CVE-2023-53370: AMDGPU MES Fence Memory Leak Fixed in Linux Kernels
The Linux kernel received a targeted fix for a memory-leak bug in the AMDGPU DRM driver — tracked as CVE-2023-53370 — that corrects how fences associated with an MES (Micro-Engine Scheduler) queue are cleaned up during ring finalization, closing a local denial-of-service and resource-exhaustion window for systems that load the amdgpu driver.
A gloved hand uses tweezers to place a glowing amdgu_ring_finl label on a ring beside a Linux penguin shield.Background​
The AMDGPU driver is the in‑kernel graphics driver used for modern AMD GPUs, and the DRM (Direct Rendering Manager) subsystem exposes device nodes and ioctls used by userland compositors, media stacks, and GPU workloads. In this specific case, the problem surfaced in the code path that runs MES self tests and in the ring teardown logic: fences created for MES queues were not always freed when a ring was finalized, leaving behind leaked kernel memory objects. The upstream kernel project assigned this issue CVE‑2023‑53370 and merged small, surgical patches into the stable tree to ensure fences are released properly during amdgpu_ring_fini. This remediation and the CVE record are documented by major vulnerability trackers and distribution security pages.
Overview of the bug and why it matters​
What leaked and where​
  • The leak is specific to the MES queue fences used by parts of the amdgpu driver’s self‑test and scheduling logic.
  • When a ring (an execution submission queue) is finalized, the code path responsible for cleanup — amdgpu_ring_fini — failed to free the fence objects in all code paths.
  • Over time, unfreed fence objects accumulate in kernel memory, increasing kernel memory pressure and potentially leading to exhaustion on systems that frequently create/destroy these MES queues.
Practical impact and exposure model​
  • Attack vector: local. The flaw requires code running on the same system to exercise the amdgpu MES test and ring finalization paths.
  • Privileges needed: low in typical desktop setups where user sessions or GPU-accelerated applications can reach DRM interfaces; higher on hardened hosts where device nodes are restricted.
  • Primary impact: resource exhaustion and availability degradation (denial‑of‑service). Leaks in kernel drivers tend to be availability-first issues rather than confidentiality or integrity compromises.
The practical exposure depends on whether the running kernel contains the affected code path and whether the amdgpu module is loaded. On many Linux distributions the driver is included by default for machines with AMD hardware; in cloud, containerized or multi‑tenant environments where GPUs are exposed to untrusted workloads, unpatched hosts present the highest risk. Distribution trackers and advisories have mapped fixed kernel package versions and advised operators to update and reboot.
Technical anatomy — what changed in the code​
Root cause, in plain language​
The driver allocates and attaches synchronization objects called fences to track submitted GPU work on MES queues. If the ring teardown path fails to iterate its MES queue fence list and release each fence, the memory backing those fence objects remains allocated and unreachable — a classic kernel‑space memory leak.
The upstream fix is conservative and precise: ensure all fences associated with MES queues are iterated and freed during ring finalization (amdgpu_ring_fini). The change does not refactor scheduling logic or alter MES semantics — it only guarantees cleanup in all finalization paths. That permits straightforward backporting and keeps regression risk minimal. The kernel project merged this correction into the stable trees and downstream distributions mapped it into kernel updates.
Why small fixes like this are preferable in kernel graphics code​
Kernel maintainers generally prefer surgical edits for driver robustness issues: add the missing cleanup or guard, then merge into stable branches. For hardware drivers, minimizing behavioral change reduces the chance of regressions on the wide diversity of GPU hardware and firmware combinations. The amdgpu MES leak fix follows this pattern: one well‑scoped cleanup insertion rather than a large rewrite.
Who should care and how to check exposure​
High-priority environments​
  • Multi‑tenant hosts, CI runners, and VDI hosts that expose GPU devices to untrusted tenants.
  • Containerized workloads that mount or expose /dev/dri or use GPU device plugins.
  • Developer and lab machines running frequent GPU self-test cycles or stress tools.
  • Vendor/OEM images and appliances where kernel updates may be delayed (the "long tail" problem).
Quick host checks​
  • Verify whether the amdgpu module is loaded: run lsmod | grep amdgpu.
  • Confirm device nodes exist: ls -l /dev/dri/* and note group/permissions.
  • Check kernel package and running version: uname -r and compare distribution advisory mappings for CVE-2023-53370.
If a system uses an older kernel series or a vendor kernel that predates the upstream patch, treat the host as potentially vulnerable until you can confirm the presence of the fix in the installed kernel package changelog.
Remediation and mitigations​
The definitive remediation​
  • Install vendor or distribution kernel updates that include the stable commit(s) fixing the amdgpu MES fence cleanup logic.
  • Reboot into the patched kernel (kernel-level fixes require a reboot to take effect).
Distribution trackers (Debian, Ubuntu, and other vendor advisories) list the fixed package versions and map the upstream commits to those versions; consult your distro’s security pages for the specific kernel package names and versions that include the fix.
When you cannot patch immediately — compensating controls​
  • Restrict access to DRM device nodes. Use udev rules or group membership to limit who can open /dev/dri/*; removing untrusted accounts from video/render groups reduces attack surface.
