Windows 11 Shared Audio Preview Streams to Two LE Audio Devices
Windows 11’s latest Insider preview quietly starts a small but meaningful change to how PCs share sound: a new Shared audio (preview) experience built on Bluetooth LE Audio that lets a Copilot+ PC stream the same audio to two separate headsets, earbuds, speakers, or hearing aids at once. The feature arrives as part of Windows 11 Insider Preview Build 26220.7051 in the Dev and Beta channels, and Microsoft is rolling it out gradually to supported Copilot+ systems after users install OS and driver updates. Early adopters in the Insider program can enable the feature from Quick Settings, pair two LE Audio accessories, and begin a shared session — but the deeper story is about what LE Audio brings (LC3, Auracast-style broadcast) and the practical limits Windows has chosen for its first public test.
Windows laptop with Shared audio control, Bluetooth earbuds and wireless headphones on the desk.Background: why LE Audio matters (and where shared audio fits)​
Bluetooth LE Audio is the next-generation Bluetooth audio architecture. It replaces—or rather augments—Classic Bluetooth audio with a new codec (LC3), support for multi-stream topologies, and broadcast/broadcast-assistant capabilities commonly grouped under the Auracast name. Those building blocks enable several things that consumers and device makers have wanted for years:
  • Better efficiency: the LC3 codec delivers higher perceived audio quality at lower bitrates than the old SBC codec, which reduces radio time and power consumption.
  • Multi-stream audio: independent, synchronized left/right or multi-channel streams for true wireless earbuds and other use cases.
  • Broadcast audio (Auracast): the ability to advertise an audio stream and let multiple receivers subscribe without classic one-to-one pairing.
Microsoft’s new Shared audio (preview) is a pragmatic, Windows-focused implementation of these primitives. It doesn’t try to be a universal Auracast transmitter for an unlimited audience on day one. Instead, the preview exposes a controlled experience: a Copilot+ Windows 11 PC can transmit the same audio stream to two paired LE Audio sinks simultaneously through a Quick Settings control. The approach gives Microsoft a manageable scope to validate user scenarios, driver interoperability, and UX flows before expanding functionality more broadly.
What Microsoft released (what’s in Build 26220.7051)​
The Insider preview that began rolling out contains the first public-facing Shared audio (preview) experience tied to the Windows 11 Quick Settings area. Essential details of the rollout:
  • The feature appears as a “Shared audio (preview)” tile in Quick Settings once the PC has the required OS and driver updates.
  • Users choose two compatible, paired, and connected LE Audio accessories and click Share to start transmitting a single audio stream to both devices.
  • A Stop sharing button ends an active session.
  • The initial rollout targets select Copilot+ PCs with compatible Bluetooth and audio driver updates; Microsoft has published a list of models that are supported now and a list that will be added soon.
  • Microsoft explicitly recommends updating accessory firmware via the manufacturer’s app; if an accessory fails to show in the tile after update, the advised fix is to remove and re-pair.
The company frames Shared audio as social and accessibility-driven: students sharing music in study sessions, families watching a movie together on a flight, and direct streaming to LE Audio hearing aids.
Which PCs and accessories are supported right now​
Microsoft’s preview restricts Shared audio to a set of Copilot+ PCs — Windows systems shipped or certified with the Copilot+ branding and supporting the required Bluetooth stack and audio drivers. The initial, available today list includes recent Surface models equipped with Qualcomm Snapdragon X silicon (the 13.8-inch and 15-inch Surface Laptop and their business variants, plus the 13-inch Surface Pro and business variant). A coming soon list names Samsung Galaxy Book5 / Book5 Pro SKUs (Intel Core Ultra Series 200) and additional Surface SKUs and Galaxy Book4 Edge configurations.
On the accessory side Microsoft lists a representative set of LE Audio-capable devices that work in the preview: Samsung Galaxy Buds2 Pro, Buds3, Buds3 Pro, Sony WH-1000XM6, and recent LE Audio hearing aids from vendors such as ReSound and Beltone. Those device names are illustrative rather than exhaustive; the feature is compatible with a broader set of LE Audio accessories so long as firmware and profiles are updated to support LE Audio/LC3.
How to try the preview (step‑by‑step)​
  • Enroll a compatible Copilot+ PC in the Windows Insider Program (Dev or Beta channel).
  • Install Windows Update until your system shows the latest build and the complementary Bluetooth/audio driver updates.
  • Update the firmware of your Bluetooth accessories via the manufacturers’ app (this is strongly recommended).
  • Pair and connect two LE Audio-capable accessories to the PC.
  • Open Quick Settings and tap the Shared audio (preview) tile; select the two connected accessories and click Share.
  • Use the Stop sharing control to end the session.
If an accessory is paired and connected but doesn’t appear in the Shared audio selection, remove it from the PC and re-pair after verifying firmware and apps are up to date.
The technical underpinnings: LC3, broadcast tech, and synchronization​
Shared audio is built on LE Audio technology — specifically the same architecture that enables Auracast broadcast and LC3 streaming. That matters because:
  • LC3 reduces bitrate while delivering equivalent or better perceived quality compared to older codecs. That efficiency translates into lower power draw for earcups and slimmer bandwidth requirements for the host radio.
  • Broadcast/broadcast-like delivery provides a mechanism for the source to push a synchronized stream to multiple sinks. In theory, Auracast supports many simultaneous listeners; Microsoft’s preview caps the Windows implementation to two receivers, likely to balance complexity and to ensure a controlled test surface for sync and quality.
  • Synchronization is central to the experience: two people watching the same video expect lip-sync parity between their ears. LE Audio’s multi-stream and isochronous transport mechanisms are designed for microsecond‑level sync, but real-world synchronization still depends on firmware, host stack behavior, and driver scheduling on the PC.
In practice, Shared audio likely uses a broadcast or broadcast-like BIS (Broadcast Isochronous Stream) mechanism under the hood, with Windows managing which paired sinks participate in the shared stream and coordinating any necessary per-sink codec parameters.
The good: practical benefits and accessible outcomes​
  • True social listening without cables: the preview offers a fast, straightforward way to share audio between two people without splitting cables, hardware dongles, or third‑party "party mode" hacks.
  • Better battery efficiency than classic Bluetooth party modes: LC3’s efficiency should keep battery impact lower than equivalent Classic‑audio multi‑output solutions.
  • Accessibility gains: hearing aid users gain direct access to streamed PC audio without intermediary hardware when their devices support LE Audio. That’s a meaningful usability win for a long-neglected use case.
  • Single control point: the Quick Settings integration centralizes the experience and lowers friction compared with manual pairing tricks or third-party transmitter dongles.
The caveats and practical limitations: what to expect during preview​
This is a preview with a narrow scope, and several real-world caveats matter for people who test it now:
  • Two-device cap: Although Auracast can support many listeners, Microsoft’s preview limits Windows to two sinks. That’s a sensible early step, but it means the feature won’t yet replace venue-level Auracast deployments or "one-to-many" listening needs.
  • Interoperability is still messy: LE Audio is new enough that vendors ship differing levels of support, vendor-specific codecs, or companion app behaviors that can interfere. Some devices may advertise LE Audio readiness but require firmware toggles or companion apps to enable the LC3 path.
  • Codec and feature fragmentation: not all LE Audio implementations support every codec configuration or streaming mode. Incomplete or partial support can cause devices to fall back to Classic Bluetooth profiles, or to behave inconsistently across phones, tablets, and PCs.
  • Latency and sync can vary in practice: while the standard supports tight synchronization, end-to-end latency depends on host stacks, buffering decisions, and accessory firmware. Two different earbuds might show small but noticeable offsets unless both do a good job with timestamp alignment and buffering.
  • Driver and firmware dependency: the Shared audio tile appears only after OEM driver and vendor firmware updates arrive. Expect staggered rollouts across OEMs and device SKUs.
  • Streaming DRM and app behaviors: some streaming services and media players apply DRM or audio path restrictions that can prevent audio from being retransmitted to secondary sinks. Early test results may vary between native media apps, browsers, and UWP apps.
  • Performance / battery considerations: pushing two LE streams concurrently requires the host Bluetooth controller and driver to manage extra workloads. On laptops with aggressive power profiles, users may see increased battery draw during prolonged shared sessions.
Known trouble patterns to watch for​
  • Accessories connected to the PC but not appearing in the Shared audio chooser — typically solved by updating firmware and re-pairing.
  • Intermittent stutter or choppiness — can originate from firmware bugs, competing radios (Wi‑Fi interference), or immature driver implementations.
  • Codec fallbacks where a device connects but uses a non‑LE profile (e.g., AAC or SBC) due to missing LC3 support on either side.
  • App‑specific behavior where a browser or streaming app routes audio differently; testing across multiple players is prudent.
Security and privacy considerations​
Broadcast-style audio introduces a different threat model than classical one-to-one pairing:
  • Public vs. private broadcasts: Auracast supports both public (unencrypted) and private (encrypted) streams; Windows’ preview uses paired devices for the two-person sharing scenario, reducing the risk of accidental public broadcast. Still, users should be mindful when enabling any broadcast-capable functionality in crowded places.
  • Unauthorized listeners: in public Auracast deployments, any compatible receiver can join a public stream. For the Windows preview’s two-sink model this is less of a concern, but it’s important to ensure the UI and default behavior do not accidentally advertise an open stream.
  • DRM implications: streaming services may block relaying of DRM-protected content; users testing video streaming should expect mixed behavior across apps and services.
Accessibility: a major win for hearing tech​
One of the clearest, immediate benefits is improved accessibility. Hearing aid vendors have treated LE Audio and Auracast as a priority: GN’s ReSound family and Beltone’s newer models explicitly support LE Audio and Auracast, and those vendors have been collaborating with platform owners to ensure compatibility. For people who rely on hearing aids, native Windows support for direct LE Audio streaming removes the need for niche transmitter hardware or proprietary bridges and creates a smoother experience for media consumption, meetings, and public venue access.
Why Microsoft limited the initial release to Copilot+ PCs​
Microsoft’s decision to limit Shared audio to Copilot+ PCs for preview is rooted in practical considerations:
  • Hardware and driver maturity: Copilot+ PCs typically ship with modern Bluetooth radios (LE-capable) and have tighter vendor cooperation for driver updates, which simplifies the certification path for a preview feature that depends on both OS and driver behavior.
  • Controlled test population: starting with a subset of hardware reduces fragmentation and makes telemetry and feedback easier to interpret.
  • Performance expectations: Copilot+ PCs include modern silicon and often higher-end radios that are more likely to deliver a reliable experience under test conditions.
Expectation: as driver and firmware quality improves, Microsoft will expand eligibility to more systems.
What industry fragmentation looks like right now​
LE Audio adoption is progressing, but slowly and unevenly. Vendors add LC3 and Auracast support at different cadences, and some device features appear behind companion-app toggles or require specific OS or vendor firmware versions. Practical consequences:
  • A headset labeled “LE Audio capable” may still require a firmware update or vendor app enablement to expose LC3/Auracast functionality to a Windows host.
  • Different vendor ecosystems can produce subtle UX differences: Samsung may implement features differently than Sony, which in turn can produce divergent behaviors on Windows.
  • Reports from early adopters show occasional stuttering, codec negotiation issues, or feature gaps while implementations settle.
This is a normal part of platform transitions — the Bluetooth SIG set the standards, but interoperability depends on consistent and correct implementation across stack layers: hardware, firmware, drivers, and OS.
Troubleshooting checklist for Insiders​
  • Ensure Windows Update shows Build 26220.7051 (or later) and that optional Bluetooth/audio driver updates are installed.
  • Update accessory firmware with the manufacturer’s app before pairing.
  • Remove and re-pair accessories if they don’t show in the Shared audio tile.
  • Keep companion apps (e.g., Samsung Wearable, Sony Headphones Connect) installed for firmware toggles and diagnostics.
  • Try the same two accessories with another LE Audio-capable device (phone/tablet) to check whether a problem is accessory-specific.
  • File reproducible feedback via Feedback Hub (Bluetooth – Audio quality, glitches, choppiness and stuttering) with logs attached when appropriate.
Developer and OEM implications​
For OEMs, driver teams, and accessory makers, Windows’ Shared audio preview highlights several places to focus:
  • Firmware quality: make sure LC3 and isochronous streaming paths are robust and that timestamping/buffering alignments are sharp.
  • Driver collaboration: coordinate with Microsoft early so driver updates can be staged through Windows Update as required.
  • Companion UX: provide clear firmware-update flows and in-app indicators when LE Audio/LC3 is active. Users expect frictionless toggles.
  • Testing and QA: test mixed-device scenarios (earbuds + headphones; hearing aid + earbud) to verify synchronization and codec negotiation.
Where this goes next: roadmap expectations​
  • Broader device support: Microsoft will likely expand supported Copilot+ PC SKUs and, over time, non-Copilot Windows machines as drivers and OEM engagement catch up.
  • More sinks and Auracast parity: eventually the Windows Auracast implementation could support larger broadcast audiences and public streams; during preview the two-sink cap provides a conservative, testable surface.
  • Improved UX and automation: expect the Shared audio flow to gain enhancements such as invitation links, automatic rejoin behavior, and richer controls (independent volume per sink, network-aware optimizations).
  • Third‑party app integrations: media apps, conferencing platforms, and DRM frameworks will need to refine their audio routing policies to work predictably with broadcast-style outputs.
Practical recommendations for readers and testing checklist​
  • If you’re an Insider with a compatible Copilot+ PC and two LE Audio accessories, try the feature — but treat it as experimental.
  • Prioritize firmware updates for accessories and confirm LC3/Auracast support in the vendor app.
  • Use the Feedback Hub to report any glitches with logs attached; early telemetry will shape the public rollout and driver prioritization.
  • For mission‑critical listening or long transits, keep a fallback plan (wired splitter, USB audio dongle, or a single trusted headset) until the ecosystem matures.
Final assessment: meaningful progress, cautious optimism​
Shared audio (preview) is a pragmatic, useful first step for LE Audio on Windows. It demonstrates Microsoft’s willingness to adopt Auracast-style broadcast primitives while deliberately constraining scope to deliver a reliable, user-friendly test experience. The accessibility upside — direct streaming to LE Audio hearing aids — is especially noteworthy and reflects months of industry work to standardize hearing-access pathways.
At the same time, the real-world experience will depend heavily on vendor firmware quality, driver updates, and app-level audio policies. Expect bumps: codec fallbacks, intermittent stutter, and device-specific quirks are a normal part of platform evolution. For users, the recommendation is straightforward: test the preview if you can, keep expectations modest, and report problems via Feedback Hub to accelerate fixes.
Shared audio isn’t a sweeping revolution yet, but it’s an important practical rollout of LE Audio in the PC space — one that brings social listening and accessibility benefits closer to everyday Windows users while exposing the interoperability gaps vendors and OEMs still need to close.
Source: Microsoft - Windows Insiders Blog Extending Bluetooth® LE Audio on Windows 11 with shared audio (preview)
Microsoft has begun preview testing a Windows 11 feature that can stream the same Bluetooth audio to two separate headsets, earbuds, speakers, or hearing aids at the same time, bringing Bluetooth LE Audio’s broadcast capabilities to the Windows desktop for the first time.
Blue-lit desktop setup with wireless headphones and a monitor showing Bluetooth audio settings.Background​
Microsoft rolled out the new Shared audio (preview) experience as part of Windows 11 Insider Preview Build 26220.7051 for the Dev and Beta channels. The feature is built on Bluetooth Low Energy (LE) Audio broadcast technology and exposes a simple Quick Settings tile—Shared audio (preview)—so users can select two paired, compatible Bluetooth LE Audio devices and “share” the same stream. The initial preview is limited to a set of Copilot+ Windows PCs and requires matching Bluetooth and audio driver updates plus firmware on the accessories themselves.
This is not an incremental driver tweak: it leverages the LE Audio stack and the new LC3 codec and broadcast primitives that were designed to enable multi-recipient audio use cases (often branded Auracast by the Bluetooth SIG). On phones and some Android devices, Auracast-style capabilities have already enabled similar “two headphones” or broadcast scenarios; Windows’ addition brings that functionality to laptops and desktop PCs and opens new scenarios for shared media, accessibility, and localized multi-listener audio in public venues.
What Microsoft announced and what it actually does​
The feature in practical terms​
  • The Quick Settings area will include a “Shared audio (preview)” tile once your system has the necessary OS, driver, and firmware updates.
  • You pair two Bluetooth LE Audio accessories to the PC, select the two devices in the UI, and press Share to transmit the same audio stream to both devices simultaneously.
  • A Stop sharing control ends the session.
Early availability and hardware gating​
  • The preview is being offered first to Windows Insiders in the Dev and Beta channels and is restricted initially to Copilot+ PCs that meet Microsoft’s listed hardware/driver requirements.
  • Microsoft lists a set of Copilot+ devices as available today for preview support and a longer list of devices coming soon as driver updates roll out.
  • Microsoft explicitly recommends using vendor apps and ensuring accessory firmware is up to date; if a paired device does not appear in the shared audio picker, Microsoft advises removing and re-pairing the accessory.
Compatibility claims and sample accessories​
  • Microsoft’s documentation notes compatibility with a range of LE Audio-capable accessories and cites product examples such as several Samsung Galaxy Buds models, Sony WH-1000XM6, and select hearing aids from manufacturers that implemented LE Audio.
  • The announcement makes clear the list is illustrative and that broader market compatibility depends on the accessory’s LE Audio feature set (support for LC3, isochronous channels, and broadcast readiness).
How the underlying technology works​
Bluetooth LE Audio, LC3, Auracast and isochronous channels​
Bluetooth LE Audio is a next-generation Bluetooth audio architecture that replaces many legacy aspects of Classic Bluetooth audio. Its headline technical improvements are:
  • The LC3 codec (Low Complexity Communications Codec) — lower power use and higher perceived quality at lower bitrates compared with the old SBC codec.
  • Isochronous channels — a new transport primitive in Bluetooth LE that enables time-aligned audio streaming with improved synchronization and lower latency.
  • Broadcast audio / Auracast — a topology that allows a transmitter to broadcast one or more synchronized streams to multiple receivers without traditional point-to-point pairing; streams can be public or private and may support different quality tiers.
In the Windows Shared audio scenario, the OS acts as the LE Audio transmitter using LE isochronous channels to push an encoded stream (LC3) to two connected sinks (the headphones/earbuds). The LE Audio design intentionally supports multi-sink topologies and synchronized delivery, which is essential for sharing a single media source between listeners without audible offsets.
Why LE Audio matters for shared audio​
  • Lower latency and better sync: LC3 plus isochronous channels reduce the timing variance between devices, making lip-sync and multi-listener experiences more realistic.
  • Power efficiency: LE Audio’s encoding lets vendors balance audio quality and battery life better than older Bluetooth audio codecs.
  • Scalability and broadcast scenarios: Auracast-style broadcasting is designed for single-source, many-listener situations—think museum tours, public transport audio, or silent-disco style presentations.
Practical setup: how to get Shared audio (preview) working​
  • Enroll your Copilot+ PC in the Windows Insider Program (Dev or Beta channel) and install the Windows 11 Insider Preview Build that includes the feature.
  • Update Windows Update to receive the necessary Bluetooth and audio driver updates from your OEM.
  • Ensure accessories support LE Audio / LC3 and install any vendor firmware updates (via the manufacturer’s app).
  • Pair and connect up to two compatible Bluetooth LE Audio accessories.
  • Open Quick Settings and select the Shared audio (preview) tile. Choose the two devices and click Share.
  • Use Stop sharing to end streaming to the paired devices.
Tips and troubleshooting:
  • If an accessory is paired but not listed in the shared audio picker, remove it and re-pair it after firmware updates.
  • Ensure other Bluetooth audio sinks are disconnected to avoid connection count limits.
  • If you can’t see the tile, verify your device is on the approved Copilot+ list and that drivers are up to date.
Strengths and real benefits​
1) A natural, user-friendly way to share audio​
The Quick Settings tile and simple selection UI bring a shareable audio experience to non-technical users. This reduces friction compared with manual workarounds like wired splitters or complicated third-party mixing apps.
2) Accessibility gains for hearing aids​
LE Audio explicitly supports low-power hearing aids and broadcast models that make it easier for hearing-impaired listeners to access the same audio in public settings—directly and synchronously—without requiring intermediary adapters.
3) Enterprise and hospitality possibilities​
Airports, museums, theaters, and conference venues that adopt LE Audio infrastructure could let patrons tune into individual language tracks, descriptive audio, or private streams with their own headsets—Windows’ adoption helps close the loop for PCs and kiosks as transmitters.
4) Better battery and quality trade-offs​
LC3’s efficiency can give users either better battery life at the same quality or better quality at comparable power use. That translates to more comfortable, longer shared-listener sessions on earbuds.
Risks, trade-offs and caveats​
Compatibility is the gating factor​
LE Audio is an ecosystem feature: the PC’s Bluetooth adapter, the OS stack, the accessory firmware, and driver support must all align. Many devices advertise Bluetooth 5.x but do not necessarily implement LE Audio, LC3, or broadcast features—expect an uneven, phased rollout across OEMs, models, and regions.
Copilot+ gating raises practical concerns​
Microsoft’s initial preview is deliberately limited to a subset of Copilot+ PCs. While that may reflect a desire to control rollouts while drivers are validated, it raises questions about artificial gating and creates confusion for users who have modern Bluetooth chipsets but are on non‑Copilot hardware.
