Windows 7 DVD Problems
Thomas
Every time I use the dvd to install anything I gat a message.
Retry, Cancel, skip :confused:
The only way to get it to stop is reboot. :mad:
I have a HP light scribe DVD
Amy one else having this problem ? :eek:
Using Windows 7 64 bit
Thomas :cool:
Don't forget, it's only a Beta 1 release. Not all hardware is going to be handled in a Beta. The final release will have a lot more hardware support. Did you try the DVD manufacturer's site, or Guru3d? Also try a Vista Driver and use the Vista compatibility option for the driver setup.
Driver
The driver is somthing that MS should put in the os and have it right. I have two computers and only one of them do this. They boath have HP Light scribe dvd's in them. I am using 64 bit on boath. So I see it as a bug. I still have never got any updates on Windows 7 yet. The only thing they have up dated is the definations . :(
Thomas:cool:
