A recently assigned vulnerability, CVE-2025-68254, patches an out‑of‑bounds read in the Linux kernel’s staging rtl8723bs Wi‑Fi driver by hardening the Extended Supported Rates (ESR) Information Element parsing in OnBeacon handling — a malformed beacon could otherwise force the driver to read beyond the end of a received frame and trigger a kernel panic.
Neon circuit board illustrating 802.11 management frame, OnBeacon, and RT8723 with bounds check.Background​
The rtl8723bs driver lives in the Linux kernel’s staging tree and supports Realtek rtl8723bs-based Wi‑Fi hardware commonly found in low‑power embedded devices and some laptops. Staging drivers historically host code that is functional but not yet matured to mainline kernel quality standards; that makes them more likely to contain memory‑safety bugs that later get tightened up when maintainers or vendors review the code. Public vulnerability trackers have cataloged a small cluster of fixes applied to rtl8723bs in mid‑December 2025 addressing both parsing and buffer‑size handling errors. Information Elements (IEs) are small TLV (type–length–value) substructures inside 802.11 management frames such as beacons and association requests. Code that parses IEs must carefully validate the advertised length bytes and ensure every access falls inside the actual frame buffer. The fix behind CVE‑2025‑68254 targets a specific ESR (Extended Supported Rates) IE parsing path in the OnBeacon handler, where the code accessed offsets (p + 1 + ielen) and (p + 2 + ielen) without confirming those offsets remained inside the frame boundary. A malformed beacon with the ESR IE placed at the very end of the frame could make those pointer dereferences go past the buffer end, producing an out‑of‑bounds read and, in the kernel context, a crash (panic) or other undefined behavior.
What was wrong: a concise technical summary​
  • The vulnerable code parsed the ESR IE by trusting the length byte and then indexing bytes that immediately followed the declared IE body.
  • It performed pointer arithmetic like (p + 1 + ielen) and (p + 2 + ielen) without checking whether the IE body and the two subsequent bytes were actually present inside the received frame buffer.
  • If an attacker or malformed transmitter crafted a beacon whose ESR IE length placed those subsequent bytes beyond the end of the buffer, the driver would read outside the legitimate buffer region, potentially causing data corruption, a kernel panic, or other unpredictable kernel behaviour.
This is classically an out‑of‑bounds read due to insufficient bounds checking on TLV parsing. In kernel context, even a read past user‑supplied memory can be critical: it can result in a denial‑of‑service, information leaks (in some cases), or destabilize the kernel’s memory management and trigger a crash.
How the fix works​
Maintainers added an explicit boundary check to verify that the ESR IE body and the two bytes the code previously accessed actually lie inside the frame buffer before performing any dereferences. In essence the patched logic validates (offset + 2 + ielen) is within the frame limits (or an equivalent bounds test) and only then reads the subsequent bytes. This eliminates the possibility of dereferencing beyond the buffer and prevents that class of out‑of‑bounds read. The corrected patches were staged into the relevant stable kernel release queues.
A cluster of related fixes — why this is bigger than a single CVE​
On the same day maintainers pushed multiple fixes for the rtl8723bs staging driver:
  • CVE‑2025‑68254 — out‑of‑bounds read in OnBeacon ESR IE parsing (this story).
  • CVE‑2025‑68255 — stack buffer overflow in OnAssocReq IE parsing: a Supported Rates IE length was copied into a fixed 16‑byte stack buffer without clamping, allowing a malicious station to overflow the stack buffer. This is a stack corruption vulnerability that was fixed by clamping the copy length.
  • CVE‑2025‑68256 — out‑of‑bounds read in rtw_get_ie parser: the generic IE parser trusted the IE length byte without validating that the body fit in the remaining buffer; the pointer could then be advanced past the end of frame and either read invalid memory or loop indefinitely.
These fixes were bundled during a short, focused clean‑up effort in the rtl8723bs driver, indicating a pattern: the driver’s IE parsing logic systematically trusted length bytes and made unsafe pointer advances. The collective nature of the fixes suggests that vendors and distribution maintainers should review any shipping kernels containing rtl8723bs in staging and treat the group of patches as a single remediation event.
Scope and impact​
Who’s affected​
  • Any Linux system running a kernel that includes the rtl8723bs staging driver is potentially affected. Many distributions incorporate the kernel stable releases that received these fixes; the updated patches appear in the stable release queues and distribution kernel updates (for example, Debian and openSUSE packaging notes reference inclusion).
