Keith Kayrungrang
Member
Hello there,
I have an HP 15-G013CL that I am trying to do a clean install of Windows 7 (64-bit) on.
A little background to the cause of the error: I first tried to do a clean install of Windows 7 (32-bit). This led me to an error that I received before Windows even started up. The error said "Windows failed to load because a critical system driver is missing, or corrupt."
I was told by someone on the HP Forum that it may have been because I am installing the wrong version of Windows (I was doing 32-bit instead of 64-bit). Apparently the OEM Operating System was 64-bit. Now I am trying to do a clean install with the 64-bit (note that I did not delete anything and am unsure if the first OS installed, just tried to do another clean install with the 64-bit version).
The Windows 7 Installer started! But first ran into an issue where I was unable to select the partition that was available. There were 2 options, and I had deleted both of them, since it said I was not able to use either one to Install Windows 7 (sorry my details are kind of vague here). After deleting both disks, I was able to click "Next."
Now I've received an error saying my installation was cancelled because "Windows could not format a partition on disk 0. The error occurred while preparing the partition selected for installation. Error code 0x80070057."
Any idea how I can solve this error and do a new clean install of Windows 7 on my laptop?
Thank you!
Thank you!
