CVE-2026-45496: Update Visual Studio Code for Important Bypass
Microsoft has classified CVE-2026-45496 as an Important Visual Studio Code security feature bypass, giving developers and administrators a clear reason to update the editor rather than waiting for the next routine maintenance cycle. The vulnerability was published through the Microsoft Security Response Center on July 14, 2026, as part of Microsoft’s unusually large July security release.
Microsoft’s advisory confirms the existence of the flaw but currently exposes few technical details outside the interactive Security Update Guide. BleepingComputer’s July Patch Tuesday inventory also lists CVE-2026-45496 as Important, alongside two additional Visual Studio Code security feature bypasses and a separate VS Code remote-code-execution vulnerability.
That grouping makes the immediate response straightforward: check every managed and unmanaged VS Code installation, move it to Microsoft’s latest serviced release, and confirm that automatic updates have not been disabled by policy, packaging, or user configuration.
Cybersecurity dashboard showing a code editor, security warning, compliance metrics, and a cracked shield graphic.A Bypass Is Not the Same as a Direct Compromise​
Microsoft’s security feature bypass classification describes a weakness that can defeat or circumvent a protection built into the product. It does not, by itself, establish that CVE-2026-45496 gives an attacker arbitrary code execution, administrator privileges, or control of a computer over the network.
The distinction matters because Microsoft separately identifies CVE-2026-50520 as a Visual Studio Code remote-code-execution vulnerability in the same July release. CVE-2026-45496 should not be described as an RCE simply because both affect the editor or arrived on the same day.
At the time of publication, Microsoft had not made enough accessible technical information available to determine precisely which VS Code boundary is bypassed. The editor contains several protections that could potentially fall under this category, including Workspace Trust, Restricted Mode, link handling, webview isolation, extension controls, browser integration, command approvals, and safeguards surrounding agent-driven operations. Without confirmation from Microsoft, attributing CVE-2026-45496 to any one of those systems would be speculation.
Microsoft’s confidence language should also not be confused with the vulnerability’s severity. Confidence measures how firmly the vulnerability and its technical description have been established; it does not measure the damage an attacker could cause. A confirmed vulnerability can still require significant user interaction or local access, while a technically uncertain report can describe a potentially severe outcome.
The Important rating therefore provides useful prioritization, but not a complete attack narrative. Administrators still need Microsoft’s attack-vector, user-interaction, exploitation and affected-version fields before they can calculate environmental risk with precision.
VS Code Now Sits Inside the Enterprise Trust Boundary​
The practical importance of a VS Code flaw extends beyond editing source files. Modern installations routinely connect to Git repositories, package registries, remote development hosts, containers, Windows Subsystem for Linux distributions, GitHub accounts and cloud development environments.
Extensions add another layer of privilege and connectivity. Depending on their purpose and configuration, they may read workspace files, start processes, invoke language servers, connect to external services or access authentication flows. A bypass affecting how VS Code distinguishes trusted from untrusted content could consequently matter even when the initial flaw does not directly execute code.
Recent releases have expanded that security surface further. Visual Studio Code 1.126 highlighted Workspace Trust and the option to open new folders in Restricted Mode, while VS Code 1.125 introduced a preview of browser traffic proxied through remote workspaces. Microsoft has also been adding enterprise controls for extension updates and managed GitHub Copilot settings.
Those features are not evidence of where CVE-2026-45496 resides. They do demonstrate why security teams should no longer treat VS Code as a simple text editor with a low-value configuration footprint.
A developer workstation can hold repository credentials, signing material, deployment tokens, local environment files and access to production-adjacent systems. Even a security-control bypass with limited direct impact may become useful when chained with a malicious repository, compromised extension, deceptive prompt or another vulnerability.
That chaining risk is especially relevant this month because CVE-2026-45496 is not an isolated VS Code entry. Microsoft’s July inventory includes:
  • CVE-2026-50520, classified as a Visual Studio Code remote-code-execution vulnerability.
  • CVE-2026-57101 and CVE-2026-57102, both classified as Visual Studio Code security feature bypasses.
  • CVE-2026-41109, affecting GitHub Copilot and Visual Studio Code as another security feature bypass.
  • CVE-2026-47282, affecting GitHub Copilot and Visual Studio Code with an information-disclosure impact.
Microsoft rates each of those entries Important. Their simultaneous publication supports patching the editor as a package rather than attempting to prioritize CVE-2026-45496 in isolation.
Update Status Must Be Verified, Not Assumed​
Visual Studio Code normally updates frequently, and Microsoft recommends using Check for Updates to obtain the newest release immediately. That convenience can create a blind spot in organizations where administrators assume the updater is functioning everywhere without checking the installed build.
Windows endpoints may receive VS Code through the user installer, system installer, Microsoft Store, WinGet, Configuration Manager, Intune or another software-distribution platform. Portable deployments, virtual desktop images, build machines and developer jump boxes can follow entirely different servicing paths.
The first task is therefore inventory. Administrators should collect the VS Code version and installation channel from Windows developer devices, including machines used through Remote Desktop and persistent virtual desktops. The About dialog and the code --version command provide quick local checks, while software inventory and endpoint-management tools are better suited to fleet-wide verification.
Teams should then compare those results with the version Microsoft identifies as containing the July fixes. Where the Security Update Guide or release channel has not yet exposed a clear fixed-build mapping, the safest operational approach is to deploy the newest Microsoft-signed stable build available and revisit the advisory when Microsoft adds affected-version details.
Automatic updating also deserves scrutiny. VS Code 1.125 introduced more control over delayed extension updates, and organizations can centrally manage relevant settings. Editor updates and extension updates are separate concerns, however; allowing Marketplace extensions to update does not prove that the VS Code application itself has received its security fixes.
Security teams should pay particular attention to systems where updates are intentionally frozen for compatibility. A version pin may protect a critical extension or development workflow, but it also leaves the editor outside Microsoft’s current security baseline. Any exception should be documented, time-limited and paired with restrictions on untrusted workspaces and repositories.
Restricted Mode Remains the Sensible Holding Position​
Until Microsoft publishes fuller technical details, administrators have limited vulnerability-specific mitigations to evaluate. General VS Code hardening remains appropriate, particularly for developers who inspect outside repositories, proof-of-concept code, downloaded project archives or unsolicited coding assignments.
Workspace Trust should remain enabled, and unfamiliar folders should initially open in Restricted Mode. Users should avoid approving trust simply to remove warnings or restore convenience, especially when the project originated from an unknown person or public download.
Extension inventories should receive similar attention. Unused extensions increase attack surface and can complicate incident response by adding background processes, network connections and authentication providers. Enterprise teams should restrict extension sources where possible and investigate unexpected publisher changes, new dependencies or requests for additional access.
These controls are not substitutes for the update. A security feature bypass is, by definition, a warning that a protection may not hold under particular conditions. Hardening can reduce opportunities for exploitation, but only Microsoft’s corrected build can remove the vulnerable behavior identified as CVE-2026-45496.
The next meaningful milestone is a fuller MSRC record identifying the affected and fixed VS Code versions, attack requirements and exploitation status. Until those fields are available, updating Visual Studio Code and verifying the resulting build across the fleet is the defensible response—not guessing which protection the vulnerability bypasses or assuming a background updater has already handled it.
References​
  1. Primary source: MSRC
  2. Related coverage: code.visualstudio.com
  3. Related coverage: techradar.com
  4. Related coverage: itpro.com