  • The issue is most relevant for devices where rtl8723bs is in use (e.g., certain embedded Wi‑Fi modules and laptops using that Realtek device). Because rtl8723bs is a staging driver, its presence varies across distributions and hardware images — some vendors ship alternative Realtek drivers or different Wi‑Fi stacks. The exact list of consumer products shipping rtl8723bs is not globally enumerated and therefore cannot be exhaustively stated here; such mapping often requires vendor or hardware‑level confirmation. (This is an unverifiable claim without vendor lists.
Attack vector and exploitability​
  • Network proximity: The vulnerability is triggered by malformed 802.11 management frames (beacons in the case of CVE‑2025‑68254). An attacker needs to supply crafted beacon frames on the same wireless medium as the victim — that means local network proximity (e.g., within radio range), not the public internet. Public trackers note that specially crafted frames sent over the air can produce the crash.
  • Privilege requirements: No local privilege escalation is required to trigger the vulnerable parsing path; the kernel’s Wi‑Fi stack by design processes management frames that arrive over the air. That said, the attacker must be able to transmit Wi‑Fi management frames (i.e., be in radio range and on appropriate frequencies). Attackers may use commodity Wi‑Fi adapters in monitor/managed mode to craft frames.
  • Likelihood of remote exploitation: Because the attack requires being in wireless range, it is not a remote internet‑scale bug. It’s more akin to a local‑network denial‑of‑service or stability bug. Public trackers initially report no known public exploit for these CVEs at the time of disclosure, but the potential for weaponization exists in the sense that an attacker with radio access can reliably crash vulnerable kernels.
Severity assessment​
  • The primary impact is denial of service (kernel panic / crash) due to an out‑of‑bounds read. Out‑of‑bounds reads are generally less dangerous than writes in terms of code execution, but in kernel space a read beyond bounds can still destabilize the kernel and produce exploitable conditions in theory.
  • Public severity metrics for the specific CVE‑2025‑68254 record were pending at initial disclosure; related rtl8723bs IE parsing fixes received high/medium CVSS mappings in some trackers (for neighboring CVEs), which reflects the kernel context and potential for availability impact. Administrators should treat kernel panics on network subsystems as high priority even when remote code execution is not demonstrated.
Evidence from stable kernels and distributions​
Multiple stable kernel releases and downstream distributions incorporated the rtl8723bs fixes:
  • The stable release queues for the 6.17.x family include patches labeled “staging: rtl8723bs: fix out‑of‑bounds read in OnBeacon ESR IE parsing” and the companion rtl8723bs fixes. The stable‑queue repository and release series files show the patch added to 6.17.12.
  • Linux 6.18.1 and 6.17.12 changelogs and kernel change summaries list the rtl8723bs fixes among other staging driver updates, indicating the fixes were merged into recent stable kernels distributed by major vendors and included in release packaging. LWN.net summaries of the 6.17.12 and 6.18.1 releases call out the rtl8723bs fixes in the changelogs.
  • Distribution packaging notes show downstream inclusion: Debian kernel package changelogs and openSUSE commit messages reference the rtl8723bs corrections as part of kernel upgrades (Debian’s linux‑signed and linux source packaging mention the fixes). These distribution changes confirm that distros moved to ship kernels that contain the corrected code.
If you rely on distribution kernels, the most practical route to remediation is to update your distribution’s kernel package rather than patch the driver manually.
Practical mitigation and remediation guidance​
  • Apply vendor/distro kernel updates immediately.
  • Update to the patched kernel versions published by your distribution (for example, kernels based on 6.17.12 and 6.18.1 in the immediate wave of fixes).
  • Reboot systems after applying the kernel update to ensure the new driver code is active. Distribution changelogs and kernel release notes indicate these versions contain the stable patches.
  • If you cannot update rapidly, reduce exposure:
  • Disable the rtl8723bs driver or unload it temporarily on systems where that driver is in use and where disabling Wi‑Fi is acceptable. Blacklisting is a common temporary measure (e.g., add a modprobe blacklist entry for rtl8723bs), but be aware that blacklisting disables the device and any dependent services. Ensure you have alternative network connectivity before doing so.
  • Put sensitive systems in wired‑only mode or move them to a separate VLAN/segment that removes the immediate need for Wi‑Fi during patching windows.
  • Network‑level mitigations:
  • Reduce the attack surface by only connecting to trusted SSIDs and avoid associating with open/unknown access points in untrusted locations.
