BMTS
I've been getting BSOD crashes increasingly for the past couple of months, it started out as a couple times a month, and now its multiple times a day. Mostly UNEXPECTED_STORE_EXCEPTION and CRITICAL_PROCESS_DIED.
I don't know if this is relevant, but i replaced my hard drive a couple months back after i ran crystaldiskinfo and found it to be damaged, i've checked and my current hard drive is healthy. Any help would be much appreciated.
Alright yeah i tested both with OCCT and i had no problems when using onboard GPU, but went back to crashing when i put my nvidia gpu back in. I think im just going to replace my GPU now. Thanks for your help again, i really appreciate it.
I see someone already answered but yes it's a possibility.
I'd also check your cabling.
I'll check on the dump file and post back.
BugCheck 1A, {6001, ffffffffc000000e, 6f50000, ffffad0e2d688d90}
Probably caused by : memory_corruption
Followup:     memory_corruption
if your psu is in doubt then you'd probably find your machine blue screening when it's stressed so try running something like Prime95.
Monitor your system temperatures using HWiNFO64 as this keeps a record of least, max and average temps attained.
How old is the PSU?
Did you check Device manager for any yellow marks?
Also if you have surge protectors on everything i wonder if one or more have become faulty in some way.
Is it possible for you to cut down on some or try a different arrangement?
Content Advisory 38%
This content has been flagged as potentially violating community guidelines.
Primary concern: sexual_minors
Our community guidelines help ensure a respectful environment for all members.
AI Content Assessment · May 21, 2025
BMTS
My PSU is 2/3 years old, no yellow marks in device manager. What i should do in prime95? just run a blend stress test?
BugCheck 154, {ffff80047e8f0000, fffff10889a96390, 2, 0}
Probably caused by : hardware_disk
Followup:     MachineOwner
So where did you get to regarding surge protectors? As the machine reacted after you made changes in this area it might be worth pursuing?
As your sockets have built in protectors try, if you can, moving to another outlet/socket.
Drivers.
I've gone trough your drivers/apps but nothing jumped out as a possible suspect so consider anything third party as suspect.
Go through your applications and anything which is either old or no longer used either update or remove.
Lastly, if you only installed Windows 10 on the drive once then I would try a further clean install.
BMTS
I've clean installed windows onto it twice, the only programs i have installed on it are: steam(dota 2), spotify, google chrome, discord, winrar, and notepad++. They are all up to date. I've plugged my pc directly into the wall now instead of plugging it in the surge protected power strip. I'm not sure if its responded to anything as its very inconsistent. Sometimes it won't happen for a while, sometimes it just keeps happening repeatedly. Usually when it crashes i am running a demanding game.
See how you go with the socket change but if you do bsod again this time run a stress test on the gpu.
Furmark is a handy tool for stressing the gpu and can be found here: FurMark > Home
Something else to consider if your only blue screening with a demanding game is overheating. I don't just mean with the gpu but also the cpu.
The temps may seem fine when evrything is quiet ingame but once the mayhem starts temps can quickly rocket. I know this from experience and was actually shocked to see how hot the cpu was actually running at.
If you use HWiNFO64 when gaming you'll get a history of lowest, highest and average temps gained.
the dump files were similar to your last which shed no light on the gpu situation.
As you see no blue screen when stressing the cpu leads me to think that your PSU is probably ok otherwise you'd bsod whatever you stressed.
Try reducing the clocks on the card first and see if that helps.
Reduce the core as well as memory by 100mhz and test again.
See if you can get to a point where the machine/gpu doesn't crash
Check the card over for dust build up plus did you monitor the temps at all as it may simply be overheating?
BMTS
I did, and i don't think its an overheating issue as they crashed a lot at about ~60C and maxed out around ~85C.
Now as with the clocking, im not too familiar with it. I tried lowering the core clock speed as well as memory and i still crash, however i noticed something i thought was weird. My core clock only goes to 540 MHz when im pretty sure my graphics card should be capable of a lot more than that (GTX 960).
An image from 'Daily BSOD crashes.'. NVIDIA Control Panel showing custom GPU clock speeds and cooling settings for a GeForce GTX 960.
Hmm.. Try reseating the card and then checking what GPU-Z say's:
TechPowerUp
Also another app to check and make changes is the following app:
See if they say anythng different.
BMTS
All those programs seem to give me different information. One thing i noticed is that if i turn anti surge protector on and i run the gpu stress test, it will immediately trigger and turn my PC off. So i definitely thinking there is something fishy going on between my PSU/GPU. I turned my clocks as low as possible to no avail. in fact, when i did that i got an error saying "overclock failed" on my next startup.
An image from 'Daily BSOD crashes.'. Screens show GPU settings, monitoring, and clock speeds for a GeForce GTX 960 graphics card.
As i mentioned above when you stress test the cpu the system runs fine so I'm not convinced it's totally down to the psu just yet.
One thing that keeps cropping up is this 'surge protector'. You say above that if it's turned on the gpu will crash under stress testing.
Have you tried stress testing without the surge protector enabled?
If no bsod occurs then you might be looking at a faulty surge protector?
