display font style problem >.<
need help :(
just see the pic above, cant display the words in the red box properly, it has been like that since i removed office 2007 manually (installed it in control panel then removed the ms office folder and used registry removal tool), it didnt work when i tried install office again
plz help, its so annoying
thnx
Saltgrass
The last time I saw a post were the font would not fit the dialog box was when someone had deleted one of the Windows system fonts.
If you think you may have done that, or just want to check, open an administrative command prompt window and type:
SFC /scannow
followed by enter. This should do a system file check and possibly find the missing font, if that is the problem.
To open an administrative command prompt, type CMD in the Start Menu search box and hit CTRL+Shift Enter.