Latency, lip-sync, and desynchronization risk​
Even with isochronous channels and LC3, perfect sync depends on accessory implementation. Differences in device buffering, DSP pipelines (ANC, voice enhancement), or firmware packet handling can cause tiny offsets between listeners. These are most noticeable for video playback (lip-sync) and ensemble music playback.
DRM and content protection​
Protected content services (streaming platforms with DRM) may impose restrictions on broadcast-like transmissions. It is plausible that some streaming services will not permit broadcast distribution outside the usual single-user playback model, or that platforms will implement provider-specific workarounds that prevent shared audio. This remains an open interoperability question that will matter to users who want to share Netflix, Disney+, or other DRM-protected streams.
Battery and connection stability​
Streaming to two sinks simultaneously increases the overall load on the Bluetooth transmitter and may reduce accessory battery life slightly (depending on how the accessory implements LE Audio). Bandwidth and environment (dense RF) could also introduce dropouts. Users should not expect magic: two simultaneous wireless streams still contend with the same RF environment.
Broadcast audio can be public by design, and while private/paired broadcast channels are possible, vendors and users must understand the security model. Public Auracast streams can be discovered by others nearby; private broadcasts require encryption and proper pairing. Windows’ implementation appears to rely on paired and trusted devices for the preview scenario, but users should be aware of discovery and access controls in public deployments.
How this compares to other vendor approaches​
  • Several Android vendors have implemented Auracast or dual-audio approaches already. Some Pixel and Samsung phones can broadcast to two headsets (or use vendor-specific dual-audio features) natively.
  • Apple’s ecosystem remains separate; AirPlay-style multi-device audio is different from Bluetooth LE Audio and typically involves the Apple ecosystem rather than native Bluetooth broadcast.
  • Wired splitters and USB-DA converters remain a universal fallback for guaranteed sync and absence of Bluetooth variability—useful on flights or situations where the wireless environment is hostile.
Real-world use cases and scenarios​
  • In-flight shared media: Two travelers can watch the same movie on a laptop without disturbing others—each with their own headset.
  • Study buddies: Students can listen to the same lecture audio or language practice without passing a single headset back and forth.
  • Museum or tour audio: A guide’s PC or kiosk could broadcast multiple language tracks or descriptive audio to visitors’ headsets.
  • Training and demonstration: Trainers can mirror audio to a trainee’s headset to follow along without interrupting a broader workspace.
  • Assistive listening: Hearing aid wearers can receive synchronized audio from a presentation or public display, improving comprehension in noisy spaces.
Troubleshooting and practical tips for early adopters​
  • Verify LE Audio support: Confirm that both your PC’s Bluetooth adapter and the accessories claim LE Audio or LC3 support in their specs.
  • Update everything: Windows OS preview build, OEM Bluetooth drivers, and accessory firmware are all required. Use manufacturer companion apps for firmware updates.
  • Re‑pair devices: If a compatible accessory does not show up in the Shared audio picker, remove and re-pair following firmware updates.
  • Minimize RF noise: Move away from crowded Wi-Fi / Bluetooth environments if you encounter dropouts; wired remains reliable.
  • Use vendor apps: Some headphone vendors expose LE Audio settings or multi‑sink support via their apps; installing those apps can improve interoperability.
  • Be prepared for content limits: Test with media you own; expect potential restrictions with DRM-protected streaming services.
  • Expect iterative improvements: The preview is intentionally limited; real-world stability will improve as drivers and firmware mature.
  • OEM driver teams must ensure their Bluetooth stacks and firmware expose the necessary LE isochronous and broadcast primitives. That means not only adding LC3 support but ensuring scheduling, buffer handling, and API surfaces between driver, firmware, and OS are robust.
  • Accessory vendors must ship firmware that fully supports LE Audio broadcast roles and the LC3 codec. In many cases, devices marketed as "Bluetooth 5.x" will still require explicit firmware updates to support LE Audio features.
  • Windows developers and integrators should test lip-sync, delay compensation, and battery characteristics. Video players may need adaptive buffering strategies or metadata negotiation to minimize perceived latency when two sinks are involved.
What to watch for next​
  • Wider OEM adoption: More PC vendors and Bluetooth adapters will need driver updates if Shared audio is to expand beyond Copilot+ hardware.
  • Accessory firmware rollouts: Headphone makers must push LC3/Auracast firmware broadly; otherwise, compatibility will remain patchy.
  • Streaming platform behavior: Will streaming services permit broadcast-style multi-sink playback for DRM-protected content? Expect vendor business policies and DRM ecosystems to shape the experience.
  • Public Auracast rollouts: Commercial venues and public infrastructure may adopt Auracast for language and accessibility support; Windows’ role as a transmitter opens kiosk and PC use cases in these environments.
  • User feedback from Preview: Early Insider feedback will highlight issues such as desync, dropouts, and UX gaps. Microsoft has asked Insiders to file feedback for audio quality, glitches, and stuttering.
Final assessment and recommendations​
Windows 11’s Shared audio (preview) is a meaningful addition to the operating system’s audio toolkit. By integrating Bluetooth LE Audio broadcast primitives into the OS, Microsoft takes a practical step toward making multi-listener audio a mainstream capability on PCs. The potential benefits for accessibility, localized public audio, and casual shared media are real and immediate.
However, the value delivered to everyday users will depend heavily on the pace of accessory firmware updates and OEM driver support. For early adopters and Windows Insiders on supported hardware, this is a feature worth testing and filing feedback on. For the broader market, patience will be required while the ecosystem catches up.
Recommendations for users:
  • If you want to try Shared audio, verify your PC is on the supported Copilot+ list and sign up for the Windows Insider Dev or Beta channel only if you are comfortable running preview builds.
  • Update Bluetooth drivers and accessory firmware first; this often resolves the majority of compatibility issues.
  • Use wired splitters for guaranteed sync in critical situations until LE Audio implementations prove stable for your accessories.
  • Report quality issues through the Feedback Hub to help shape the feature before public rollout.
In short, Shared audio brings desktop Windows into the new era of LE Audio broadcast capabilities—but early-stage ecosystem friction and hardware gating mean real-world seamlessness will arrive incrementally. The architecture is solid; the rollout and accessory adoption will determine how quickly shared, synchronized wireless audio becomes an everyday reality for PC users.
Source: The Daily Star https://www.thedailystar.net/tech-s...-sharing-two-headsets-simultaneously-4025291/
Microsoft’s Windows 11 is rolling out a long‑requested convenience: a built‑in way to stream the same audio to two Bluetooth devices simultaneously, using a new Shared Audio preview that leverages Bluetooth Low Energy (LE) Audio to deliver synchronized sound to two pairs of headphones, earbuds, speakers, or compatible hearing aids.
Laptop shares audio with two LE Audio headphones in a blue UI illustration.Background​
Shared Audio arrives as part of the Windows Insider Preview builds and is being previewed in Build 26220.7051 for the Dev and Beta channels. The feature is presented as a Quick Settings tile called Shared audio (preview) and is designed to let users pick two LE Audio‑capable accessories that are paired and connected to the PC, then press Share to transmit the same audio stream to both devices at once. Microsoft positions this as a simple, hardware‑level solution that removes the need for cables, Bluetooth splitters, or complicated software workarounds.
This capability stands on the shoulders of Bluetooth LE Audio — the successor to classic Bluetooth audio codecs — and follows a broader industry trend toward multi‑device, broadcast‑style audio experiences on mobile platforms. The initial rollout is hardware‑gated: it requires a Copilot+ PC with the necessary Bluetooth and driver stack, and compatible LE Audio accessories. Over time Microsoft plans to expand the device list and driver support to reach more systems.
What Shared Audio actually does​
The user‑facing experience​
The Shared Audio preview adds a new tile to Windows 11’s Quick Settings. The typical flow is:
  • Pair and connect two LE Audio‑enabled accessories to your PC.
  • Choose the two connected devices you want to share audio with.
  • Hit Share to start broadcasting the same audio stream to both devices.
  • Use Stop sharing to end the session.
This is intentionally simple: the UI exposes only the controls most users need, and the sharing session behaves like a linked output that delivers identical audio to both endpoints.
How it differs from prior Windows behavior​
Historically, Windows only routed audio to a single default device or required complex workarounds to mirror output (virtual audio drivers, third‑party mixing apps, or hardware splitters). Shared Audio replaces those kludges with a first‑party, Bluetooth‑native approach. The difference is meaningful: instead of creating virtual devices or using software mixing that can introduce latency or instability, Shared Audio uses the Bluetooth stack itself to broadcast a single stream to multiple receivers.
The technology behind Shared Audio: Bluetooth LE Audio and broadcast models​
Why LE Audio matters​
Bluetooth LE Audio is a next‑generation audio architecture for Bluetooth that introduces several technical improvements over classic Bluetooth audio:
  • LE Audio supports lower power consumption, which can extend battery life for both transmitters (PCs/phones) and receivers (earbuds, hearing aids).
  • Improved spectral efficiency and codec design (most notably the LC3 codec) allow for better audio quality at lower bitrates.
  • Broadcast and Auracast‑style capabilities, where a single transmitter can send the same audio stream to multiple receivers, are first‑class features in LE Audio.
  • Better support for hearing aids and assistive listening, enabling more inclusive experiences.
Shared Audio on Windows implements this broadcast model: the PC becomes the source broadcaster, and the two selected accessories act as listeners. Because the mechanism operates inside the Bluetooth LE Audio stack, it avoids the clock‑domain sync problems that commonly plague ad‑hoc software mirroring.
Latency and synchronization​
Bluetooth LE Audio was developed with multi‑device scenarios in mind. When implemented end‑to‑end (firmware in the headset + OS + driver support), LE Audio broadcast can provide tight synchronization between devices. That said, real‑world performance depends on the accessory firmware, the OS drivers, and the Bluetooth radio quality. In practice, identical models from the same manufacturer will usually sync better than mismatched products; users may still notice subtle timing discrepancies if one accessory does additional internal processing (active noise cancellation, extra DSP) that introduces delay.
Practical takeaway: expect near‑perfect sync for many modern LE Audio‑capable accessories, but be aware that exact behavior depends on device firmware and driver maturity.
Compatible devices and hardware requirements​
Copilot+ PCs and the rollout model​
Shared Audio is initially gated to a set of Copilot+ Windows 11 PCs that have the necessary telemetry, drivers, and Bluetooth hardware updates. That means not every Windows 11 machine will see the tile immediately — Microsoft is doing a phased rollout tied to OEM driver updates and the Copilot+ program.
