youbetter
If you are asked to format the external hard disk before you can use it, then you mat meet the external hard disk raw error. That external hard disk can not be used before we format it. Some people worry about losing data saved on the external drive previously. We need not to be worried, as we can restore them from the raw external hard disk. We should format it later.
Here are the steps as follows:
Step1. Download and mount the data recovery software on the computer.
Step2. Connect the raw external hard disk to the computer, too.
Step3. Run the data restoration tool by double clicking it. Then we can choose the recovery model and aim disk to scan.
Step4. Wait some minutes to preview the contents in the list after scanning and we can pick up the wanted to recover.
Step5. Select one of the computer hard disks as the location to save files to be recovered.
Useful link: http://www.ucfix.com/data-recovery/external-hard-disk-asking-to-format-it.html
Pauli
Fantastic Member
I don't really get the point. The drive has to be formatted before taken into use, and once it's formatted, it is. And the data is there.
Are you referring to a re-installation, after a major crash?
Joe S
You can try data recovery software. As a last ditch you might running the command prompt to convert the disk from FAT32 to NTFS. It sometimes works this link shows the command to use Link Removed
Joe
