Deadz3
lately my graphic card is having problem, my pc will freeze and stop working, from the event log i can see
"error nvlddmkm - Event id 14"
"error nvlddmkm - Event id 13"
i tried to unistall drivers, try older drivers, format the pc, nothing worked.
is there a fix to this problem?
sometimes nvidia driver kernel has stopped working and has successfully recovered will pop up and instaead of crashing, my pc will just freeze till i close every application
it happen everytime when i try to play a game, or randomly while watching videos
Faulty graphic card or drivers problem?
my specs are :
windows 7 64 bit
Geforce Gtx 770
berlin 630w thermaltake 80
Intel core i5
8gb ram
if you need other information just tell me.
are you sure it's not overheating? If your overclocking stop. Remove any dust build up and monitor the cpu and gpu temperatures. Try uninstalling the current driver using DDU (display driver uninstaller) as this removes anything left behind by previous installs:
Display Driver Uninstaller (DDU) V15.7.1.0 Released. - Wagnardmobile Forum
Install latest WHQL driver.
This app will check the Vram:
Finally see if you can run Furmark stress test (watch the temps too):
FurMark: VGA Stress Test, Graphics Card and GPU Stability Test, Burn-in Test, OpenGL Benchmark and GPU Temperature | oZone3D.Net
Deadz3
Im sure it's not overheating. (using HwMonitor ), nothing is overclocked, but i use msi afterburner / A tuning for configure fan speed.
i already tried using DDU, but that's still happening, there is no dust in the pc.
i checked vram, 0 errors.
i can't upload the file. (the uploaded file does not have an allowed extension)
Cambiamento risoluzione a 640x480x16 in corso...OK
[10/12/2015 10:39:41] Test iniziato "Driver video primario (NVIDIA GeForce GTX 770)"...
Test 16bpp RGB:565 in corso...OK
Test 16bpp RGB:555 in corso...OK
Test 16bpp BGR:565 in corso...NON SUPPORTATO (Codice: 80004001)
Test 32bpp RGB:888 in corso...OK
Test 32bpp BGR:888 in corso...NON SUPPORTATO (Codice: 80004001)
[10/12/2015 10:49:29] Test Completato (0 errori trovati).
is furmark safe?
i heard that furmark can cause permanent damage to the graphic card.
Deadz3
Oh, i installed furmark, did the stress test,
after 6 seconds, the test crashed, and "nvidia driver kernel has stopped working and has successfully recovered" pop up.
and after the test closed
" Nvidia opengl driver, unable to recover from a kernel exception. the application must close. Error code: 3." came
from the event log, the problem is nvlddmkm driver
Deadz3
I did the test again, and now it lasted 1 minut.
71 C° till my screen blocked and had to wait till nvidia "nvidia driver kernel has stopped working and has successfully recovered" came out
How old is the PSU?
Try reseating the GPU.
Is it possible for you to run the gpu in a friends machine and test with furmark again?
Just a word to the wise. MSI AfterBurner is known for causing BSOD's (google it if you don't believe) so might be worth uninstalling to test..
Deadz3
The psu is old around 18 months,
oh, and the problem started around 3 months ago, but it was not a huge problem, then started to be that.
if MSI afterburner is the problem, it's not strange that the problem started only "now" ?
what you mean with "Reseating the gpu"?
Pulling it out and then placing it back in the motherboard.
I never said it 'was' the problem. I just said it could be and besides Windows changes all the time what with updates, different software etc. It's entirely up to you, all I'm saying is that it is known for causing the odd issue although chances are it probably isn't in this case
What about try it in a friends machine?
Deadz3
ok, i will try it!
I will unistall msi and try if everything is stable.
Right now i can't.
Thanks for the help
Something else you could try if the above doesn't help is under clocking the card slightly. Test again and see if the card will run. If it does then it could be a power supply issue or the actual card itself.
Just out of interest have you tested the cpu?
Intel diagnostic
Deadz3
I did everything, but, after 2 days ( after reseating the graphic card ) it happened again.
this time, the screen blocked and i had to shutdown the pc.
this time there were no errors in the event viewer, i tested the cpu, it is not a problem.
i think it's an hardware thing then.