At launch, the preview lists a limited set of devices as supported (notable examples among early compatible machines include specific Qualcomm Snapdragon X‑powered Surface devices). Microsoft also published a “coming soon” list that includes additional OEM models including certain Intel Core Ultra‑based laptops and more Qualcomm Snapdragon X devices, suggesting a rapid but staged expansion.
Accessories: LE Audio is required​
A second gating factor is the accessories themselves. Shared Audio requires Bluetooth LE Audio support in the headphones, earbuds, or hearing aids being shared. That excludes a great many legacy Bluetooth audio products that rely on older classic A2DP or SBC/aptX/LDAC stacks. Manufacturers such as Samsung, Sony, and others have started shipping LE Audio‑enabled models (for example, recent Galaxy Buds and flagship Sony models), but the installed base of compatible devices is still growing.
  • If your headset or earbuds advertise LE Audio or LC3 codec support, they are candidates.
  • If they are older devices that only support classic Bluetooth audio, they will not appear as options in the Shared Audio tile.
Driver and firmware requirements​
The Shared Audio experience requires not only OS code but also Bluetooth driver updates and accessory firmware that fully support LE Audio broadcast and the relevant profiles. Microsoft recommends installing manufacturer firmware updates for accessories and the latest Bluetooth drivers for your PC. In many cases, the Shared Audio tile will not appear until both the OS and manufacturer drivers are present and updated.
How to try Shared Audio today (step‑by‑step)​
If you want to experiment with Shared Audio in the preview, follow these general steps:
  • Confirm your PC qualifies as a Copilot+ device and enroll it in the Windows Insider Program (Dev or Beta channels).
  • Update Windows to Build 26220.7051 (or later) via Windows Update and accept any offered driver updates.
  • Verify your PC’s Bluetooth hardware supports LE Audio. Check Settings > Bluetooth & devices for LE Audio indicators and ensure drivers are up to date.
  • Update firmware on your Bluetooth accessories via the manufacturer’s app. Confirm that each accessory supports LE Audio/LC3.
  • Pair and connect both accessories to the PC through Settings > Bluetooth & devices.
  • Open Quick Settings (system tray) and look for the Shared audio (preview) tile.
  • Select the two connected accessories in the Shared Audio UI and press Share.
  • Adjust volume independently on each accessory as needed; use Stop sharing to end the session.
Note: If the Shared Audio tile does not appear after updating the OS, check for OEM driver packages through Windows Update or your device manufacturer’s support site. Re‑pairing accessories after firmware updates can also resolve visibility problems.
Real‑world use cases: where Shared Audio shines​
Shared Audio is more than a novelty; it’s tailored for specific real‑world scenarios:
  • Travel and entertainment: Two people on a plane or train can watch the same movie on a laptop without sharing a single pair of earbuds.
  • Gaming with a friend: Two players sitting side‑by‑side can listen to the same in‑game audio or soundtrack without splitters or wired connections.
  • Study or group work: Two students can listen to the same lecture or language lesson from one PC at the same time.
  • Assistive listening: People using hearing aids (that support LE Audio) can receive the same stream directly.
  • Public demos: A salesperson or presenter can let two prospective customers listen to product audio on separate headsets during a demo.
These situations benefit from the convenience and cleaner setup compared with older solutions. The experience is particularly compelling on ultralight, mobile Windows devices where passing headphones back and forth is inconvenient.
Limitations, caveats, and practical risks​
Hardware and ecosystem friction​
The most immediate limitation is hardware compatibility. Many Windows machines and Bluetooth accessories in circulation do not yet support LE Audio, and Copilot+ gating further narrows early availability. That will change over time, but users should not expect universal compatibility at release.
Quality and codec variability​
LE Audio introduces LC3, but manufacturers may implement different quality/performance tradeoffs. A headset configured to prioritize battery life may sound different than one configured for higher bitrate audio. When mixing brands, quality mismatches are possible.
Latency concerns for certain applications​
Although LE Audio was built with broadcast use in mind, latency still matters. For music and movies, small latencies are usually unnoticeable. For competitive gaming or audio recording workflows, even small additional latency could be a problem — Shared Audio is not a replacement for low‑latency private headphone setups used in high‑stakes competitive scenarios.
Battery life implications​
Broadcasting to two devices is more energy‑efficient on LE Audio compared with older Bluetooth implementations, but it still consumes additional power on the host PC and both accessories. In general, expect some battery impact on both the transmitter and connected devices — though not to the degree of older stereo over classic Bluetooth.
Device parity and UX quirks​
Not all accessories expose independent on‑device volume controls or consistent mute behaviors when used together. Users should expect to debug behavior the first few times: firmware updates, re‑pairing, or toggling the Shared Audio tile may be necessary to get smooth operation.
Privacy and proximity concerns​
The broadcast model implies sharing to devices that are paired and connected; however, broadcast systems conceptually can be discovered by nearby listeners if not properly implemented. Microsoft’s preview design limits sharing to paired, selected devices, but users should be mindful of accidental pairing or leaving broadcast sessions open in public spaces. Treat the Shared Audio session like handing someone a wired earbud — you are intentionally giving them access to your audio stream.
How Shared Audio compares to mobile offerings​
Mobile platforms have been moving toward multi‑listener Bluetooth experiences for a while. Apple supports a paired two‑headphone sharing mode on iOS for specific AirPods models, and Android has cross‑vendor approaches with Auracast/LE Audio on compatible devices. Shared Audio brings a similar convenience to Windows PCs but with PC‑specific constraints:
  • Windows supports more types of accessories (including PC‑class Bluetooth radios), which can be an advantage.
  • The Copilot+ gating and driver dependency create a more staged experience compared to some mobile rollouts.
  • Windows PCs often run complex audio stacks and third‑party audio apps; Shared Audio needs to play nicely in that environment.
In short, Shared Audio narrows the feature gap with phones and tablets but inherits PC complexity around drivers, firmware, and third‑party audio software.
Developer, OEM, and manufacturer implications​
The arrival of Shared Audio puts pressure on several parts of the ecosystem:
  • OEMs must ensure Bluetooth radios and drivers support LE Audio broadcast and that their update channels are ready to deliver timely driver packages.
  • Accessory manufacturers need to ship LE Audio firmware and ensure compatibility with a variety of hosts; differences in firmware will drive much of the real‑world experience.
  • Audio software vendors (virtual mixers, conferencing apps) should test against the new broadcast mode to ensure no regressions occur when multiple Bluetooth outputs are present or when Quick Settings toggles are used mid‑session.
This feature could also reduce reliance on third‑party virtual audio tools for casual multi‑device needs, pushing the market toward more polished hardware solutions.
Shared Audio’s model is conservative: pairing and explicit selection are required to share audio. Nonetheless, there are aspects to watch:
  • Pairing hygiene: Users should maintain tight control over which accessories are paired to their PC, especially on mobile devices used in public.
  • Session visibility: The Quick Settings tile implies an on/off visibility; users must stop sharing when finished to avoid unintended listeners.
  • Driver and firmware trust: As with any radio feature, updates to drivers or accessory firmware can change behavior. Only install updates from trusted channels.
For organizations, Shared Audio could have both helpful and risky uses — it enables assistive listening and collaborative work, but IT teams should document acceptable use policies for shared audio in public or sensitive environments.
Recommendations for users and early adopters​
If you’re interested in trying Shared Audio during the preview, consider these steps to reduce friction:
  • Confirm your PC is a Copilot+ model and enroll in the Windows Insider Program (Dev or Beta). Expect preview builds to be less stable than production releases.
  • Update Bluetooth drivers and accessory firmware before attempting a session.
  • Use matching or same‑brand accessories where possible for the best sync and quality.
  • Test with non‑critical content first (music or video) to evaluate latency and quality.
  • Keep an eye on OEM release notes; driver updates may be required to enable the Quick Settings tile.
  • If you rely on low‑latency audio for gaming or studio work, do not use Shared Audio as your primary monitoring solution until you validate latency performance for your specific setup.
What Microsoft needs to watch going forward​
Shared Audio marks a solid step forward but faces engineering and ecosystem challenges that Microsoft should manage carefully:
  • Driver fragmentation: The biggest short‑term friction will be device and driver availability. Microsoft’s staged rollout tied to OEM updates is pragmatic but will frustrate users on unsupported hardware.
  • Interoperability: Ensuring consistent behavior across accessories from different vendors is crucial. Microsoft and partners should prioritize cross‑vendor test suites.
  • User discoverability: The Quick Settings tile is a good starting point, but education (in Settings, tips, and support docs) will help users understand device and firmware prerequisites.
  • Privacy defaults: Clear UI cues and conservative defaults (paired only, manual share) will help mitigate accidental broadcasting.
  • Accessibility: LE Audio’s assistive potential is significant; Microsoft should closely collaborate with hearing‑aid makers and accessibility advocates to maximize benefit.
Final analysis: why Shared Audio matters — and where it might fall short​
Shared Audio is a pragmatic, OS‑level solution to a long‑standing limitation in Windows audio routing. It brings convenience parity with modern smartphones and unlocks everyday use cases — travel, paired entertainment, and assistive listening — without relying on third‑party hacks. By building on Bluetooth LE Audio, Microsoft positions Windows for the next generation of wireless audio where efficiency, broadcast, and hearing‑aid support matter.
However, the feature’s immediate utility will be constrained by ecosystem readiness. The Copilot+ gating, driver dependencies, and the slow uptake of LE Audio in the installed accessory base mean that many users will not see the benefit right away. Even when supported hardware is present, mixed‑brand setups and firmware differences could produce inconsistent quality and timing.
The long term is promising: as LE Audio becomes mainstream across headsets and PC radios, Shared Audio should become a frictionless, default option for many shared listening scenarios. For now, it’s an important preview that hints at a future where multi‑device audio is simple and reliable on PCs — provided manufacturers, OEMs, and Microsoft coordinate to close the compatibility and driver gaps.
Shared Audio on Windows 11 is a meaningful addition to the PC audio toolkit. It translates mobile‑style shared listening to the desktop and laptop world by leveraging Bluetooth LE Audio’s broadcast capabilities and a concise Quick Settings experience. Early adopters on Copilot+ devices with LE Audio accessories will experience the feature first, and their feedback during the preview will shape broader availability and polish.
For users, the advice is straightforward: update drivers and accessory firmware, try the preview if your machine and headsets support it, and temper expectations about universal compatibility and latency for professional workflows. For the industry, Shared Audio is another signal that LE Audio is maturing — and that the days of single‑device Bluetooth audio on PCs are finally starting to end.
Source: Hindustan Times Windows’ new feature allows you to play audio on two Bluetooth devices simultaneously: How to try it
Microsoft is testing a new Windows 11 capability that can stream the same audio to two Bluetooth devices at once, using Bluetooth Low Energy (LE) Audio and surfaced as a Quick Settings tile in the Windows Insider Preview Build 26220.7051 (Dev and Beta channels).
