DPC Watchdog Violation
Hi, whenever I play League of Legends now, I get BSOD that claim DPC Watchdog Violation.
I had a previous igdkmd64.sys driver irql not less or equal error that was seemingly fixed by removing Norton a week ago. Since then, I had no bsod's playing LoL until today.
Windows Forum Admin
BugCheck 133, {0, 501, 500, 0}
*** WARNING: Unable to verify timestamp for igdkmd64.sys
*** ERROR: Module load completed but symbols could not be loaded for igdkmd64.sys
Probably caused by : igdkmd64.sys ( igdkmd64+63379 )
Followup: MachineOwner
Please update your Intel graphics driver:
http://support.toshiba.com/support/modelHome?freeText=1200007392
Laptop drivers are supplied by the manufacturer so please make sure I have the correct model in the link above.
Thank you~
So far, there have been no BSOD's. I'll post back if any still happen.
Hi, my laptop has started to BSOD a lot again frequently while playing LoL. T_T
Windows Forum Admin
same again Intel display driver. Try using this application to remove the old driver and then re-install:
http://www.bleepingcomputer.com/download/driver-fusion-driver-sweeper/
You can obtain new copies from the link above. Just check the os to see if any files have become corrupted. Right click in the bottom left hand corner of the screen and click on admin command prompt. Type:
sfc /scannow
Press enter and await results.
Try running memtest86:
http://www.memtest.org/
Yes, it said stuff had been corrupted. (uploaded cbs log below)
I'll run the memtest over night while sleeping.
Windows Forum Admin
#7
2014-02-17 03:59:07, Info                  CSI    000004b5 [SR] Cannot repair member file [l:36{18}]"Amd64\CNBJ2530.DPB" of prncacla.inf, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type = [l:24{12}]"driverUpdate", TypeName neutral, PublicKey neutral in the store, hash mismatch
2014-02-17 03:59:13, Info                  CSI    000004b6 Hashes for file member \SystemRoot\WinSxS\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.16384_none_9590ba64d5b91f79\Amd64\CNBJ2530.DPB do not match actual file [l:36{18}]"Amd64\CNBJ2530.DPB" :
  Found: {l:32 b:e6aeGcWF/T38nCcBHUsKpxH8n/ntmcWin0e7A1/84K0=} Expected: {l:32 b:n520k714Uu3utHa5JGQ6HQYbZphKhlMWq5pEmfnCDuw=}
2014-02-17 03:59:13, Info                  CSI    000004b7 [SR] Cannot repair member file [l:36{18}]"Amd64\CNBJ2530.DPB" of prncacla.inf, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type = [l:24{12}]"driverUpdate", TypeName neutral, PublicKey neutral in the store, hash mismatch
Looks like from the above that files relating to the processor have become corrupt. You can always try a 'Refresh' but personally I would do a clean install booting off the windows 8 install disk.
