I've seen on other sites people complaining about not having any sound after install Windows 7 under Parallels. The fix is to do the following:
1. Make sure you've updated Parallels to the latest version 4.3180.
2. Make sure you've installed the Parallels Tools pack.
3. From the Control Panel, click on the Device Manager
4. Find the device that's not installed, it's listed as 'Multimedia Audio Controller'
5. Click on the device and install/update the driver.
6. Let Windows go out to the Internet to find the driver.
7. Install the selected drive and click 'Ok'
Windows will install the driver and give you sound inside your Windows 7 VM.
<Tested on 2.4 Ghz MBP with Parallels 4.3180>