Neon blue laptop with headphones, highlighting LC3 audio codec and isochronous channel.Background / Overview​
Bluetooth audio on PCs has long been constrained by legacy profile trade-offs that forced systems to choose between high‑quality playback and usable microphone support. The arrival of Bluetooth LE Audio — with the LC3 codec, Isochronous Channels (ISO) and new profiles like TMAP — opened a standards‑based path to better quality, improved battery life, and multi‑sink or broadcast‑style audio. Microsoft’s new Shared audio (preview) is the first visible Windows implementation that uses those LE Audio primitives to transmit a single synchronized audio stream to two separate receivers.
This preview is intentionally conservative: Microsoft limits initial availability to Copilot+ PCs and to two simultaneous sinks in the preview, and it requires matching Bluetooth firmware and OEM driver updates to function reliably. The feature is included in Windows 11 Insider Preview Build 26220.7051 and is being rolled out to Insiders on the Dev and Beta channels on supported hardware.
Shared audio converts a single PC audio output into a synchronized LE Audio broadcast to two compatible Bluetooth accessories. From a user perspective, the flow is deliberately simple:
  • Pair and connect up to two LE Audio‑capable accessories in Settings > Bluetooth & devices.
  • Open Quick Settings and tap the Shared audio (preview) tile.
  • Select the two connected accessories and press Share to begin streaming.
This UI hides the more complex work done by the Bluetooth transport and Windows audio stack: encoding to LC3, opening isochronous channels, and coordinating packet timing so both receivers play the stream in sync. The preview limits the experience to two sinks while Microsoft and partners collect feedback and iterate.
Technical primer: the LE Audio foundation (short and practical)​
Understanding the standards under the feature clarifies both its potential and its practical limitations.
  • LC3 codec — Designed for LE Audio, LC3 delivers better perceived audio quality at lower bitrates than legacy SBC. That efficiency reduces radio airtime and improves battery life for accessories while allowing a single host to feed multiple sinks. LC3 supports sampling rates up to 48 kHz, which keeps media quality high for desktop scenarios.
  • Isochronous Channels (ISO) — ISO is the LE transport primitive that provides timing guarantees required for synchronized playback across multiple receivers. It reduces jitter and aligns packet timing so listeners hear the same audio with minimal offset.
  • TMAP / Multi‑stream — Profiles like TMAP enable simultaneous high‑quality media and microphone streams on the same LE connection, addressing the old “music goes to mud” problem where a mic would trigger a low‑quality telephony mode. Microsoft’s recent audio plumbing work in Windows 11 aligns with these standards to preserve stereo and voice quality together.
Because Shared Audio is built on standards rather than a proprietary trick, it has the potential to work across vendors — but only where vendors update firmware, drivers, and companion apps to expose LE Audio features.
Device requirements and current availability​
A key caveat: the preview is hardware‑gated. Microsoft restricts initial exposure to systems that meet specific hardware and driver requirements.
  • Host PC requirement: Copilot+ capable Windows 11 PCs are the first targets; Microsoft initially rolled the preview to select Surface models and a handful of Galaxy Book SKUs, and it requires up‑to‑date OEM Bluetooth drivers that expose the LE Audio stack to Windows.
  • Accessory requirement: headphones, earbuds, speakers or hearing aids must support Bluetooth LE Audio (LC3 / ISO). Many existing Bluetooth devices will not work until vendors ship firmware updates to enable LE Audio features. Examples cited in early testing include several Samsung Galaxy Buds models and Sony’s WH‑1000XM6 as representative LE Audio‑capable accessories, though these lists are illustrative rather than exhaustive.
  • Windows build: the feature appears in Windows 11 Insider Preview Build 26220.7051 (Dev and Beta channels). The Quick Settings tile only appears after Windows and OEM driver updates enable the capability.
Important caution: published device lists during a preview are frequently illustrative; Microsoft and OEMs often update the compatibility roster rapidly. Treat any early “works on these models” claims as provisional until OEM driver release notes and vendor firmware pages confirm compatibility.
How to try Shared Audio (step‑by‑step)​
For readers who want to test the preview on supported hardware, follow these steps as a practical checklist.
  • Confirm your PC is on the Copilot+ compatibility list and you’re comfortable running Insider builds. Shared Audio is in the Dev and Beta channels as part of Build 26220.7051.
  • Enroll the Copilot+ device in the Windows Insider Program (Dev or Beta).
  • Update Windows and accept any OEM Bluetooth/audio driver updates delivered through Windows Update or the vendor’s support tools. The Quick Settings tile appears only after drivers expose the LE Audio capability.
  • Ensure each Bluetooth accessory supports LE Audio and has the latest firmware installed via the vendor’s companion app — many vendors unlock LC3/LE functionality through firmware updates.
  • Pair and connect two LE Audio‑capable accessories in Settings > Bluetooth & devices.
  • Open Quick Settings (Win + A) and tap Shared audio (preview). Select the two connected accessories and press Share to start streaming. Use Stop sharing to end the session.
Practical tip: If a connected accessory does not appear in the Shared Audio selector, remove and re‑pair it after verifying firmware and driver versions — this resolves many early compatibility problems.
Immediate benefits and everyday scenarios​
Shared Audio is a simple feature on the surface, but it unlocks several practical improvements for desktop users.
  • Shared viewing and listening — Two people can privately watch a movie or view content on a laptop using their own headsets, without cables or external splitters.
  • Travel and public spaces — On airplanes, trains, or in waiting areas, two listeners can privately consume in‑flight or on‑device entertainment without disturbing others.
  • Study and small‑group work — Students can share audio during group study or language labs without crowding around one set of speakers.
  • Accessibility — LE Audio’s hearing‑aid profiles and broadcast potential make Shared Audio relevant for venues and assistive tech use cases where individualized listening from a central source is valuable.
  • Power and latency improvements for compatible accessories — LC3 delivers efficiency gains that can translate into better battery life for earbuds and lower radio airtime than legacy stacks.
These benefits are the main reasons the desktop needed a first‑party, standards‑based solution rather than ad‑hoc third‑party workarounds.
Limitations, risks, and the ecosystem problem​
Shared Audio is promising, but practical deployment exposes several real‑world risks and limitations that will affect adoption speed.
Strict hardware and firmware dependencies​
A chain is only as strong as its weakest link: even if Windows exposes Shared Audio, the PC’s Bluetooth controller firmware, the OEM’s Windows drivers, and the accessory firmware all need to support LE Audio and its isochronous transports. If any link is missing, the feature falls back to legacy Bluetooth behavior or won’t appear at all. Expect spotty availability until vendors push coordinated updates.
Synchronization and latency variability​
LE Audio’s ISO helps alignment, but vendors implement buffering and audio‑processing pipelines differently. That can create perceptible misalignment between two headsets when accessory vendors use different latency targets. Microsoft deliberately limits the initial preview to two sinks to minimize complexity, but multi‑vendor testing will be required to make the experience reliably imperceptible across a broad set of accessories.
Battery and device trade‑offs​
While LC3 is more efficient, broadcasting one feed to two receivers increases radio activity on the host and may affect host battery drain and accessory behavior depending on implementation. Claims of improved battery life for earbuds are conditional: they hold when accessory implementations optimize LC3 usage correctly. Unverified vendor claims about battery gains should be treated cautiously until independent tests confirm them.
User and enterprise security/privacy considerations​
Any broadcast or multi‑sink audio scenario raises policy and privacy questions in enterprise or public venues. Administrators will want controls for discoverability, encryption, and governance when hosts broadcast to multiple listeners — particularly if the broadcasted content could contain sensitive information. Microsoft will need to surface appropriate enterprise controls and telemetry options as the capability scales beyond Insiders.
Interoperability telemetry and certification needs​
Because different accessory vendors may ship incompatible buffering or encoding behaviors, Microsoft and partners may need formal interoperability testing or a certification program to ensure consistent experiences. Expect Microsoft to gather telemetry and possibly tighten certification if synchronization or latency issues vary widely across devices. Early testing feedback will shape how certification or entitlements are applied.
Comparative context: how this compares to mobile and vendor solutions​
Apple and some Android vendors already offer device‑pair audio sharing solutions, often with proprietary ties to their ecosystems or using Auracast‑style features on Android. Microsoft’s Shared Audio differs by building on Bluetooth SIG standards (LE Audio / LC3 / ISO) and bringing those primitives into Windows as a first‑class OS feature. That matters for cross‑vendor compatibility if accessory makers adopt standardized LE Audio behavior rather than proprietary pairings. However, the desktop’s broader hardware heterogeneity makes the rollout intrinsically more complex than a vertically integrated phone + earbuds ecosystem.
What to expect from the rollout and timelines​
Microsoft’s staged approach is predictable and sensible:
  • Preview to Insiders on Dev/Beta channels for selected Copilot+ hardware to collect telemetry and feedback.
  • OEM driver and accessory firmware updates rolled out to more devices progressively; broad availability depends on vendor update cadence.
  • Potential expansion beyond two receivers and additional UI controls (discoverability, encryption, group management) once interoperability and UX are validated.
This means consumers using older Bluetooth devices or non‑Copilot+ PCs should expect a phased arrival: the promise is real, but the timeline is governed by vendor cooperation.
Practical recommendations​
For consumers and early adopters​
  • Verify your PC appears on the Copilot+ compatibility list before enrolling in Insider builds.
  • Keep a wired fallback for mission‑critical sessions (presentations, streaming events), since wireless multi‑sink behavior may still vary across accessory combinations.
  • Update accessory firmware using the vendor’s companion app — many vendors gate LC3/LE features behind firmware updates.
For accessory manufacturers​
  • Prioritize firmware updates that expose LE Audio, LC3 and isochronous channel support to maximize compatibility with Windows hosts. Early coordination with OEMs and Microsoft reduces fragmentation.
For IT teams and procurement​
  • When buying for shared or public environments, include Bluetooth silicon model, LE Audio support, and vendor driver update cadence as procurement requirements. Don’t assume Bluetooth 5.x implies LE Audio support.
  • Pilot Shared Audio in representative environments and maintain wired fallbacks for deterministic audio workflows in conference rooms or classrooms.
Critical analysis: strengths, weaknesses, and the tipping point​
Shared Audio addresses a long‑standing consumer pain point on Windows with a standards‑based solution that is technically sound. By leveraging LC3 and isochronous channels, Microsoft avoids the pitfalls of ad‑hoc mirroring and offers an energy‑efficient, synchronized experience in principle. The Quick Settings UX is also a pragmatic choice: low friction for consumers and a controlled surface for Microsoft to iterate on.
However, the feature’s real‑world value will depend on three interdependent forces:
  • OEM and accessory vendor cooperation to ship firmware and driver updates exposing LE Audio capabilities. Without widespread vendor action, the feature remains niche.