  • Use host firewalling and service isolation to limit cascading impacts when a crash occurs (e.g., ensure critical services are on independent hosts or containers so a single kernel panic does not take down a multi‑tenant stack).
  • Monitoring and detection:
  • Watch for unexplained kernel panics or repeated dmesg traces referencing rtl8723bs or rtw_mlme/rtw_get_ie code paths — these likely indicate trigger attempts or other driver faults.
  • Enable kernel crash dumps (kdump) and collect crash logs for forensic analysis if you suspect malicious frames have been received.
  • Long‑term: prefer maintained drivers and upstreamed code
  • Where possible, prefer upstreamed, well‑maintained drivers (those that live in mainline kernel trees and receive broad testing). Staging drivers are transitional; vendors and system builders should monitor staging drivers for follow‑on fixes or upstream replacements.
  • For device vendors using rtl8723bs silicon, coordinate with the hardware vendor for any recommended firmware updates or alternative driver suggestions.
Risks and caveats — an analyst’s view​
  • Attack reach vs. severity: While the need for radio proximity limits large‑scale remote exploitation, the bug is significant for environments where wireless is an attack vector (airports, coffee‑shop scenarios, industrial sites). An attacker positioned near targets — including a malicious drone, a laptop, or a rogue access point — can craft beacon frames to trigger crashes across multiple devices, producing an effective denial‑of‑service in a localized area. Administrators in such contexts should prioritize updates.
  • Not all devices are vulnerable: The presence of rtl8723bs and the staging driver varies across devices and distributions. Some systems may ship alternate Realtek drivers (rtl8xxxu, rtw88) or vendor‑patched firmware that obviates the staging driver usage. Mapping vulnerability to inventory requires checking the kernel version and loaded modules on each system. This granular inventory step is essential but often time‑consuming in heterogeneous fleets. (This hardware‑specific mapping is difficult to enumerate reliably from public sources.
  • No immediate public exploit code reported as of the initial disclosures: Public trackers initially reported no published exploit code for CVE‑2025‑68254 at disclosure time; however, the vulnerability model (crafted wireless frames causing panics) is straightforward to exploit in practice for an attacker with the right tools and proximity. As always, “no public exploit today” does not equal “no risk tomorrow.”
  • Information leakage vs. code execution: The patched vulnerability is documented as an out‑of‑bounds read, which usually leads to crashes or possibly information disclosure in user space depending on memory layout. There is no public evidence at disclosure that this turns into remote code execution; however, kernel memory corruption patterns are notoriously subtle and can sometimes be leveraged for privilege escalation under the right conditions. Hence the fixes should be treated seriously.
Recommended checklist for system administrators​
  • Inventory: Identify systems running the rtl8723bs kernel module.
  • Run: lsmod | grep rtl8723bs (or check dmesg for rtl8723bs logging).
  • Confirm kernel versions (uname -r) and distribution packaging.
  • Update: Apply your distribution’s kernel updates that include the rtl8723bs fixes (for example, the 6.17.12 or 6.18.1 series where patches were merged into stable queues) and reboot. Distribution notes show these kernels carry the patches.
  • Temporary mitigation (if you cannot patch immediately):
  • Blacklist the rtl8723bs module or physically disable the Wi‑Fi interface.
  • Restrict Wi‑Fi usage and limit device exposure to untrusted networks.
  • Monitor: Collect and analyze kernel crash dumps, and watch security bulletins for any follow‑on advisories or proof‑of‑concept code releases.
  • Vendor coordination: If you deploy vendor OS images (OEM kernels, embedded Linux images), contact your vendor to confirm their timeline for integrated patches.
CVE‑2025‑68254 is a classic example of the kind of memory‑safety issue that appears in staging kernel drivers: IE parsing that trusts length bytes without full boundary verification. The immediate consequence is denial of service via kernel panic caused by an out‑of‑bounds read in the rtl8723bs OnBeacon ESR IE parsing path. Maintainers produced a focused set of fixes — including boundary checks and buffer clamping — and those patches landed in the stable kernel release queues and downstream distribution packages (e.g., kernels in the 6.17.12 and 6.18.1 families). Administrators should prioritize applying vendor or distribution kernel updates and, where updates are delayed, use temporary mitigations such as driver blacklisting or disabling Wi‑Fi on critical hosts. Given the proximity‑based attack model, the highest risk settings are those where adversaries can broadcast crafted management frames to targets (physical, public, or industrial wireless environments), and defenders in those contexts should treat the fixes as urgent.
