**************************Mon Jul 29 22:00:12.045 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\072913-17175-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Built by: 7601.18113.amd64fre.win7sp1_gdr.130318-1533
System Uptime:0 days 9:38:42.777
*** WARNING: Unable to verify timestamp for aswMonFlt.sys
*** ERROR: Module load completed but symbols could not be loaded for aswMonFlt.sys
Probably caused by :aswMonFlt.sys ( aswMonFlt+5010 )
BugCheck 19, {20, fffff8a004809000, fffff8a004809420, 5420400}
BugCheck Info: Link Removed
Arguments:
Arg1: 0000000000000020, a pool block header size is corrupt.
Arg2: fffff8a004809000, The pool entry we were looking for within the page.
Arg3: fffff8a004809420, The next pool entry.
Arg4: 0000000005420400, (reserved)
BUGCHECK_STR: 0x19_20
PROCESS_NAME: System
FAILURE_BUCKET_ID: X64_0x19_20_aswMonFlt+5010
CPUID: "Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz"
MaxSpeed: 3600
CurrentSpeed: 3602
BIOS Version 1103
BIOS Release Date 04/10/2012
Manufacturer System manufacturer
Product Name System Product Name
**************************Sun Jul 28 18:39:55.301 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\072813-14586-01.dmp]
System Uptime:0 days 5:20:37.145
Probably caused by :Pool_Corruption ( nt!ExDeferredFreePool+100 )
BugCheck 7E, {ffffffffc0000005, fffff800031f99bc, fffff880065d2618, fffff880065d1e70}
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff800031f99bc, The address that the exception occurred at
Arg3: fffff880065d2618, Exception Record Address
Arg4: fffff880065d1e70, Context Record Address
BUGCHECK_STR: 0x7E
FAILURE_BUCKET_ID: X64_0x7E_nt!ExDeferredFreePool+100
MaxSpeed: 3600
CurrentSpeed: 3602
BIOS Version 1103
**************************Sat Jul 27 22:41:42.602 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\072713-14851-01.dmp]
System Uptime:0 days 10:14:26.445
Probably caused by :memory_corruption ( nt!MiBadShareCount+4c )
BugCheck 4E, {99, 25001, 1, 25901}
Arguments:
Arg1: 0000000000000099, A PTE or PFN is corrupt
Arg2: 0000000000025001, page frame number
Arg3: 0000000000000001, current page state
Arg4: 0000000000025901, 0
BUGCHECK_STR: 0x4E_99
PROCESS_NAME: chrome.exe
FAILURE_BUCKET_ID: X64_0x4E_99_nt!MiBadShareCount+4c
MaxSpeed: 3600
CurrentSpeed: 3602
BIOS Version 1103
**************************Fri Jul 26 21:22:03.428 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\072613-14632-02.dmp]
System Uptime:0 days 1:50:51.271
BugCheck 4E, {99, 36a24, 0, 109ca4}
Arguments:
Arg2: 0000000000036a24, page frame number
Arg3: 0000000000000000, current page state
Arg4: 0000000000109ca4, 0
MaxSpeed: 3600
CurrentSpeed: 3602
BIOS Version 1103
**************************Fri Jul 26 19:03:12.864 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\072613-14632-01.dmp]
System Uptime:0 days 4:20:47.660
Probably caused by :ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+35084 )
BugCheck 1A, {41790, fffffa8000fade50, ffff, 0}
Arguments:
Arg1: 0000000000041790, A page table page has been corrupted. On a 64 bit OS, parameter 2
contains the address of the PFN for the corrupted page table page.
On a 32 bit OS, parameter 2 contains a pointer to the number of used
PTEs, and parameter 3 contains the number of used PTEs.
Arg2: fffffa8000fade50
Arg3: 000000000000ffff
Arg4: 0000000000000000
BUGCHECK_STR: 0x1a_41790
PROCESS_NAME: privoxy.exe
FAILURE_BUCKET_ID: X64_0x1a_41790_nt!_??_::FNODOBFM::_string_+35084
MaxSpeed: 3600
CurrentSpeed: 3602
BIOS Version 1103
