; rather, it is a correctness fix that removes a leak which could, over time, impact system availability—especially for Tegra‑based embedded devices and vendor kernels that see long uptimes. The practical remediation path is clear: install vendor or distribution kernels that include the upstream stable commits and reboot. For embedded fleets and vendor kernels, operators should insist on explicit confirmation that the fix was backported, and until those backports arrive they should apply compensating monitoring and access controls to limit risk.
