Driver IRQL not less or equal
I realize several people have asked about this problem, but everyone's issue seems to be unique.
I'm running Win7 64-bit, zip file of last 4 dmp files is attached.
Thanks!
kaos
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa8005932038, Address of the WHEA_ERROR_RECORD structure.
Arg3: 0000000000000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000000, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR:  0x124_GenuineIntel
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
CURRENT_IRQL:  0
STACK_TEXT:
fffff880`033ee6f0 fffff800`02d14c59 : fffffa80`05932010 fffffa80`03cfb040 00000000`00000010 00000000`00000000 : nt!WheapCreateLiveTriageDump+0x6c
fffff880`033eec10 fffff800`02bf4fa7 : fffffa80`05932010 fffff800`02c6f2b8 fffffa80`03cfb040 00000000`00000000 : nt!WheapCreateTriageDumpFromPreviousSession+0x49
fffff880`033eec40 fffff800`02b5c5c5 : fffff800`02cd0ac0 00000000`00000001 fffffa80`0593a600 fffffa80`03cfb040 : nt!WheapProcessWorkQueueItem+0x57
fffff880`033eec80 fffff800`02adc021 : fffff880`010e0e00 fffff800`02b5c5a0 fffffa80`03cfb000 ffffffff`ffffffff : nt!WheapWorkQueueWorkerRoutine+0x25
fffff880`033eecb0 fffff800`02d6e32e : ffffffff`ffffffff fffffa80`03cfb040 00000000`00000080 fffffa80`03ceb9e0 : nt!ExpWorkerThread+0x111
fffff880`033eed40 fffff800`02ac3666 : fffff880`009e7180 fffffa80`03cfb040 fffff880`009f1f40 ffffffff`ffffffff : nt!PspSystemThreadStartup+0x5a
fffff880`033eed80 00000000`00000000 : fffff880`033ef000 fffff880`033e9000 fffff880`0328f7c0 00000000`00000000 : nt!KiStartSystemThread+0x16
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: hardware
IMAGE_NAME:  hardware
DEBUG_FLR_IMAGE_TIMESTAMP:  0
FAILURE_BUCKET_ID:  X64_0x124_GenuineIntel_PROCESSOR_BUS_PRV
Followup: MachineOwner
1: kd> !analyze -v
Arguments:
Arg2: fffffa8006679038, Address of the WHEA_ERROR_RECORD structure.
Debugging Details:
CUSTOMER_CRASH_COUNT:  2
CURRENT_IRQL:  0
STACK_TEXT:
fffff880`033e76f0 fffff800`02cc8c59 : fffffa80`06679010 fffffa80`03cfc680 fffff8a0`001949d0 00000000`00000000 : nt!WheapCreateLiveTriageDump+0x6c
fffff880`033e7c10 fffff800`02ba8fa7 : fffffa80`06679010 fffff800`02c232b8 fffffa80`03cfc680 00000000`00000000 : nt!WheapCreateTriageDumpFromPreviousSession+0x49
fffff880`033e7c40 fffff800`02b105c5 : fffff800`02c84ac0 00000000`00000001 fffff8a0`00194948 fffffa80`03cfc680 : nt!WheapProcessWorkQueueItem+0x57
fffff880`033e7c80 fffff800`02a90021 : fffff800`02ea6f70 fffff800`02b105a0 00000000`00000000 fffffa80`03cfc680 : nt!WheapWorkQueueWorkerRoutine+0x25
fffff880`033e7cb0 fffff800`02d2232e : 00000000`00000000 fffffa80`03cfc680 00000000`00000080 fffffa80`03ceb9e0 : nt!ExpWorkerThread+0x111
fffff880`033e7d40 fffff800`02a77666 : fffff880`009e7180 fffffa80`03cfc680 fffff880`009f1f40 00000000`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`033e7d80 00000000`00000000 : fffff880`033e8000 fffff880`033e2000 fffff880`033e72c0 00000000`00000000 : nt!KiStartSystemThread+0x16
STACK_COMMAND:  kb
fffff800`00bd1000 fffff800`00bdb000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff800`02a06000 fffff800`02fef000   nt       ntkrnlmp.exe Sat Apr 09 05:15:23 2011 (4D9FDD5B)
fffff800`02fef000 fffff800`03038000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`00c5c000 fffff880`00c6c000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`00c6c000 fffff880`00c86000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`00c86000 fffff880`00c8f000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00caa000 fffff880`00cf9000   mcupdate mcupdate.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`00cf9000 fffff880`00d0d000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`00d0d000 fffff880`00d6b000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00d6b000 fffff880`00d9e000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00d9e000 fffff880`00db3000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00db3000 fffff880`00dc8000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00dc8000 fffff880`00df2000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`00df2000 fffff880`00dfd000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`00e00000 fffff880`00e0f000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00e0f000 fffff880`00e66000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`00e66000 fffff880`00e6f000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00e6f000 fffff880`00e79000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`00e79000 fffff880`00e86000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`00e86000 fffff880`00e8e000   intelide intelide.sys Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`00e90000 fffff880`00f50000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`00f50000 fffff880`00ff4000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00ff4000 fffff880`00ffb000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`010cc000 fffff880`01118000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`01118000 fffff880`01189000   SYMDS64  SYMDS64.SYS  Wed Dec 08 00:16:58 2010 (4CFECE7A)
fffff880`01189000 fffff880`0119d000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`01200000 fffff880`0125e000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`0125e000 fffff880`012d0000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`012e6000 fffff880`013ca000   SYMEFA64 SYMEFA64.SYS Mon Mar 14 03:20:58 2011 (4D7D899A)
fffff880`01400000 fffff880`0140a000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`0142d000 fffff880`015d0000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`015d0000 fffff880`015eb000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`015eb000 fffff880`015fc000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`01600000 fffff880`01630000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`01630000 fffff880`01643000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`01674000 fffff880`01767000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`01767000 fffff880`017c7000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`017c7000 fffff880`017f2000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`01800000 fffff880`0184c000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`0184c000 fffff880`01886000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01886000 fffff880`01894000   52814182 52814182.sys Thu Oct 22 10:54:01 2009 (4AE02BB9)
fffff880`01897000 fffff880`01a9b000   tcpip    tcpip.sys    Sat Nov 20 09:25:52 2010 (4CE79420)
fffff880`01a9b000 fffff880`01ae5000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`01ae5000 fffff880`01bd5000   timntr   timntr.sys   Wed Jun 02 13:56:47 2010 (4C06550F)
fffff880`01bd5000 fffff880`01be3000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`01be3000 fffff880`01bef000   dump_ataport dump_ataport.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01bef000 fffff880`01bf8000   dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01c00000 fffff880`01c12000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`01c12000 fffff880`01c1b000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`01c1b000 fffff880`01c31000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01c39000 fffff880`01d70000   tdrpm273 tdrpm273.sys Tue Aug 10 10:54:18 2010 (4C6121CA)
fffff880`01d70000 fffff880`01d78000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`01d78000 fffff880`01dbe000   snapman  snapman.sys  Thu Nov 11 11:05:10 2010 (4CDBCDE6)
fffff880`01dbe000 fffff880`01df8000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
Mini Kernel Dump does not contain unloaded driver list
