Directing programs to different audio devices.
Hi.
My problem being I wanna play games with my headset, but at the same time listen to music via speakers. Is it possible to direct audio to different audio devices? I had a program that could do it once, but it cost money so I uninstalled it after the trial. There must be a code or something that's easy enough I would assume. Don't wanna pay like 50€ for something that could be done for free.
Any advice is welcome!
Thanks!
Neemobeer
Windows Forum Team
Other than a given program having the ability to redirect it's own audio, I don't believe there is a way to do this natively. This program looks like it may work but it does cost $20 CheVolume, Liberate your Audio.
Windows Forum Admin
Microsoft MVP
I might be totally wrong in this but if you have Realtek onboard audio then you may have the same settings as arrowed here:
You can see by what's arrowed that a audio stream can be enabled for the back of the pc as well as the front. I've never tried to do this myself so I cannot advise you further but it might be worth a go? (if you have the same or similar set up that is)..