  • Avoid mounting /dev/dri into untrusted containers. Don’t pass the GPU device into containers unless necessary.
  • Monitor kernel logs and telemetry. Add alerts for kernel oops, repeated amdgpu warnings, or anomalous memory pressure patterns tied to GPU activity.
  • Consider vendor livepatch solutions only if the vendor offers a safe backported livepatch for your kernel and hardware stack; otherwise plan a maintenance window for a full kernel upgrade and reboot.
These mitigations reduce exposure but do not eliminate the bug; the proper fix remains installing the patched kernel and rebooting.
Evidence and independent confirmation​
Multiple authoritative sources independently describe the issue, link to the upstream kernel commits and list fixed package versions:
  • Distribution security trackers (Ubuntu and Debian) record the CVE and list affected/fixed kernel package versions mapping to the upstream stable commits.
  • The OSV (Open Source Vulnerabilities) database entry for CVE‑2023‑53370 enumerates the same description and references the kernel stable commit IDs that implement the cleanup changes.
  • NVD’s initial record lists the high‑level description and references the upstream commits; NVD’s entry shows the record was added and is awaiting full enrichment. Administrators should therefore rely on the distribution and kernel commit mapping for concrete package remediation guidance while NVD completes its processing.
These independent confirmations align: the fix is present in upstream stable branches and has been backported into distribution packages that ship updated kernels.
Risk assessment and analysis​
Strengths of the response and fix​
  • Surgical patching: The upstream correction is limited in scope (ensure fences are freed), which reduces regression risk and simplifies backporting for distributors.
  • Clear distribution mapping: Major distributions have already mapped the upstream commit into fixed kernel package versions and published advisories, enabling straightforward remediation via normal package management workflows.
  • Low probability of remote exploitation: The flaw is local-only and depends on exercising kernel graphics code paths, limiting broad remote attack scenarios.
Residual risks and caveats​
  • Long-tail exposure: Embedded devices, OEM images, and bespoke vendor kernels may lag upstream and remain vulnerable for months unless vendors provide backports. These embedded or appliance images are the most persistent source of residual risk.
  • Operational complexity for patch windows: Patching kernel packages requires reboots. For large fleets or high‑availability environments, coordinating reboots and verifying driver behavior across varied hardware (docking stations, MST hubs, multi‑GPU topologies) can be non-trivial.
  • Detection limitations: Memory leaks do not always produce clear, reproducible error messages. Operators may only see subtle memory pressure symptoms, transient driver warnings, or degraded performance before the issue becomes severe. Robust logging and telemetry are therefore essential.
Exploitability nuance​
While memory leaks are not the same as typical memory‑corruption primitives (UAF/double-free), sustained leaks can drive a system into out‑of‑memory conditions or cause kernel resource exhaustion. That creates a reliable denial‑of‑service path that attackers with local access can exploit. The risk of converting this leak into an elevation-of-privilege or code‑execution condition is low and environment dependent; there is no public authoritative exploit claiming RCE for this CVE at disclosure. Still, availability impacts alone justify prioritizing patching in exposed contexts.
Operational playbook (concise steps)​
  • Inventory and classify systems:
  • Run uname -r, lsmod | grep amdgpu, and ls -l /dev/dri/* to identify hosts that load amdgpu and which users/groups can access device nodes.
  • Consult vendor advisories:
  • Find the distribution package that contains the upstream stable commit referenced for CVE‑2023‑53370 and schedule kernel updates.
  • Patch and reboot:
  • Apply the vendor kernel update and reboot during a maintenance window.
  • Validate:
  • Run representative GPU workloads, hot-plug tests and monitor kernel logs for 24–72 hours to ensure no recurrence.
  • Mitigate when necessary:
  • Restrict /dev/dri access, avoid GPU passthrough for untrusted tenants, and increase kernel oops monitoring until the patch is applied.
Verification notes and cautionary flags​
  • The official NVD entry for CVE‑2023‑53370 was created and lists the upstream commit references, but it was awaiting full NVD enrichment at the time of review; operators should therefore cross‑check vendor changelogs and the kernel stable commit history to confirm the presence of the fix in a given kernel package.
  • Some third‑party trackers show additional metadata (scores, EPSS) that vary; where those numbers are missing or inconsistent, treat severity scoring as secondary to exposure-driven remediation. If a tracker assigns a numeric score, validate that score against your environment’s exposure model rather than treating it as a deployment priority by itself.
CVE‑2023‑53370 is a focused, operationally important kernel vulnerability in the AMDGPU DRM driver: a memory leak from unfreed MES queue fences that can erode kernel memory resources and produce denial‑of‑service conditions on systems that load the amdgpu module. The upstream kernel tree contains a small, low‑risk fix that ensures fences are freed in amdgpu_ring_fini, and major distributions have begun mapping that fix into updated kernel packages. Administrators should prioritize updating kernels on hosts that expose GPUs to untrusted workloads, follow canonical package advisory instructions from their distribution, and apply compensating restrictions (device node permissions, container device policies) for environments that cannot yet reboot. Cross‑checking vendor changelogs and confirming the presence of the stable commit in your kernel package is the reliable way to verify remediation has been applied.