  • Cross‑vendor interoperability in buffering and latency behavior. Even with ISO, perceptible misalignment remains possible unless vendors align on latency budgets.
  • Enterprise and privacy controls for managed environments. Broadcasting audio in public or workplace settings must be governed sensibly to avoid accidental data leakage.
If those three conditions are met, Shared Audio could become a routine part of desktop media workflows. If not, it risks staying a pleasant but limited Insider preview used only by early adopters with tightly matched hardware stacks.
Final verdict and next steps for readers​
Shared Audio is a welcome, standards‑first step that brings desktop Windows into the LE Audio era. The implementation shows technical maturity — LC3, ISO, and TMAP are the right building blocks — and Microsoft’s cautious rollout strategy reduces user risk while giving partners time to align. Still, the experience will not be seamless for everyone on day one: firmware updates, vendor drivers, and potential synchronization caveats mean practical adoption will be incremental.
If you have a Copilot+ device and LE Audio‑capable accessories, the preview is worth trying — follow the recommended update and pairing steps and report feedback through Windows Insider channels so the feature can mature. If you manage deployed systems, treat Shared Audio as a pilot candidate, validate it across representative device combinations, and keep wired backups for mission‑critical uses.
Shared Audio marks a concrete moment: the desktop is finally adopting the same LE Audio primitives that modern phones and hearing‑aid ecosystems use. When vendors and OEMs converge on firmware and driver updates, Windows users will gain a broadly useful and low‑friction way to share audio — a small change with outsized daily convenience for media, study, travel, and accessibility.
In short: Windows 11’s Shared Audio (preview) demonstrates how standards‑driven innovation (LC3, ISO, LE Audio) can turn a decade‑old annoyance into a built‑in convenience — but the practical arrival of that convenience depends on a coordinated ecosystem rollout.
Source: en.bd-pratidin.com Windows 11 to let you stream audio to two Bluetooth devices at once | | Bangladesh Pratidin
Microsoft has quietly added a long‑requested convenience to Windows 11: a built‑in Shared Audio (preview) feature that can stream the same audio feed to two Bluetooth headphones or other LE Audio receivers at once, powered by Bluetooth Low Energy (LE) Audio and rolling out to Windows Insiders on select Copilot+ PCs in Build 26220.7051.
A laptop screen shows Quick Settings tiles in blue, with headphones resting on the desk.Background / Overview​
For years, Windows users who wanted to share sound from a laptop or desktop had to choose between awkward workarounds — wired splitters, third‑party dongles, or fragile software routing — because legacy Bluetooth Classic profiles were not designed for multi‑sink media distribution. LE Audio, the Bluetooth SIG’s newer family of audio standards built around the LC3 codec and isochronous channels (ISO), changes that by enabling efficient, synchronized multi‑sink streaming and broadcast‑style audio. Microsoft’s Shared Audio builds on those primitives to offer a native, user‑facing way to share a single synchronized stream to two compatible Bluetooth accessories from one PC.
This is an intentional, phased rollout: Microsoft has delivered the feature as a preview in the Windows Insider Dev and Beta channels and limited initial availability to Copilot+ PCs where Bluetooth radios, firmware and vendor drivers already expose the required LE Audio stack. That conservative approach reduces the risk of a fragmented, unreliable experience while the broader hardware ecosystem catches up.
The user‑facing feature​
  • One PC, two headphones (or speakers/hearing aids): Shared Audio lets a Windows 11 host transmit a synchronized audio stream to two paired Bluetooth LE Audio accessories at once, appearing as a Quick Settings tile labeled Shared audio (preview).
  • Simple flow: Pair both devices via Settings > Bluetooth & devices, open Quick Settings, tap the Shared Audio tile, select two connected accessories and press Share. Use Stop sharing to end the session.
  • Limited preview scope: Initially capped at two receivers in the preview; Microsoft may expand the UX to broader broadcast or Auracast‑style scenarios later.
The technical building blocks (brief primer)​
  • LC3 codec: LE Audio uses LC3 (Low Complexity Communications Codec) to deliver better perceived audio quality at lower bitrates than older codecs such as SBC, which reduces radio airtime and can extend battery life of accessories.
  • Isochronous Channels (ISO): These provide the timing guarantees required to keep multiple receivers synchronized and to lower perceptible inter‑device lag.
  • Multi‑stream / broadcast primitives: LE Audio supports duplicating streams (Auracast‑style broadcasting) and independent left/right streams for earbuds, enabling the underlying mechanism Shared Audio uses to duplicate output without classic Bluetooth compromises.
How to try Shared Audio today (Insider preview)​
These are the practical steps reported for Insiders who want to test the preview. The sequence reflects Microsoft’s current guidance and community‑tested workflows.
  • Enroll the Copilot+ PC in the Windows Insider Program (Dev or Beta channel).
  • Update Windows to Insider Preview Build 26220.7051 (or later) via Windows Update.
  • Confirm your PC and Bluetooth adapter expose LE Audio capabilities; some Copilot+ systems are explicitly in the initial gate.
  • Update Bluetooth and audio drivers from the OEM, and install firmware updates for your headphones using the vendor app.
  • Pair two LE Audio‑capable accessories in Settings > Bluetooth & devices so both show as connected.
  • Open Quick Settings, tap Shared audio (preview), pick two accessories and press Share. Adjust per‑device volume independently if exposed by the accessories.
If you do not see the Shared Audio tile after updating, check for additional OEM driver packages through Windows Update or your device manufacturer’s support site, and try forgetting and re‑pairing the accessories after firmware updates. Those troubleshooting steps have been consistently recommended by community reporting.
Verified technical claims and independent corroboration​
  • Claim: Shared Audio is included in Windows 11 Insider Preview Build 26220.7051. This is confirmed by Insider release notes and multiple independent outlets covering the preview release.
  • Claim: The feature relies on Bluetooth LE Audio (LC3 codec, ISO channels, multi‑stream/broadcast primitives) and requires accessories that support LE Audio. This is described both in Microsoft’s Insider communications and by Bluetooth technical explainers; independent reporting reiterates that LE Audio primitives are required for synchronized dual‑sink operation.
  • Claim: Initial hardware gating to Copilot+ PCs (e.g., Qualcomm Snapdragon‑X powered Surface Laptop and Surface Pro variants) is intentional and necessary because synchronization and multi‑sink audio depend on radio firmware, chipset capabilities and vendor drivers. Community and outlet reports align with Microsoft’s staged rollout approach. However, Microsoft has not published a full, definitive hardware compatibility list as of the preview announcement — treat specific model lists from press coverage as provisional until Microsoft or OEM pages publish them.
Where claims were not independently or definitively documented (for example, a complete, exhaustive supported‑models roster), this analysis flags them as provisional and recommends verifying model‑level compatibility with OEM support pages before making procurement decisions.
Real‑world benefits: why this matters to Windows users​
  • Convenience and simplicity: No more analog splitters, USB dongles, or virtual audio routing for routine shared listening scenarios like watching a movie together, group study, or travel entertainment. The Quick Settings tile makes the flow straightforward.
  • Improved perceived quality and battery life: LC3 enables a better subjective audio experience at lower bitrates, which can extend accessory battery life compared with older Bluetooth codecs when both sides are LE‑capable.
  • Simultaneous mic and stereo playback: LE Audio’s modern profiles reduce the old A2DP vs HFP tradeoff, allowing stereo media to remain intact while a headset mic remains active (so music doesn’t “go to mud” when you use the mic). This is part of Microsoft’s broader LE Audio / “super wideband stereo” work.
  • Accessibility and assistive hearing potential: LE Audio’s hearing‑aid support and broadcast primitives open use cases for assistive listening and private demos, once Microsoft and partners broaden the UX.
Limitations, compatibility caveats and real risks​
While promising, the feature is constrained by current ecosystem realities. These are practical limitations every user and IT professional should weigh.
  • Hardware and firmware dependency: Many existing Bluetooth radios and headsets do not support LE Audio or the specific multi‑stream/ISO primitives needed. Even devices with Bluetooth 5.x are not guaranteed to support LE Audio without explicit firmware and driver updates. Expect a staggered, model‑by‑model availability.
  • Initial Copilot+ gating: Microsoft’s decision to gate the initial preview to Copilot+ systems means large sections of the Windows installed base will not see the feature immediately. This is pragmatic but limits early adoption.
  • Latency and synchronization variability: Although ISO channels provide synchronization, independent buffering and driver behavior inside each headset can introduce slight desync; when two listeners sit close together, even small differences can create audible echo/comb filtering. For pro audio, or competitive gaming where deterministic low latency matters, wired or vendor‑specific RF solutions remain preferable.
  • Battery and host radio load: Streaming to two devices consumes more radio airtime than a single device; while LC3 is efficient, the dual‑sink scenario still increases power usage on the host and each accessory.
  • Support complexity: Troubleshooting will often involve multiple vendors — headset maker, Bluetooth chipset vendor, OEM and Microsoft — which can lengthen support cycles. IT help desks should prepare for this increased support surface.
  • Privacy and discoverability risks if expanded: If Microsoft later opens broadcast/Auracast‑style discoverability on desktop, discoverability and permission models will need careful design to prevent accidental public listening or unauthorized joins; the current preview is intentionally limited to paired devices.
Compatibility checklist — what to verify before you try this​
  • Confirm your PC is a Copilot+ model in the initial preview gate or has vendor documentation asserting LE Audio / ISO support.
  • Update Windows to Build 26220.7051 (Insider Dev or Beta).
  • Update OEM Bluetooth and audio drivers from your manufacturer’s support site (Windows Update may not deliver the OEM’s latest driver).
  • Update accessory firmware (Sony, Samsung, ReSound and others publish LE Audio firmware in companion apps).
  • Confirm each accessory advertises LE Audio / LC3 support in vendor specs; Bluetooth version numbers alone (5.2/5.3) are insufficient evidence of LE Audio support.
  • Keep a wired or USB audio fallback for mission‑critical calls and low‑latency gaming until you validate the performance with your specific headset pairings.
Troubleshooting tips and practical workarounds​
  • If the Shared Audio tile does not appear, check for OEM Bluetooth packages and uninstall/reinstall adapter drivers; re‑pairing accessories after firmware updates often resolves profile negotiation issues.
  • If the two headsets sound noticeably out of sync, test them individually to validate per‑device latency characteristics; consider using the same model pair (same firmware) to reduce timing mismatch.
  • For now, wired splitters, standalone dual‑pair Bluetooth transmitters, or vendor USB dongles with multipoint support remain reliable fallbacks where deterministic sync or very low latency is required.
  • IT groups should run controlled pilots: inventory Bluetooth controller models, vendor driver availability, and headset firmware versions before broad deployment. Document the fallback plan for critical meetings.
Enterprise and procurement implications​
For IT buyers and AV teams, Shared Audio is important but not yet a drop‑in replacement for established wired or vendor RF solutions in enterprise deployments.
  • Procurement should require explicit LE Audio / LC3 / ISO support in headset and adapter spec sheets rather than rely on generic Bluetooth 5.x marketing. Ask vendors for firmware timelines and documented Windows driver compatibility.
  • Pilot with a controlled group before broad rollout. Expect a mixed experience during the rollout window as firmware and drivers land at different cadences across vendors.
  • Update helpdesk knowledge bases to include LE Audio verification steps (check Settings > Bluetooth & devices, confirm “Use LE Audio when available” where present, update drivers, re‑pair) and keep USB/wired fallbacks for mission‑critical scenarios.
The broader Bluetooth audio roadmap and what to expect next​
Shared Audio is a visible milestone in the years‑long migration from Bluetooth Classic to LE Audio across phones, PCs and accessories. As LE Audio adoption grows:
  • Expect more headsets to publish LC3/LE Audio firmware updates and for OEMs to expose LE ISO primitives in their PC Bluetooth stacks.
  • Microsoft could expand the UX beyond a two‑device cap to Auracast‑style broadcasting on desktop, but that raises discoverability, permissioning and enterprise policy questions that will likely delay broad consumer rollout until robust controls exist.
  • The timeline for a fully ubiquitous experience will depend on chipset vendors, OEMs and accessory makers aligning firmware and driver releases; community reporting suggests a likely 6–18 month window of mixed compatibility before LE Audio is universally practical on Windows devices.
Final assessment — strengths and risks​
Microsoft’s Shared Audio (preview) is a welcome, standards‑based correction to a decades‑old Windows UX gap. Built on LE Audio fundamentals — LC3, ISO and multi‑stream primitives — it promises real, everyday benefits: easier shared listening, better power efficiency, and the end of audio‑quality compromises when microphones are used. The Quick Settings UX makes the feature approachable for mainstream users, and gating the experience to Copilot+ hardware for the preview shows prudence in avoiding a fragmented rollout.
But the real‑world experience will be ecosystem dependent. The initial preview accurately reflects the messy reality of cross‑vendor coordination: headsets, Bluetooth controllers, firmware, and drivers must all align for a smooth experience. Expect uneven compatibility, occasional sync quirks, and a heavier support burden during the early months. For enterprise and power users, wired and vendor‑specific RF options will remain the safe choice for low latency and mission‑critical determinism.
Recommendations — practical next steps​
  • If you’re curious: enroll an eligible Copilot+ PC in the Insider Program, confirm Build 26220.7051 (or later), update drivers and headset firmware, and test Shared Audio with a friend using two supported headsets. Document anomalies and report telemetry to Microsoft via Feedback Hub.
  • If you manage fleets: pilot the capability in a controlled group, inventory Bluetooth radios and headsets, require explicit LE Audio support in purchase specifications, and maintain wired/USB fallbacks for critical meetings.
  • If you’re buying headsets now: prefer models that explicitly advertise Bluetooth LE Audio / LC3 support and a vendor commitment to firmware updates; don’t rely solely on Bluetooth version numbers.
Microsoft’s Shared Audio is not a headline‑grabbing overhaul — it’s a practical, standards‑driven enhancement that brings a smartphone‑style convenience to Windows, while revealing the reality of an industry‑wide shift to LE Audio. For users on compatible hardware, it’s an immediate and useful addition. For the broader market, it marks the start of a smoother, higher‑quality era for wireless audio on the PC — one that will only become broadly reliable when device makers, chipset vendors and OEMs finish the hard work of aligning drivers and firmware across the ecosystem.
Source: Mashable India Windows 11 Is Getting AirPods-Style Dual Audio Support: Here’s How It Works
Microsoft is previewing a native Windows 11 audio-sharing feature that can stream sound to two Bluetooth LE Audio headsets, earbuds, speakers, or hearing aids at the same time, bringing PC audio parity with smartphone-style dual-listen features and the new Auracast-capable broadcast model of Bluetooth LE Audio.
Windows 11 promo showing shared audio (Auracast) with headphones and a laptop.Background / Overview​
Bluetooth Low Energy (LE) Audio is the next-generation Bluetooth audio standard built around the LC3 codec and a broadcast model commonly marketed as Auracast. LE Audio delivers lower power consumption, improved audio-codec efficiency, better support for hearing aids, and the ability for one transmitter to serve multiple receivers. Microsoft’s new Shared Audio (preview) in Windows 11 is built on those same LE Audio foundations and exposes a simple Quick Settings workflow for sending the same audio stream to two LE-capable devices simultaneously.
The feature debuted in Windows Insider Preview Build 26220.7051 (Dev and Beta Channels) released October 31, 2025. At launch the capability is limited to a curated set of Copilot+ PCs that include recently released Surface models powered by Qualcomm Snapdragon X-series processors, with other OEM Copilot+ machines listed as “coming soon.” Compatible accessories called out in the preview include modern LE Audio-capable earbuds and headphones as well as select hearing aids, enabling both social listening scenarios and improved accessibility use cases.
What shared audio in Windows 11 actually does​
Shared Audio (preview) is a Windows-level experience that:
  • Lets a single Windows 11 PC transmit the same audio stream to two paired and connected Bluetooth LE Audio accessories at once.
  • Is accessed from the Taskbar Quick Settings via a “Shared audio (preview)” tile; users pick two connected devices and press Share to begin.
  • Uses LE Audio broadcast/streaming technology under the hood but is surfaced as a paired two-device sharing flow in Windows, not an open public Auracast broadcast by default.
  • Requires device and driver updates on the PC and up-to-date firmware on the accessories to enable LE Audio (LC3) operation.
This is not a virtual audio-splitter workaround: it’s a native OS-level LE Audio implementation that aims to deliver synchronized audio to two receivers with minimal setup — provided hardware and firmware line up.
Supported hardware, today and soon​
The initial preview is intentionally limited to a set of Copilot+ PCs. At rollout those included:
  • Surface Laptop, 13.8‑inch and 15‑inch models powered by Qualcomm Snapdragon X processors.
  • Surface Laptop for Business, 13.8‑inch and 15‑inch with Qualcomm Snapdragon X.
  • Surface Pro, 13‑inch (and Surface Pro for Business, 13‑inch) powered by Qualcomm Snapdragon X.
Microsoft lists additional Copilot+ PCs as coming soon, including Samsung Galaxy Book5 series SKUs using Intel Core Ultra Series 200 chips and other Surface variants (different sizes and Snapdragon X SKUs). The Windows Insider preview notes that more Windows 11 PCs will add support over time as OEMs supply compatible Bluetooth and audio driver updates.
Supported Bluetooth LE Audio accessories noted in the preview include, but are not strictly limited to:
  • Samsung Galaxy Buds2 Pro, Buds3, and Buds3 Pro.
  • Sony WH-1000XM6 (recent firmware updates enabled LE Audio/Auracast features).
  • Recent LE Audio-capable hearing aids from established assistive-listening vendors.
Key hardware prerequisites:
  • The PC must expose LE Audio-capable Bluetooth (hardware + driver support).
  • Accessories must support Bluetooth LE Audio/LC3.
  • Latest firmware for accessories and up-to-date Windows drivers are recommended for a smooth experience.
How to try shared audio (step-by-step)​
  • Enroll a compatible Copilot+ PC in the Windows Insider Program (Dev or Beta channel).
  • Update Windows to Build 26220.7051 or newer and install any optional driver updates delivered through Windows Update.
  • Make sure both Bluetooth LE Audio accessories are paired and connected to the PC.
  • Open Quick Settings on the Taskbar and enable the “Shared audio (preview)” tile.
  • Select the two paired accessories you want to share audio with and click Share.
  • To end the session, click Stop sharing in Quick Settings.
Troubleshooting tips:
  • If the Shared Audio tile does not appear after updating, check Windows Update for optional driver packages from your PC OEM and install the latest Bluetooth/audio drivers.
  • Update your accessories’ firmware through the manufacturer app (e.g., Sony, Samsung companion apps) — many LE Audio features require recent firmware.
  • If a paired device doesn’t show up as an option for shared audio, remove it from Windows Bluetooth settings and re-pair after firmware updates.
  • Some USB Bluetooth adapters or older chipsets may not support LE Audio/LC3; built-in Bluetooth on modern Copilot+ PCs or certified LE Audio hardware is recommended.
Why this matters: benefits and use cases​
  • Native, simple dual-listening: For years, sharing audio on a PC required cables, adapters, or clumsy virtual-audio drivers. Windows’ shared audio makes listening with a friend as straightforward as a smartphone audio-share feature, but from a PC.
  • Accessibility and hearing aid support: LE Audio explicitly supports hearing-aid profiles. Windows’ shared audio lets someone use a hearing aid while another user uses consumer headphones, both tuned to the same stream.
  • Travel and shared entertainment: In confined environments — on a plane, in a hotel room, or during study sessions — sharing a movie or a playlist becomes frictionless.
  • Improved game-chat quality and voice use: LE Audio’s LC3 codec and related improvements (including Microsoft’s recent work on “super wideband stereo” and enhanced LE Audio call/microphone handling) mean higher-quality audio without the old tradeoff that forced a headset into mono when using a mic.
The technical underpinnings — LE Audio, LC3 and Auracast​
Bluetooth LE Audio replaces the old A2DP/HFP split with a more flexible model:
  • LC3 codec: A modern, highly efficient codec that delivers the same subjective audio quality at lower bitrates. That improves battery life and reduces bandwidth pressure.
  • Auracast / broadcast model: LE Audio introduces a broadcast paradigm that can, in the extreme, let one transmitter serve potentially unlimited receivers — useful for public venue audio and simultaneous listening. Microsoft’s implementation for Shared Audio appears to use LE Audio’s broadcast/streaming capabilities but in a controlled, paired two-device sharing mode rather than an open public broadcast.
  • Device and chipset dependency: Full LE Audio functionality requires stack support from the PC’s Bluetooth controller, the OS Bluetooth stack, and accessory firmware that supports LC3 and the LE Audio profiles. That is why certain Copilot+ PCs and recent headphone firmware updates are prerequisite.
Compatibility and fragmentation — the practical reality​
LE Audio brings long-term improvements, but the ecosystem transition introduces short-term fragmentation:
  • Chipset and driver variety: Not all Bluetooth radios are LE Audio-ready. Even if a headset supports LE Audio, the PC’s Bluetooth radio (or a third-party USB dongle) must support LC3 and the LE Audio stack. Many older adapters fall back to SBC or classic Bluetooth profiles.
  • Firmware required on accessories: Several leading accessory makers have released firmware updates to add LE Audio/Auracast features, but adoption is staggered. Users must update firmware via vendor apps; without those updates the devices will connect using legacy codecs.
