pstein
Assume I have an external hard disk with one (backup) partition which is currently mounted as drive Q:\
Now I right-click on the Recycle Bin icon on my desktop, then select Properties--->Drive Q: and enable
"Don't move files to the recycleBin. Remoive files immediately when deleted"
Much to my surprise this switch does NOT delete currently existing stuff in RecycleBin of drive Q:\
The toggeling applies only to future deletes.
Can someone confirm this strange behaviour?
How can I tell Win 7 to delete ALL currently existing files in RecycleBin of drive Q: ?
Can I simply unhide "protected folders" in WinExplorer and delete all the files manually?
Or is there a smarter way?
How do I delete all files+folders fom all RECYCLEBINs from all partitions currently mounted?
Peter
This is normal behavior, and yes you can could unhide C:\$Recycle.Bin and delete the content inside, or run the Disk Cleanup utility and check the box next to Recycle Bin will also work.
Neemobeer
Windows Forum Team
