ReeceN
Hi.
I have a new Dell XPS 15 with Windows 10 Pro and a TPM 1.2 module on the board.
I have enabled Enhanced PINs via the Group Policy Editor and have set my pin using a mixture of letters, numbers and symbols. However when I restart the machine, it does not accept my entered PIN.
However, it does recognise this PIN when I am using the change Bitlocker Pin option from within Windows.
I am wondering, is there a way to find out if my TPM actually supports Enhanced PINs?
Thank you!
Neemobeer
Windows Forum Team
Open an elevated command prompt and type manage-bde -status and manage-bde -protectors -get C: and post the output
ReeceN
Disk volumes that can be protected with
BitLocker Drive Encryption:
Volume C: [OS]
[OS Volume]
BitLocker Version: 2.0
Conversion Status: Fully Encrypted
Percentage Encrypted: 100.0%
Encryption Method: XTS-AES 128
Protection Status: Protection On
Lock Status: Unlocked
Identification Field: Unknown
Key Protectors:
Numerical Password
TPM And PIN
Volume C: [OS]
All Key Protectors
Numerical Password:
Password:
[removed]
TPM And PIN:
PCR Validation Profile:
0, 2, 4, 11