  • Interoperability quirks: Some early dongles or adapters prioritize certain OEM stacks and may not work seamlessly with all LE Audio devices. Reports during early LE Audio deployments show users needing to switch firmware or buy specific dongles to get every combination working.
  • Windows + OEM coordination: Microsoft has designed Shared Audio as an OS feature, but full functionality depends on OEMs shipping LE-enabled drivers and OEMs’ firmware work for particular PC families — hence the Copilot+ phased rollout rather than an immediate universal enable.
Performance, latency and audio quality: what to expect​
  • Latency and synchronization: LE Audio’s LC3 codec and modern implementations are designed to minimize latency and keep streams synchronized across receivers. In practice, performance will vary with device pairing, distance, and the Bluetooth radio’s capabilities. For video playback, LC3 at modern sampling rates is capable of keeping lip-sync accurate, but real-world results depend on the lowest-common-denominator between the two headsets.
  • Codec fallbacks: If one accessory cannot operate in LE Audio mode with a given PC/controller, Windows will need to negotiate compatible codecs. That can force streams to fall back to lower-quality codecs (e.g., SBC), or prevent Shared Audio altogether until both devices are LC3-capable on that connection.
  • Battery impact: Streaming to two headsets will naturally lead to higher total accessory battery usage because both devices are actively decoding and playing audio. LE Audio’s efficiency helps, but exact battery impact depends on codec settings (LC3 bitrate), device power profiles, and whether active noise cancellation is enabled on each headset.
  • Voice and microphone behavior: Shared Audio in this incarnation is for output. Microphone sharing, multi-microphone mixing, or per-listener volume/mix preferences are not part of the initial experience.
Note: precise latency numbers, bitrates used during shared sessions, and the exact battery drain profile have not been published by Microsoft; these remain user-testable metrics and will vary across hardware. Treat any specific numbers you encounter prior to large-scale rollout as provisional until vendors publish verified measurements.
Security and privacy considerations​
  • Private vs broadcast modes: Bluetooth LE Audio supports open broadcasts (Auracast) that receivers can discover and join; Microsoft's Shared Audio preview is a paired two-device flow — that makes it private by default. However, users should remain conscious that Auracast-style broadcasts can be joinable if implemented in a public mode.
  • Eavesdropping risk: The usual Bluetooth security model applies. When sharing with two paired devices, the risk surface is similar to standard paired BT use. Public Auracast broadcasts can be discovered by any LE Audio-capable receiver; that model is intended for venues but necessitates clear UX for discoverability and joining in public contexts.
  • OS-level permissioning: Because Shared Audio is surfaced in Windows Quick Settings and is initiated by the user, it uses the OS’s permissioning model; still, users should be careful when joining or creating public broadcasts in crowded areas.
  • Firmware trust: Accessory firmware updates are essential to enable LE Audio. Only install firmware from verified vendor apps and official channels to avoid malicious or faulty updates.
Troubleshooting and best practices for users​
  • Update everything: Windows, OEM drivers, Bluetooth firmware, and accessory firmware should be up-to-date before attempting Shared Audio.
  • Pair and re-pair: If a device doesn’t appear in the Shared Audio UI, unpair and re-pair after updating firmware. Many LE Audio features require a fresh pairing to negotiate new profiles.
  • Prefer built-in radios on modern Copilot+ hardware: External USB adapters vary in LE Audio support. On Copilot+ PCs with built-in LE-capable radios, the experience will typically be more stable.
  • Test with the manufacturer app: Use accessory apps (Sony Sound Connect, Samsung Galaxy Wearable, etc. to confirm LE Audio is enabled and that the firmware is current.
  • Manage expectations for high-fidelity stereo and mic use: Shared Audio is primarily a dual-output experience. If you require low-latency, mic-enabled, high-fidelity multi-person chat, test your exact scenario — especially for multiplayer games where mic performance and stereo imaging matter.
OEM and accessory vendor landscape: who’s ready and who’s not​
  • Samsung: Has pushed Auracast and LE Audio across its 2023+ devices and Galaxy Buds line, and prominently markets Auracast support in recent buds and phones. Samsung’s ecosystem work positions Galaxy headsets and Galaxy Books as natural LE Audio partners.
  • Sony: Brought LE Audio/Auracast support to recent flagship models via firmware updates and has explicit firmware releases that enabled features such as audio-sharing and head-tracking over LE Audio.
  • Hearing-aid vendors: Companies specializing in assistive hearing devices have adopted LE Audio standards for improved accessibility; Windows’ Shared Audio is explicitly positioned to work with LE Audio-capable hearing aids.
  • Third-party dongles and adapters: Early adopter dongles exist to add LC3/LE Audio to PCs without native support, but these items vary in compatibility and require careful vendor selection and firmware attention.
Because LE Audio is a multi-party transition (Bluetooth SIG, chipset vendors, accessory OEMs, and OS providers), expect incremental support and device-specific behavior during the first year of mainstream adoption.
Developer and enterprise implications​
  • AV managers and IT admins: Shared Audio’s pairing model and Quick Settings approach mean minimal admin overhead for small-scale setups, but enterprises deploying Auracast in public venues will need to consider discoverability policies and Wi‑Fi/Bluetooth coexistence.
  • App developers and audio middleware: Native OS support simplifies apps that provide local shared-listening experiences—media players, virtual meeting spaces, and local content kiosks can now lean on the OS instead of building custom audio routing pipelines.
  • Accessibility teams: The ability to send the same stream to assistive devices and consumer headphones improves inclusivity in classrooms, museums, transportation hubs, and healthcare settings, provided venues and devices implement proper Auracast configurations and privacy controls.
Risks, limits and potential user frustrations​
  • Preview stability: This is a preview feature. Early adopters should expect bugs, glitches, and occasional regressions as Microsoft collects feedback and refines interactions.
  • Device mismatch: Because Shared Audio requires both ends to support LE Audio, mismatched pairings or older headsets will either fail to join or force a lower-quality fallback.
  • Fragmentation means inconsistent user experience: Some pairings will be flawless, others will require specific dongles, firmware versions, or even waiting for OEM driver updates. This can frustrate users who expect a “plug-and-play” smartphone-like experience.
  • Lack of per-listener controls: Initially the experience is focused on output sharing. Advanced needs such as per-listener EQ, independent volume balance, or individual language tracks are not yet part of the built-in Shared Audio workflow.
  • Unclear public broadcast UX: If Windows later surfaces Auracast-style public broadcasts, UX and security decisions around discoverability and joining will be critical to prevent confusion or accidental joins in public venues.
Market context — why Microsoft’s move matters​
Smartphones from leading vendors have been adopting LE Audio and Auracast features to enable dual listening and public broadcast audio models. Microsoft’s step to integrate a polished Shared Audio flow into Windows 11 closes a functional gap between desktop OSes and mobile devices. This matters for several reasons:
  • Windows remains a primary content-creation and media-playback platform for many users; bringing native dual-stream support removes legacy barriers (cables, adapters, third-party apps).
  • The addition strengthens Windows’ credentials for mixed-device scenarios — a Copilot+ PC can be both an AI hub and a shared audio hub for content in classrooms, workplaces, and family settings.
  • Microsoft’s phased, Copilot+-first rollout reflects the complexity of getting LE Audio working end-to-end across silicon, drivers, firmware, and accessory ecosystems — a sensible approach even if it slows full availability.
What the rollout schedule and expectations look like​
  • Preview availability: Starting with Windows Insider Preview Build 26220.7051 on October 31, 2025, for Dev and Beta Channels, Microsoft is distributing Shared Audio to Copilot+ PCs in a staged manner.
  • Phased hardware expansion: Additional Copilot+ models from Microsoft and OEMs (Samsung Galaxy Book5 family and other Surface SKUs) were listed as “coming soon” and expected to receive driver updates in the weeks following the initial preview.
  • General availability timeline: Microsoft is rolling this feature gradually. Widespread availability will depend on OEM driver updates and accessory firmware adoption. For users not enrolled in Insider builds, expect a mainstream rollout only after Microsoft has gathered feedback and addressed initial compatibility issues.
Practical buyer advice — what to look for when purchasing accessories or PCs​
  • Look for explicit LE Audio or Auracast support in product specs when buying headsets or earbuds if you plan to use Shared Audio.
  • Prefer recent flagship or mid-tier devices that manufacturers have explicitly updated to include LE Audio features via firmware.
  • For laptops, Copilot+ PCs with integrated Qualcomm Snapdragon X-series radios or OEMs advertising LE Audio readiness are the safest bet for a seamless Shared Audio experience.
  • If you must use a dongle, choose a vendor with explicit LE Audio/LC3 support and active firmware maintenance — compatibility varies widely across low-cost adapters.
Final analysis — strengths, weaknesses, and the road ahead​
Strengths:
  • Native OS-level dual-listen removes long-standing pain points for sharing audio from a PC.
  • Built on LE Audio and LC3, the approach is future-ready: better battery life, improved codec efficiency, and accessibility for hearing aids.
  • Integrates naturally into the Quick Settings UX, lowering the barrier for everyday use.
Weaknesses and risks:
  • Early-stage rollout is limited to Copilot+ PCs and depends on OEM driver and accessory firmware updates, creating short-term fragmentation and uneven experiences.
  • Not all Bluetooth controllers or USB dongles will support LE Audio out of the box; users may need to replace or update hardware.
  • Preview features can be buggy, and Microsoft has not published complete performance metrics (latency, exact bitrates, battery impact), so real-world results will vary.
The road ahead:
  • Expect the shared audio experience to mature over the next several months as more Copilot+ and non-Copilot PCs receive driver updates and accessory vendors push LE Audio firmware. As Auracast adoption grows among phones, earbuds, TVs, and hearing devices, shared listening and broadcast audio models will become a standard expectation across ecosystems.
Windows 11’s Shared Audio (preview) is a meaningful, practical application of Bluetooth LE Audio technology that finally gives PC users a native, simple way to stream the same audio to two wireless headsets or hearing devices simultaneously. The feature aligns Windows with mobile platforms that already offer dual-listen experiences and leverages LE Audio’s efficiency and accessibility benefits. Early availability is intentionally narrow — limited to Copilot+ PCs with compatible Bluetooth stacks and up-to-date accessory firmware — which reduces the risk of a chaotic rollout but does mean many users will need to wait or update hardware.
For early adopters with Copilot+ machines and LE Audio-capable accessories, the preview is an attractive, low-friction feature to test. For others, the practical advice is clear: update firmware, check OEM driver support, and be patient. The broader ecosystem transition to LE Audio and Auracast will take time, but Windows’ native support for shared audio is an important milestone that should make shared listening, accessibility, and public-audio scenarios easier and more robust across the PC landscape.
Source: www.extremetech.com Windows 11 Lets Users Connect to Audio With 2 Wireless Headsets Simultaneously
